My Asko D1996 dishwasher will not drain. I checked the drain hose and it is not clogged. I need to replace the drain filter but cannot see how to remove the old one. Can someone tell me how to remove the old drain pump. ThanksMy Asko D1996 dishwasher will not drain. I checked the drain hose and it is not clogged. I need to replace the drain filter but cannot see how to remove the old one. Can someone tell me how to remove the old drain pump. Thanks
You can't post conmments that contain an email address.
i have nearly the same problem ! but my one have no water left in it !but pump still running if i put bucket of water in it will drain it away but no lights on panel and anyone know what that is please ?
If you cannot get the diswasher to drain there is some obstruction in the drain line going to the disposal. First turn the power off to the diswasher at the breaker panel then open doors under sink and follow drain line to the disposal there you will find a hose clamp(silver) that you must loosten with a flat blade screw driver ( get a bucket under the disposal) pull the drain line loose and dump out excess water and debris inspect area going into the disosal to make shure it is not clogged up
reverse your proceedure and reconnect the drain
Before trying the dishwasher take some ice cubes and run thewater then put in disposal and turn on that should clean the disposal
try your dishwasher I forgot to mention that theri is a strainer at the bottom of you dishwasher that you can remove to be sure it is not clogged up I assume that you have aready checked that
My Whirlpool Diswasher did not drain water. The same water has been recycling from washing thru rinsing and sitting there after done.
Model: S62NXPLP-7624
indicates that the water solenoid diaphragm has failed and not shutting of the water supply
get a new one from the service agent or have a technician come , diagnose and replace the faulty item
