Question about Microwave Ovens
My sharp microwave r- 490f runs normally but does not heat Ajay
  • William Miller
    William Miller May 11, 2010
    When you hit Start to cook, do the inside light and turntable come on?
    Any unusual noises? Is it louder or quieter than usual?
    These answers will help me judge whether it's in the high voltage
    section (magnetron, transformer, or diode) or the control section
    (door switch or control board relay or connection).
I was using the 5000 scanner on a MAC G5 Pro work fine, but now There is no upgrade for newer Mac Imac what to do?
Posted on Jan 01, 2013
It's your MAGNATRON, the thing that heats the food. mine did the same thing, luckily it was still under warranty. Good luck
Posted on Oct 31, 2008
Sharp r410 microwave runs but wont heat
If it sounds like it normally does, then you probably have a failure of some component in the high voltage circuit, or whatever element controls it, or the thermal protector on the magnetron.
If troubleshooting this yourself, be aware that the high voltage capacitor can retain a charge of several thousand volts indefinitely. Very unpleasant to touch.
May 13, 2016 | Sharp R-410LW Carousel 1-2/5-Cubic-Foot...
Sharp - Food not heating up but all is lit up and turn table turns
Hai my friend, if its not heating you must open it at the back and check your fuse on top for contuinity using amultimeter it must be on abuzzer and if its fine there is other fuse covered with normal black cover connected to the cspacitor also check it, if this two fuses are fine check your capacitor if its fine check your magnetron for contunuity of 0,2 ohms but normal if its not heating its fuse, thx
Sep 13, 2014 | Sharp R959SLMA 900 Watts Convection /...
Sharp r2103j microwave lights on doenst heat up
No heat, but unit seems to run normally in all other ways - possible causes: failure of high voltage rectifier, shorted high voltage capacitor, magnetron failure, power transformer open/shorted winding(s), thermal protector open, or no 120 v supplied to power transformer.
May 04, 2014 | Sharp R310J 1200 Watts Microwave Oven
Sharp R-930CS microwave turntable stopped turning and neither convection or microwave are working (ie. not heating). Lights and fan turn on and counter counts down normally.
Look inside for one of many thermal cutouts (button type) test each for continuity (with the unit unplugged of course). Also look for burned wires and repair or replace them. If you get it running and it works fine... we're done. If it still acts up then replace the magnetron and or the capacitor.
Oct 19, 2013 | Sharp Microwave Ovens
Sharp r-610dk microwave runs but don't heat up
The magnetron has failed, or the inverter board, "if 7 years old or less" there is also a possibility the keypad control board may be the problem.
Apr 21, 2012 | Sharp Microwave Oven Microwave Oven
Sharp modelR1381 everything works but will notheat
If it runs and makes normal noise but just no heat, issues is either a loose connector to magnetron or at diode to capacitor. Be careful with capacitor because it stores thousands of volts.
Nov 21, 2009 | Sharp Microwave Ovens
Fan runs when door is closed - no heat
This is normally 1 of the interlock door micro-switches not working.
Jun 20, 2007 | Sharp R-1490 Microwave Oven
Microwave Ovens Logo
65 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
