Question about HP PSC 1610v All-in-One Printer
WON'T TAKE PAPER; SAYS OUT OF PAPER,
IT WON'T TAKE PAPER; SCREEN SAYS OUT OF PAPER; HAVE TRIED WITH ONE SHEET OR SEVERAL TRYING TO GET IT TO ADVANCE; STILL WON'T - HELP PLEASE
  • Anonymous Oct 17, 2008
    I have the same problem with same printer
I had that problem and I feathered my paper in a "stairstep" instead of putting the paper in all flush and it solved my problem. I can print continuously without getting the "out of paper" error message now.
Posted on Oct 19, 2008
My praftically brand new Canon Pixma MP620 printer grabs more than one sheet of photo paper and stops printing picture on first sheet then garbles several pictures on a portion of the next sheet. I just...
check the printer's printing preferences on properties option.should be set to normal then check the printer rollers if its dirty where the papers pass thru, if the problem persists load only 1 paper every time you print for the printer not to grab more papers.i think it is in the feeder and the sensor maybe its dirty need to be cleaned up.
Feb 22, 2010 | Office Equipment & Supplies
It grabs several sheets of paper at one time
This is most likely a paper problem, the paper is basically sticking to the next sheet, Ensure the paper is stored in a cool dry place helps, dont load the paper with more than what you need for a couple of days and when loading the paper flick the pages to allow air between the pages
If this dosnt work try a different brand of paper
Sep 09, 2009 | Lexmark Optra E310 Laser Printer
Miss feeds when print multilpe pages
The paper feed solenoid is sticking, it can be seen thru a hole in the back with the door opened. Not easy to get to, but I have been able to bend the stop tab slightly and run just fine.
Sep 02, 2009 | Konica Minolta magicolor 2300DL Laser...
Keeps flashing back door open.
Got to be a little micro switch or sensor the is damaged or has gummy paper over it Have a good hard look
Apr 22, 2009 | Brother DCP-7020 All-In-One Laser Printer
Problem Printing Sheet Paper with the Epson 9800
On the machines control panel set to sheet fed (pressing the left button will change from Sheet, roll and roll with cut). In the print settings select your paper profile. On the page setup choose sheet. In the pull down menu you should only have basic paper sizes, no custom size. choose 20x30 and try again.
let me know if this helps
Feb 02, 2009 | Epson Stylus Pro 9800 InkJet Printer
There's a pencil stuck in my Lexmark x5450
hmmm... try lifting up on the scanner part to open, like you are going to change the ink cart. might have worked its way in there thats about the only reasonable entry point i can think of. and please try not to shake it more than you have to. they dont like that :)
Dec 25, 2008 | Lexmark Z735 InkJet Printer
Won't feed paper while printing
I just obtained a printer with the same problem. When I opened it up I discovered a plastic gear that had cracked and was not turning the main paper roller as it was slipping. It looks like the solution is to replace the roller if you can find one or to repair the gear and epoxy back onto the roller. I am trying the later.
Apr 22, 2008 | Lexmark X83 All-In-One InkJet Printer
My brother laser printer HL-5050's paper light is flashing, which usually indicates a paper jam. i've checked 5 times and there is no paper jam. have shut off printer and restarted 3x. when i try to print,...
Hi
I've nearly the same problem....My printer(HL5050)  takes only a little bit of the sheet, then paper led flashes.
I've found a block into the paper feeder. This printer is impossible to disassemble.!!...even if I've the service manual, because for taking away a simple pressed paper block , it's necessary disassembling  almost all the machine!!! No comment
So I'd an idea:
I've sprayed into the paper feeder a great quantity of a cleaning spray (without oil) , in order to get the paper block wet, then , by means a school-book plastic cover, used like a paper sheet,  and  manually acting on the gear, I've pulled this plastic sheet up and down several time (spraying in the same time)in order to  remove these hard paper blocks. Now my feeder seems free. Tomorrow I'll try to test it.....
Regards
PS To do this it's necessary the only removal of left cover, in order to reach the gear which allows the paper to advance manually.
Apr 21, 2008 | Office Equipment & Supplies
Printer won't advance next piece of paper
You can get a repair kit for this off ebay.
Your paper feed roller and lifter are worn.
Jan 30, 2008 | HP LaserJet 1012 Printer
HP PSC 1610v All-in-One Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
