SanDisk Sansa View 8GB MP3 Player - Black Logo
Posted on Sep 28, 2008
Sansa view it wont charge and keep a charge
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jan 31, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
137
Points
I had the same problem and finally solved it by downloading latest firmware and then re-formating. You lose all the uploaded songs,etc. that were on the player, but the battery holds charges just fine after this. Since all the music I wanted was already in windows media player, it took one quick sync to get it all back on the player.
SanDisk Sansa C240 1 GB MP3 Player only shows half empty battery picture on screen and wont turn on. So it needs fixing.
Question edited for a lot more clarity.
Question moved from Misc to model category.
Replace the internal Li-Po battery, but try a reset first.
https://www.google.com/search?q=sandisk+sansa+c240+battery+replacement
If your Sansa player is freezing, not charging or not turning on, the first thing to try is a reset of the unit. This will normally clear any temporary condition that may cause the player to freeze or not shut off completely, it's a bit like when your PC crashes and you need to re-start it to clear the error.
Dec 28, 2020
My Sansa MP3 player has stopped working or charging
Sansa Clip Won't Charge - iFixit
iFixit https://www.ifixit.com > Answers > View > Sansa+Clip...
Feb 15, 2021 - I found an older Sansa Clip which will power on when connected to a USB charger or to the computer, but it won't boot up or hold a charge.
1 answer · 1 vote: Hi, Sounds as though the battery has failed and needs to be replaced. I couldn't find a battery replacement guide for a Sansa Clip but here's a video ...
How to replace dead battery in Sansa Clip mp3 player?
Oct 1, 2010
Why is my clip say tranferring and not charging
Jan 16, 2017
Where can I find a new battery? - Sansa Clip Plus
Mar 27, 2017
My MP3 player won't turn on once I remove the charger.
Aug 3, 2015
More results from www.ifixit.com
Sansa Clip Battery is not charging - SanDisk Forums
sandisk.com https://forums.sandisk.com > sansa-clip-battery-is-not-...
Jun 4, 2008 - You can try to charge the device first, to make troubleshooting easier. Unplug the device, then select Settings, then USB Mode, then MSC. Now ...
SANSA CLIP ZIP NOT TURNING ON, NOT CHARGING
Feb 27, 2013
Sansa clip won't charge - SanDisk Forums
Jan 4, 2010
SanDisk Sansa Clip+ doesn't charge, doesn't turns on or ...
Nov 2, 2016
Sansa Clip Zip battery won't charge, goes straight to song ...
Nov 28, 2014
More results from forums.sandisk.com
Sansa will not charge, keeps saying connected, but wont charge. Also need a how to use manual.
Having gone over a month without a response, I assume this is no longer a problem.
3helpful
I have a Sansa View 8gb and the battery would die like within like 3-5 hours but when I connect it to my computer and go to properties I found that it was charged 84% what should I do about it?
What you need to do is let your player die. Then after it is dead keep turning it off and turning it on till it stops responding. This will run the player out of all battery charge. Then you will keep turning it on so that you can deplete the battery charge that your player sets up as a backup power. Then you need to plug it into your computer and let it charge all night. This will reset the player battery memory so that you can have full charge again. If this does not work your battery might be going out and you should look into either replacing it or investing into another mp3 player.
Mp3 2gb sansa veiw wont turn on... but charge screen will show up
it seems that your player are corrupted.
it means some of your file are infected with virus and corrupted.
if you can try to reformat your player i suggest you to do it.
be aware that if you will going to reformat all files saved are possible to be deleted.
thanks,
It wont turn on!
If you were charging it with your USB cord, you have to keep the computer turned on the whole time it's charging, otherwise, it will be losing it's charge.
My 8 gb sansa
Does the charging sign show up? It could be a bad cable. Also make sure you have the right software You can get it here at: http://www.sandisk.com/sansa
Go to Support\product support\sansa view\ thenlook in the right column
Try it with different usb ports as well.
Go to Device Manager and look for "?'s" or "!'s"
2answers
Sansa view
if you did not charged it properly you could of just messed it up so just call the company they should fix it for free
Sansa Clip 2GB
yu charge it erveryday, and yuve been using it everyday, so that means that it needs to charge, if it says connected tocomp and charging that means that it needs more electricity in its battery to keep, its battery running.
Top SanDisk Audio Players & Recorders Experts
SmartAviator
SmartAviator
Grand Canyon Tech
Grand Canyon Tech
Alexander
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
