Question about IBM ThinkPad T22 2647 Notebook
IBM Thinkpad T22 Battery
I'm having trouble with the battery on the IBM thinkpad t22. For some reason it's not charging,eventhough the battery light is green and shows that it is fully charged. As a result as soon as the A/C adapter is disconnected it turns off. So it has to stay connected the whole time if not it shuts off.
I bought a second battery, charged it overnight, but I'm still having the same problem. The battery light is green, which means a fully charged battery, but it's not holding the charge. When i check the power source for the battery it reads that it is only 29%total battery power remaining. That's with the new battery and it connected to the A?C adapter.
Basically the batteries aren't charging. Could it be that both batteries are dead, even the new one? Or something else?
  • dat_chick215 Sep 29, 2008
    Treid this, but still not charging either battteries. Any other suggestions?
Did you try buyinga new battery? They only recharge so many times, you know,
Posted on Oct 31, 2008
    Problem Solver:
  • 24 Answers
Pls first check your adapter may be problem with your adapter.
thank you
Posted on Sep 28, 2008
Pyrhyc
  • 2028 Answers
SOURCE: IBM ThinkPad T22 Series (Type 2647)
Since this is an older machine, the performance can't be boosted very much. The maximum performance you can get from this machine is 1ghz processor, with 512mb RAM. The 1ghz processor is the biggest processor that is compatible, and unfortunately, the system is base on a 100mhz frequency rating, so PC100 memory is the only compatible memory available. The maximum chip size in PC100 is 256mb, they just don't make them any bigger, so 2x256mb=512mb RAM. As far as the hard drive, it is an IDE drive, and you can get an IDE drive up to 120gb. These are very good and durable machines, just slow, so if you can deal with the lower level of performance, this machine will last years. Also, these are upgradeable to XP pro, but not Vista.
Posted on Sep 04, 2008
  • 70 Answers
SOURCE: How can I boot from USB in a Thinkpad T22?
you should enable legacy USB support from BIOS
Posted on Jan 30, 2009
gnkanang
  • 63 Answers
SOURCE: ibm t22 thinkpad laptop error 0175 crc1
Ok hm...
Sounds expensive, I'm afraid!
Here is IBM'smag-glass_10x10.gif explanation of the error codes.
What your machine is telling you is that a chip on your Motherboard is faulty and the only way to repair it is a new system board.
It is probably worth finding out how much IBM would charge you to repair it but I very much doubt you'd get much change from £500.
Posted on Mar 25, 2009
Geekman
  • 32281 Answers
SOURCE: My IBM Thinkpad T22's battery doesnt last. can i fix that?
Basically you need a new battery. Recharageable batteries have a finite number of charge and discharge cycles and they lose their full charge capacity as the get older. The batteries will have less capacity over time ie less available battery time, and when it is worn out, it won't charge at all.
Posted on May 15, 2009
SOURCE: Is IBM Thinkpad T22 equipped with WIFI & what's the USB port vers
IBM Thinkpad T22 doesn't have Wi-Fi adapter installed. you need a USB Wi-Fi adpater in other to have Wireless connection.
You can go for D-Link, 3COM,belkin USB Wi-Fi adapter. Make sure the USB Wi-Fi adapter support the Operating System you installed.
Good Luck.
Posted on Jan 08, 2010
I was given ThinkPad 2647 T22 and it has been in it's case for 1 year. I plugged it into the AC adaptor and the green indicator light came on that the battery was charged after 5 hours. When I pushed the...
Remove the battery and try to power on without it. Replace the battery if the computer powers on. If not, the motherboard have to be repaired/replaced.
Aug 15, 2010 | IBM ThinkPad T22 2647 Notebook
Good Luck.
Jan 08, 2010 | IBM ThinkPad T22 2647 Notebook
Can't power up. my IBM ThinkPad T22. I have the green light that indicates that it's charged up, however when I push the power button it just makes a flash and nothing happens.
If you only get a green light, try removing the battery first. If a laptop battery has gone bad, it will prevent a laptop from booting up.
Now, if removing the battery doesn't resolve your problem, check the laptop charger to make sure that the adapter has not malfunctioned.
If your fans are spinning, then the problem is probably the one listed below.
The transformer may not be converting the voltages properly.
Try these steps first. If it comes down to the internal transformer, then you have to contact IBM.
Aug 09, 2009 | IBM ThinkPad T22 2647 Notebook
Can barley see screen on t22 thinkpad
It might be that the power supply, battery, or backlight. Try pulling the battery out using just the power supply. If you have another power supply try that also.
Jun 25, 2009 | IBM ThinkPad T22 2647 Notebook
May 15, 2009 | IBM ThinkPad T22 2647 Notebook
Ibm t22 thinkpad laptop error 0175 crc1
Ok hm...
Mar 25, 2009 | IBM ThinkPad T22 Laptop
Getting hot underneth
Both batteries could be dead. But if you bought a new battery, it's unlikely. I don't know what green light you see, but if it's on the power adapter, it just means it's turned on--not that it is charging.
Two possibilities: Your power adapter is bad or the motherboard is bad. Because you say the computer works if plugged in, then you have ruled out the adapter.
You should be checking/cleaning the battery contacts and if all else fails, going for a new motherboard.
Jan 16, 2009 | IBM ThinkPad T22 2647 Notebook
IBM T22 Battery won't charge & is not detected
Take it to a very good technician who will open it up and check a dry joint in the charging system.  Sometimes if you donot attend to it quickly you may find your T22 refusing to power at all with the AC Adaptor.  Delicate soldering may solve your problem.  Power may not be getting to the charging circuit and the battery thus it is totaly discharged.
Oct 24, 2007 | IBM ThinkPad T22 2647 Notebook
IBM ThinkPad T22 2647 Notebook Logo
218 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
