Question about Kodak Easyshare M753 Digital Camera
Charging camera i plug my camera into the usb port in my computer but how do i know if its charging right because theres no light flashing and i cant turn it on after its been plugged for a while
  • apowell813 Sep 28, 2008
    no connection
  • roostereagle
    roostereagle Oct 14, 2012
    a little piece came out of the charging port on my camera. Now there is no connection being made from the charger to the camera. Can this be fixed?
Are you using the front usb ports on your computer? My computer's front usb ports were not able to charge my camera, but the rear usb ports were able to (the charging light should stay on if it's charging correctly). I'm not an expert on this stuff, so maybe there's a power output difference between your frontal and rear usb ports.
Also, on the CD there was a camera connection driver. You might try installing that and see if that makes a difference?
Posted on Oct 09, 2008
2 Suggested Answers
  • 102366 Answers
SOURCE: Can the USB Cord charge
No and no. The camera does not contain charging circuitry. You need to use the supplied charger.
Posted on Jun 17, 2011
Im trying to charge my camera via computer. . there is a red light on the charge cable connector and a green light on the camera which i have switched "on". it still says "low battery even...
Hi, I'd suggest using a wall charger as they're able to provide more power to charge then a computers USB port. Often with camera's the USB port doesn't supply enough power so the camera doesn't charge at all.
Aug 18, 2011 | Samsung SL102 Digital Camera
I have just bourght a vivitar vivicam 8025 digital camera it cam with 2 plugs i put the battery in and memery card and it works i know one end is the usb i know it either plugs in the computor but the...
The USB socket is toward the bottom on the left end of the camera (as you view it from the rear). Take a look at the illustrations on page 5 of the manual.
You can charge the battery either outside the camera using the supplied charger or inside the camera by connecting the camera via USB to a powered port. Be aware that not all computer USB ports put out enough current to charge batteries.
Nov 05, 2010 | Vivitar ViviCam 8025 Digital Camera
I'm having a hard time getting my Flip HD to charge. It is brand new and this is the first time I've had to charge it. Sometimes the red light is on and steady and other times the red light is flashing. ...
I had this charging problem with 2 new Flip Ultra HD cameras...red light flashing..nothing on the screen after plugging in the USB port.
I removed the battery..plugged camera into USB port..pc recognized the camera... installed flipshare software..updated software...plugged battery back in..all good.
Why on earth the book doesn't mention these steps is beyond me.
Oct 11, 2010 | Pure Digital Flip Video Ultra Camcorder
I have the Insignia HD camcorder, this is the second one I have and the second time I have this problem. The first couple of times it charges, then I don't use it for a couple of months, try to charge it...
Have you tried using an AC to USB charger?
I know that some products that charge through a USB port are not able to completely and correctly charge from the computers USB port because it is undervolted for what the device needs. (I have the same issue with my cell phone).
Also, may of a computers USB ports will power enough for data transfer, but not enough for charging the unit.
Try using an AC to USB power supply and not the computers USB ports.
Hope this works!
Apr 07, 2010 | Insignia NS-DCC5HB09 High Definition Flash...
How do I charge the battery?
You can actually charge this camera right from your computer's USB port. Use the small, rectangular hole and plug the small end of the USB cord into that and the other end into the USB port in your computer or laptoip. The green charging light should come on but the computer won't recognize new hardware since you don't need to turn the camera on. In fact, it will charge faster if you leave it off, so you can just leave that plugged in for a few hours and go about your business.
Hope that helps. Good luck. :)
Jan 11, 2010 | Kodak Easyshare M753 Slim Digital Camera
My computer do not recognized my Sandisk Cruzer Micro 1.0 GB.
I had the same exact problem on my 8G card. It worked fine in the camera, but when I plugged it into the card reader it flashed once and then the light went off. So, I put the card back in the camera and ran a USB cable from my camera (there was a port on the side of my Cannon Powershot that was smaller than a USB, but I don't know what to call it) to my computer. When I turned the camera power on, the computer was able to read the 8G card while it was inside the camera. I downloaded everything to my computer at that point. Hope this helps! I got the chord from my external hard drive and that fit from the camera to the computer.
Jun 09, 2009 | SanDisk ULTRA II 4GB Compact Flash Card...
Will Not charge
It happens, one of the cell in the battery went bad.
Try new battery.
Mar 19, 2009 | Kodak Easyshare M893 Digital Camera
LG Secret charging
Dr Know, doesn't know what he's talking about. I have a LG KF750 and have experienced the same problem.
Solution - Really jam the cable into the socket! The connection is pretty rubbish. The phone charging icon will (with some force and wiggling) appear on screen. Then carefully put it down and don't touch it!
USB charges very slowly, if charging from a dead flat battery it may take a good 20mins of charging to boot up.
P.S. the red camera light is not supposed to come on when charging. Keep wiggling the cable and the light will go off when the phone charging icon appears.
Dec 16, 2008 | LG Secret ? KF750 Cellular Phone
Kodak easyshare m853 digital camera
is the light that's coming on green or red?
if it's red, there's a charging error - contact kodak, they may provide a 5v ac adapter to resolve your charging issue
if it's green, was it blinking or solid? is the battery drained?
if the battery still has a little charge on it, please connect it to the computer then turn it on, check if there's power light
check if the screen is black - that means it's making a connection and the charging is the only issue - computer not detecting it, maybe resolved by kodak's software support
if the camera screen is active - that means there's definitely something wrong with the camera
arrange repairs with kodak, include the battery and usb cable
please visit
www.kodak.com/go/itg - troubleshooting and repair
www.kodak.com/go/usbcharging
Feb 13, 2008 | Kodak EasyShare M853 Digital Camera
Not charging
does the charging light come on. if it does the battery is charging is it plugged into a usb hub if so the camera will not charge. it has to be connect to the computers usb port directly.also some computers have a built in usb hub witch cause this to happen. try using the usb plugs in the back they are diffrent addresses. also check you cable for any damage. I thing about USB is they are touchy pains. I had to fully reload my computer twice because of a USB problem best thing to do is get a seperate charger for your battery and a memory card reader to transfer your pictures.
Jan 11, 2008 | Kodak Easyshare M753 Digital Camera
Kodak Easyshare M753 Digital Camera Logo
172 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
