Question about Apple iPod MA446LL/A MP3 Player
Ipod 30GB Video FROZEN
It works on my computer but after i eject it stays on the menu sceen and NO button's work at all so i can't reset it and when you turn the hold button off the screen lights up but the BUTTON'S DO NOT WORK!!!
help please!
-thanks
  • rjhai Oct 03, 2008
    my ipod video just hanged while im playing songs.. no button works and even when i connect it to the pc, the pc wont read the ipod..
I found the solution already.. the first one you said was right.. you can try to wait till the battery runs out.. but the faster solution is just pressing and holding the center button and the 'play' button.. after a few seconds the ipod will restart..
Posted on Nov 27, 2008
  • 21 Answers
You can try an ywait till it runs out of battery or you can try and reformat it in itunes.
Hope this helps and good luck!
Jaxon
Posted on Nov 23, 2008
My iPod classic (30GB) keeps showing "do not
Try holding down the menu/center button for at least 10-15 seconds, if that does not reset it try the center button and play/pause combo for the same time period (I used to have the same model as you, one of these 2 combos usually worked).
You can also try connecting your ipod to another computer with iTunes on it to see if its a software or hardware problem with your iPod. Or you can uninstall/reinstall iTunes and see what happens after a fresh install
and yea you can let the battery run out overnight if you want, but if you do get to fix it I'd say back up your music on the iPod through a program like iDump or something in the meantime
Mar 08, 2011 | Apple iPod classic MP3 Player
Failed to eject before rebooting computer, now USB port says it doesnt recognize the ipod and my ipod is frozen on "Connected-eject before disconnecting"
Actually this issue shouldn't really be that difficult to resolve. :) A simple reset should take care of it being frozen on the connected screen. Below I have posted a step by step on resetting an iPod.
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
As soon as you see the apple icon appear disconnect the iPod from your computer. After the iPod completely loads. reconnect it to make sure it is connecting and loading correctly. If this does not resolve your issue for any reason please do let me know. I have a few other options we could attempt. :) and the feed back is always good. It lets me know if I am actually helping people with they're issue's or not.
May 16, 2009 | Apple iPod nano
Frozen ipod
Hey i scored you these instructions on how to reset your frozen ipod. Hope its hella useful. Good luck :)
Last Modified: January 28, 2009 Article: HT1320 Old Article: 61705 Summary Learn how to reset or restart iPod following a freeze.
Important: If your iPod is frozen or won't turn on, it may be because iPod is paused or the Hold switch is in the locked position. If so, a lock symbol appears on the screen. Slide the Hold switch to the unlocked position and check the screen.
If the iPod is connected to a computer and displays any of the following messages you should eject the iPod from within iTunes instead of resetting it:
Connected. Eject before disconnecting Sync in Progress. Please wait... Do not disconnect If your iPod is frozen or won't turn on, the steps to reset it vary by model. You can easily tell which iPod model you have if you're not sure.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button.
When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time are preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on.
Apr 23, 2009 | Apple iPod MA446LL/A MP3 Player
Frozen screen
First, make sure the lock slider is in the proper position.  I know, obvious, but you'd be surprised how often this happens.
Next, slide the lock slider to locked and then back.  Then press and hold the Menu and Select (center) button for 6-8 seconds.  Try a couple times if it doesn't work the first time.  The ipod should reset and work.
If that didn't work, you can reset your ipod.  But first, try connecting the ipod to your computer and see if it goes into sync mode. If so, wait for iTunes to load and then eject your ipod in iTunes and see if it works again.
To reset your ipod, slide the lock slider to locked and then back.  Next hold the Play/Pause Button and the Menu button for 6-8 seconds.  You may have to try this a couple times.  The ipod should reset.
The last thing to do is to let your ipod discharge completely by leaving it at the frozen screen.  Once your ipod is out of battery, reconnect it to you computer or a power adapter and let it charge.  Then try to access it again or repeat the steps above.
Nick
Jan 22, 2009 | Apple iPod nano
Frozen nothing works!!!
Press the Menu Button and the Center button until the apple appears and it will reboot
Dec 25, 2008 | Apple iPod Photo MP3 Player
Ipod 30gb video black
Try a reset
To reset your iPod:
  • 1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  • 2. Press and hold the Menu and Select buttons until the Apple logo appears, about 6 to 10 seconds. You may need to repeat this step.
Tip:
  • If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
  • If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
May 15, 2008 | Apple iPod MA446LL/A MP3 Player
My Ipod is frozen
OK what you need to do is reset it. To do this you will need to hold down the menu and select buttons simultaneously for approx 6 seconds until the apple logo appears on the screen. This should reset and un freeze your ipod.
Try this and let me know how you get on.
May 12, 2008 | Apple Mini IPod
My 30gb ipod is frozen
have you tryed the five rs?
sounds like a hardware problem, I would contact apple, or your dealer, or a local professional for repairs.
Apr 05, 2008 | Apple iPod MA446LL/A MP3 Player
Apple iPod Model A1136, 30 GB.
First make sure your hold switch isn't on. It's on the top or bottom and slides back and forth. It needs to be switched to the left. Once it is to the left, here's how you reset:
You can reset your ipod by holding down the menu and select (round button in the center) buttons down for at least 10 seconds. You'll see an apple logo flash, that's when you stop pressing the buttons. It will shut off, then back on.
Feb 14, 2008 | Apple iPod MA446LL/A MP3 Player
My Ipod is frozen
hi there did you try to reset the iPod by holding the MENU and center button?
to do that first lock the itune then press and Hold MENU and Center Button by 7sec. then apple loge appears means the ipod had been reset. ok!
peace!
Dec 15, 2007 | Apple iPod MA446LL/A MP3 Player
Apple iPod MA446LL/A MP3 Player Logo
55 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
