Question about GE Energy Star 3.7 IEC Cu. Ft. Front Load Washer with Stainless Steel Basket
Ge adora whdvh626fww not filling with water and locks door
My ge door buzzes the locks and i hear some humming underneath drum but no water filling up drum. humming lasts 5 minutes the unit resets back to original time without doing anything. could my door lock be bad?
  • 1 more comment
  • jflani Sep 28, 2008
    ok i just tried to fill it with water and the humming was the pump pumping with no water in it. pumped out fine with water in it. i had it set to rinse and spin setting. is the pump supposed to come on in the beginning like that? thx for any input
    still not filling with water on its own i used a hose....
  • jflani Oct 01, 2008
    thx anyway i already ordered new computer board per service man i called,thx
    Sergeant:
  • 409 Answers
just the water supply hose for any kinks or leaks. doesn't sound like you have any incoming water at all or the water pressure to the house if very low.
thanks
Posted on Sep 30, 2008
  • Carmen Mikulic Sep 30, 2008
    you need to check the hose from the wall into the machine. if the hose is okay, replace the drain pump.
  • 1,879 Answers
Can you take a look at the pump to see check why it is able to pump-in water ? Motor is still good as you can hear it trying to pump-in water.
Ge adora WHDVH626FWW makes clunking noises when spinning, bearings seem ok
Could be a broken Hub Spoke, My Kenmore broke at the spokesand bearing e.of drum,
Sears replaced all parts as the were still uder warrenty. Less than 10 years old, would have been over $1,000 cost otherwis.
Sep 30, 2012 | GE Wh12x10309 Heater for Adora Front Load...
GE dryer model DDE8200GALAD was working fine. After removing a load and trying to dry another, after inserting the load and shutting the door when you turn the timer to start it before pushing the start...
If you hear the motor humming and not starting at all it most likely has a severe friction problem with the drum or motor. It could possibly have some type of garment jamming the blower wheel preventing the motor from starting too.
Open the dryer door and manually rotate the dryer drum counter clockwise (CCW). It should take very little effort to rotate the drum. If it's hard to rotate that could explain why the motor hums instead of starting up. If it turns freely, shut the door and see if will start. If it still hums and not start it may have bad motor or a low voltage supply to the motor.
Jan 23, 2011 | GE Dryers
NOT FILLING THE WATER
Is there a faint buzzing or humming noise coming from the water-inlet valve? (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If you can't hear anything, the water-inlet valve may not be getting any power. If you can hear some noise and there's water present, you may need to completely replace the water-inlet valve.
Dec 14, 2010 | GE WPGT9360EPL Top Load Washer
GE front load washer wont start model #WHDVH626FWW
there is a chance that your door lock has failed
Feb 06, 2010 | GE WSXH208A Front Load Washer
Ge front load washer model WSXH208A Will not spin
Mine kept stopping mid cycle also, pouring water on the floor, then the start/pause button flashed and the door unlocked. I found the solution to clean the lint filter on the GE Adora. Go to http://www.instructables.com/id/GE-Adora-Lint-Filter-Cleanout/?download=pdf
I just did this and my washer is now running instead of the flashing start/pause and door unlocking. It was fairly easy. Make sure you have towels and a flat pan to catch the water if you don't have the machine on a riser. There may be water inside so a wet vac may be helpful too. Once my washer finishes what was in it, I have these funky towels to clean. You'll be very surprised what you find in the filter! Best of luck!
Oct 13, 2008 | GE WSXH208A Front Load Washer
GE WHDVH626fWW Door Locked, but not
As most these washers use the same control board.
try some of the troubleshooting you see here :
http://www.fixya.com/support/t364216-whirlpool_duet_ht_ghw9400pl0
The main relay (black one on the right of board ) may be at fault in your issue.
these boards have bad solder joints in most all cases.
If its still in warranty it time to call them.
If you open it please post pics.
Feb 03, 2008 | Washing Machines
Humming and not filling?
had the same problem this morning, turned out the pump on the drain side had frozen, took it apart, and broke free the fan, humming stopped, washer back up and working.  Its two screws to the bottom of the washer, two electrical connection (white and black) two hoses to undo, and three screws on the pump itself, after actually committing to doing it, only took about 10 minutes.
good luck
Oct 13, 2007 | GE WSXH208A Front Load Washer
GE washer wont spin or wash
It sound like a lid switch issue. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. Look if the switch is broken or loose. In case it looks OK mechanically, it might be defective electrical and should be replaced. Good luck!
Sep 09, 2007 | Washing Machines
Door Lock Clicks/Makes noises Washer does not agitate/spin
Sounds like very worn motor brushes to me, as its trying to turn the drum but has'nt the power needed to maintain any momentum,and the blinking door light is because of the bad cotact from brushes to motor.About £20 for a set of brushes or get an engineer to fit new brushes,but get a price first.
Apr 18, 2007 | GE WSXH208A Front Load Washer
GE Energy Star 3.7 IEC Cu. Ft. Front Load Washer with Stainless Steel Basket Logo
509 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
