Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Airflow blocked tv will shut down after a few seconds
Greetings: I saw that you addressed this issue before by suggesting checking the lamp thermal sensor. I am having the same problem... the fan under the runs, there are no blockages of the air flow, I have unplugged and plugged back in (ensuring the connection was solid) How can I test the thermal sensor? I am assuming that it is a bit more complex than a simple normally closed switch.
Any assistance would be welcomed.
Thanks,
Brian
  • Anonymous Oct 28, 2008
    this TV is ********. Nithing but trouble.
  • sandsierra Mar 11, 2009
    this doesn't happen all the time but at least 5 times a month we turn our tv on and a message come up saying tv will shut down air flow blocked.  how can i fix this
  • 927 Answers
Good Day;
If you have a WD-52525 Model TV and the the screen displays "air flow problem" change the sensor. There's not a positive way to check device, just replace it, trust me. IF your TV is a different Model MIT'S has a recall on those certain Models. REPLACE.
Good Luck, big IRISH.
Posted on Sep 28, 2008
My tv monitor says "TV
YOU NEED TO REPLACE THE THERMOSTAT ON YOUR SET TO CORRECT THIS ISSUE .
Dec 14, 2010 | Mitsubishi WD-57732 Projection Television
Have a Mitsubishi 52725 52" DLP The TV shuts off frequently. It tells you "the TV with shut off in 30 seconds". It seems warm but I have a fan in the rear to cool it down but sometimes it still...
does it give you the "airflow" message?
if so it needs a new thermal sensor by the lamp, known issue defective sensor..
if not, suspect bad capacitors
there are many bad caps across 3 board , all part of the chassis.
a repair center will ship the chassis into mits for rebuild, about 400 or 500 total bill
May 21, 2010 | Mitsubishi WD-52725 52". Rear Projection...
Have a mitsu wd-52631 - get message "tv will shut down in a few seconds - chk for air flow blockage" then shuts down - wil turn on after sit for several hours. No blockage evident.
Well....the reason you are getting an "airflow message" is that there is a thermal sensor on the BACK of the lamp cage, and the connections on it get to be "intermittent" after awhile...and when this happens...the computer thinks that the lamp is overheating due to a dirty filter or fan--and shuts down the set.
It is a small, white plastic sensor, with 2 wires on it, that go to a connector and it has a black and red wire(usually) in a twisted pair that connects to the sensor connector. The connectors need to be REMOVED and the sensor HARD-WIRED (directly connected to) the other pair of wires. IF you have done some electrical work before...this is easy. You only need about 3" of spare wire to patch in between the sensor and the other connector, after you cut the connectors off. BUT...if you do NOT have repair experience...I suggest you call a COMPETENT, FAIR tv shop in your area, if you do not have a service plan...and tell them you have a mits. set that needs the "airflow sensor problem" repaired . this CAN be done -in-home, in about an hour or less, and for under 300, including service call.
Oct 12, 2009 | Mitsubishi WD-65731 65" HDTV
Temp light flashes tried unplugging it for a few minutes turned it on tries to power up but then power , lamp , temp lights flash for a few seconds then it shuts down and temp light stays on
It sounds like you have a thermal issue. The TV is getting too hot or the Thermal Fuse is bad. The thermal fuse detects the temperature in the TV and tells the TV to shut down if it thinks it is too hot. Most likely caused by poor ventilation or clogged fans from household dust. Try moving TV away from wall or cabinet first, if this does not fix the problem, clean ALL the fans in the TV. If problem still persists, replace the thermal fuse.
Oct 04, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
What causes my mitsubishi WD-Y65 tv to keep saying: The tv will shut down in a few seconds. Check airflow.
thermal sensor problem.... there is a service bulliteen to service shops about this.. this generally a warranty item that is covered.... you will have to get a tech to see if its covered. the thermal sensor needs replaces.not to difficult to replaced
Apr 04, 2009 | Mitsubishi Televison & Video
Error message
Good Day, drdeath57;
Make sure your air vents are clean but more than likely you should suspect the TV's Lamp Thermal Sensor
Aug 21, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Shut Down Message
The repair is to have the DLP engine replaced!!
FYI: The engine also can cause the set to shut down without any display or might even tell you the lamp door is open when it is not.
Feb 01, 2008 | Mitsubishi WD-52628 52" Projection HDTV
Mitsubishi wd 52525 dlp shuts down
mitsubish has issued a service bullietin about the problem. which means ussally they will pay for its repair. the reson it says airflow bock is that there is a temperture sensor that is at fault... it needs replaced.
Dec 13, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Error Message
. Set shuts off after displaying the message "TV will shut down in a few seconds. Please check if the air flow is blocked." After shutdown, it may have a yellow status LED, self diagnostics indicates error code 38. To repair, replace the Lamp Thermal Sensor with the new version, part # 299P313010A. The sensor is located on the Lamp Cartridge Housing. See Service Tip VS-72B. Under rare circumstances, when a replacement thermal sensor is not available, refer to the original Service Tip, VS-72 (page 2 and 3 of VS-72B) If error 3-4 then this maybe problem:. Check to see if the lamp is on when the unit is off (in standby) if it is components on the Power PWB... K9A20 and/or K9A21 are shorted. Also, R9A02 may be open. Possible side effects ... deformed lamp exhaust duct and damaged lamp. Replace PWB-POWER part # 934C228003 and if necessary, Lamp part # 915P049010, Lamp Exhaust Duct part # 642B155010, and/or Lamp Exhaust Duct Cover part # 642B156010. See Service Tip VS-73 2. If the lamp never lights suspect the Lamp part # 915P049010
Aug 22, 2007 | Mitsubishi WD-57732 Projection Television
Mitsubishi dlp tv model number wd57732 purchased 2-20-2007
i had the same problem on 10/24/07 and i called a Mitsubishi warranty company near me and they came out and replaced the Sensor part # 1299P313010A. No problem since
Jul 30, 2007 | Mitsubishi WD-57732 Projection Television
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
821 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
