I am a student leaning IT work and I need to know what service error: 49.3C1A for a Hp LaserJet 4100n would be? This printer is being used in our schools library as a printer for 8 work stations.
SOURCE: 50.4 fuser error for hp
If unplugging the power cord for 30 minutes does not cure the problem, you have a bad fuser.
Look in the back of the printer for 2 blue levers.
Make sure the fuser is locked in.
SOURCE: 49 4C02 error
Well I was having the same problem. I cleaned out the queue by canceling the job that it was having the problem with. Turns out the data being sent to the printer was corrupt in this case.
SOURCE: Printer Pauses every few pages, seems to print slower than it shouls
I seriously doubt that this is a network spooler issue but I guess there is a possibility. I was thinking that there is a setting with the paper on the actual printer or something about waiting to start the job until all pages are in memory. I have the problem with a 4300 not a 4100
SOURCE: 50 .2 Fuser Error in
you need an maintenance kit 4100
ACC
C8057A
Maintenance
Kit, Fuser, 110V, LJ 4100
LJ 4100 Series
ACC
C8057-67901
Maintenance
LJ 4100 Series
ACC
C8058A
Maintenance
Kit, Fuser, 220V, LJ 4100
LJ 4100 Series
Selected Item
RG5-5069-000
See RG5-5069-090
Not Available
0
Alternate Item(s)
RG5-5069-090
Fuser Film ***'y, 220V, LJ 4100
180.50
http://www2.printerworks.com/cgi-win/tpwall.exe/find?RG5-5069-000
HP LJ 4100 Fuserkit RG5-5069 HP
SOURCE: Printer Hp Laserjet 3055 giving error message 5
If you scanner error 5 or printer hangs at scanner bulb warming up than the issue is with Scanning Assembly inside the printer and it is hardware issue.
