Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
Interior walls cracking...
Frigidair side by side... the interior of the fridge side is cracking. the fridge is 4 years old. has two cracks, one on either side of the fridge interior, half way down from the top.
any health issues? do i need a new fridge or is it just a cosmetic thing.
  • 958 Answers
I don;t think there would be a health issue involve.
the old fiber glass has been replaced with polyurethane foam now a days to replace the more dangerous fiber glass insulation.
if you can replace the plastic part that cracked open, that would much better.
tnx 4 using fixya,
drcool
Posted on Sep 28, 2008
Back of interior in fridge has developed a horizontal crack of 400mm about half way up. Is this a problem ?
yes
it will allow moisture to get between the walls , turn to ice and expand or rot the insulation and rust the back of the fridge
time to consider an alternative unit
Oct 30, 2016 | Refrigerators
The inside glass panel, in the oven, has a hairline crack. Is the oven still usable?
Hello ewaters56 - Honestly, I suggest contacting a professional to have the inner glass panel replaced and I do not recommend for the oven to be used.
Dec 12, 2012 | Frigidaire Gallery 30" Self-Cleaning...
Have a 6 - 7 year old Samsung RS2534WW from Best Buy. The back interior wall of the fridge is bulging forward/inward for quite some time now. We had to remove some shelving in order to be able to close...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 30, 2010 | Samsung RS2534 Side by Side Refrigerator
The White enamel/paint in the interior of the microwave, by the base & back wall seem has peeled off - about 2 inches. I see unpainted metal & I am concerned. How do you fix this problem and is it...
The area will first have to be sanded smooth and cleaned and dried thoroughly.
If the cavity metal of the oven is cracked or split, you can use a small amount of steel-based epoxy such as JB-WELD to patch the crack or hole.
Once that dries thoroughly, you can sand it very smooth.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
Aug 18, 2010 | Frigidaire Microwave Ovens
WHIRLPOOL SIDE BY SIDE fridge GD25DFXFW 10 YRS
Get your refrigerator repainted before it is too late. It isn't that costly. Cracks may be due to rusting. Ask those mechanics about it when you give it for painting.
Apr 21, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Interior thermal of refridgerator is cracked
If you are talking about the inner liner then you cannot change that. Seal it with silicone if it bothers you.
Sep 12, 2009 | Frigidaire FRS3R5EMB Side by Side...
Freezer workss but fridge dont
Check for a frost buildup on the interior back wall of the freezer. If you find this, a problem exists in the defrost circuit (heater, terminator or control).
Also verify that the evaporator (freezer) fan is functioning.
A failed damper control can cause this condition as well.
Proper product temps are 0 to 10 in the freezer and 36 to 42 in the fresh food compartment.
Apr 25, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Is there any way to fix a crack and a hole in the plastic interior wall of the CRV. Apparently, something I was transporting, like a bike pedal, punctured the side of the CRV's rear interior. The plastic...
You will need to get the panel plastic welded. You should be able to find someone to do this, should not be expensive or take lond, you can even leave panel with them so you can use your vehicle. Won't be perfect, you will only be able to tell if you look for repair, they can colour match really well.
Cheers
Apr 06, 2009 | 2002 Honda CR-V
The power works and the interior lights work but it wont get cold. It's a DEC fridge and it's about 2 years old
Hi Boatgc,
You say, the power works and the interior lights work but it wont get cold. It's a DEC fridge and it's about 2 years old.
Is the freezer also not cold?
If the fridge is not cold and the freexer is!!!
There are a couple things to sheck.
Let me know!
Huuum
Sep 21, 2008 | Refrigerators
Whirlpool fridge walls cracking inside
IF THE WALLS ARE CRACKING FROM POOR MANUFACTURING THAN YOU SHOULD RAISE HELL!!!How many times are consumers paying the repairs for poor quality ???Unless you have caused the cracks ,I do believe Whirlpool would see this was taken care of the honest way.WHAT WAS ONE OF MAYTAG'S UNIQUE QUALITYS THAT STOOD MILES ABOVE THE REST??????
answer: QUALITY CONTROL
Jun 09, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
348 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
