Question about Car Audio & Video
Uniden vs1100xr car alarm will not arm or disarm,have found valet mode button which sets & resets ok but remote just flashes led no chirps or lights flashing
I had the same problem with my vs1100xr. The remotes for these (and other) unidens have a rolling code. Seems to me that either the remote runs out of new codes and cycles back to the beginning, or the alarm base unit somehow loses track of the codes. Either way, the alarm base unit stops accepting the codes of your remote, and so needs to be purged of its code tracking memory - reset, if you like. This is essentially the procedure for training the alarm base unit to recognise new remote (and forgetting old remotes).
This procedure is:-
1) Disarm alarm, or if in valet mode, take it out of valet mode (push valet button 3 times)
2) Turn the ignition on and off 2 times within 15 seconds.
3) Put the alarm into valet mode (push valet button 3 times) within 15 seconds of completing step 2. Alarm should beep, and remote training has started.
4) Within 15 seconds of completing step 3, push the button (#1) of the first remote you wish to use for the alarm. Alarm should beep, indicating acceptance of remote. Repeat for other remotes you wish to use - up to 4 in total. (Once the first remote has been accepted, you have all the time in the world to make the alarm learn other remotes)
5) Turn ignition on and off to end remote learning mode. Alarm should beep 2 times. New remotes have now been learned and previous remotes forgotten.
Some of these details may vary from country to country - who knows. If this doesn't work, I suggest that you contact Uniden in your country to obtain the procedure. Took me a few tries to get the timing right, what with the valet button hard to get at and having only 15 seconds between steps.
Posted on Apr 18, 2009
Just adding to gem001's perfect answer above there are a few little steps that you must ensure you are doing otherwise nothing works.
FIRSTLY. Locate your valet alarm button. This is usually somewhere underneath the fuse box near to where the bonnet release is. To acess mine I had to remove the plastic covering that hides all the ignition wires. You will likely see the alarms "brain" or control with a whole bunch of wires. Ignore these. To the right of this up against the cars panelling will be a small push button. It will be difficult to locate but once you spot it, you will think its obvious. Mine is sort of about shin height.
SECONDLY. now you have the valet button begin gem001's instructions. HOWEVER step number 1. ensure the keys are in the ignition and the car is turned to ON before pressing the valet button 3 times.
If the ignition is not on the on position you cannot enter or exit valet mode.
Alternatively if you are stuck somewhere and it is embarrassing that you have just been standing next to an car with its alarm going off for 30 minutes. Enter valet mode (ignition on, press button 3 times within 15 seconds ), and then turn your car on and drive it home. Your alarm is effectively off until you take it out of valet mode. Use your key to lock the vehicle etc until you have time to retrain your remote alarm sensor as detailed above.
Posted on Mar 19, 2013
How to reprogram excalibur omega147 remote
Try this :
Programming the Transmitter
To program a transmitter, turn on the car's ignition and then press the valet switch five times to initiate programming mode. With this step there is typically a brief siren sound accompanied with a red indicator light. Press the transmitter button to shuffle between different modes and functions. To change a particular feature, use the disarm/unlock button or the arm/lock button. Pressing the disarm/unlock button turns the selected feature off, while pressing the arm/lock button turns it on. The action comes with either one or two chirps - one for a confirmation and two for a deactivation.
To switch from one security feature to the next, press and release the valet switch number until it corresponds with the identified feature. For instance, tap the valet switch three times to access the third listed feature. The switch chirps and the indicator light flashes the same number of times as the selected feature (in this example, three times).
Some of the programmable features include setting the type of light output (steady or flashing), alarm cycle, and bypass function. To exit from the programming mode, turn on the ignition and wait 10 seconds. The Excalibur alarm system automatically switches off after 10 seconds of inactivity.
Most Excalibur alarm systems come with a controller that allows for easy remote use within a specific range (decided by the particular model). To lock the door of the car, press and release the arm/lock button. Pressing and holding the lock button activates the remote panic option with systems that offer this feature. To release or deactivate any of the security features, hold the unlock button to deactivate remote panic and unlock the doors or press and release to simply deactivate the doors.
or this :
http://www.carid.com/images/omega-security/security-systems/pdf/rs350edpb-operation-guide.pdf
Jun 23, 2016 | Vehicle Parts & Accessories
Viper 5701 led light does not flash when armed, stays lit when alarm is disarmed
If the LED is on solid then the alarm is in valet. To exit valet, press "F" twice then press unlock on the remote. The LED should turn off.
OR,
enter the vehicle, turn the ignition on then off, press and release the valet/programming button on the antenna. LED should turn off
Jan 30, 2013 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
What is the valet button located inside of glove compartment used for
It is used for programing the alarm, it is used to disarm the alarm without the remote, [in case remote is damaged] and it is used to put alarm system into valet mode, [service mode] valet mode is only really needed if the alarm has been programed for passive arming, [alarm arms itself].
Your main use for the valet switch, [if programed for active arming instead of passive arming] is to have a way to disarm the alarm if the remote does not work.
Apr 22, 2012 | 1997 Cadillac DeVille
I have a 2005 Honda Odyssey Touring. I bought it used last year, so I am not too familiar with the car alarm in it. The alarm was fine until my battery died a few months ago. After the car was jumped, the...
Ok, try this.
Put the key in the ignition, and turn forward
all the way just before cranking. Then within
5 seconds, locate, press and hold in the
valet/overide button, found under the
dash area, (push button, spring loaded)
until the installed LED (the blinking light)
in your dash area goes on solid,
and the siren chirps once.
(Your valet switch might be the toggle
(on/off) type. in this case, key on,
flip switch in opposite direction,
then turn the key off.)
This should reset the alarm, and reset
the grounded relay on the starter wire,
allowing you to start the engine.
At this point, the only thing working would
be the keyless entry from the alarm,
if it came equipped that way.
Just Repeat these steps to place it
back to usable armed mode.
You may get 2 chirps, confirming it,
and the lights may flash twice as well.
Dec 21, 2010 | Honda Vehicle Parts & Accessories
I have had my Viper system for some years now with never a problem, that is until yesterday. Now when I arm or disarm my system the horn does not chirp and the small red dash light stays solid red instead...
Your alarm is is in valet. to take the alarm out of valet with the remote: open any door. Press lock, unlock, lock. The LED should be off now. Close the door and lock the doors with remote. The alarm should chirp to confirm that it is armed.
OR
Turn the key on then off. Within ten seconds press and release the valet switch. The LED should be off now. Close the door and lock the vehicle with the remote. The alarm should chirp to confirm that it is armed.
Nov 26, 2010 | Remote Start System
How to disable or reset a Prestige car alarm. Purchased a used car with an after market Prestige alarm installed. Alarm somehow tripped and shut off the ability to start the car. I can't find a valet...
The valet switch,on the newer Prestige alarms, is a push button LED or, it's incorporated into the antenna. In both cases, turn the key to the on position, then press and release the valet switch. The alarm will respond with two chirps confirming that it is disarmed. You may now start the vehicle. After you successfully disarmed the alarm, turn the key to on position, press and hold the valet switch for approximately 5 seconds, the LED will come on solid. Turn the key off.The alarm is now in valet. You can take it out of valet in the same manner.
Oct 28, 2010 | Audiovox Prestige Code Alarm Remote Alarm...
I have a viper alarm on my car that wont shut off nor i cant start the car..and i have tried the button under my dash, how Can i shut it off??
was it a professional or shade tree install? the following is off vipers website:
disarming without a remote control
This feature allows you to disarm the security system without the
Remote Control should it be lost, damaged, or disabled. In order to
disarm the system without a remote remote control, you must have
the vehicle’s ignition key and know where the Valet button is
located. Be sure to check with the installer for the location and the
number of presses of the Valet button required to disarm the system.
To disarm the security system,
turn the ignition to the ON position.
Press the Valet button the
preset number of times (one to
five times) within 15 seconds. After five seconds the system will
disarm. If the system does not disarm, you may have waited too long;
turn the ignition off and on and try again.
if that doesn't work try this other
valet mode
You can prevent your security system from automatically arming
and triggering by using Valet Mode. This is very useful when
washing the vehicle or having it serviced. In Valet Mode, the
security system will not arm, even with the Remote Control, but
all convenience functions (door locks, trunk release, etc.) will
continue to work normally.
To enter or exit Valet Mode:
1. Turn the ignition on.
2. Turn the ignition off.
3. Press and release the Valet
button within 10 seconds.
The status LED will light solidly if you are entering Valet Mode,
and it will go out if you are exiting Valet Mode.
May 08, 2010 | 1994 Honda Civic
My Mustang Cobra has a Viper alarm system that won't set
Under the dash, Your installer that worked on your Cobra should have put an valet button under the dash, It is a small round Black button, Ok with the driver door open,,put your key in the ignition and go to the on position, Locate the black button before you do this, once the ignition is on hold the black button down for 3 seconds hit it once more and then turn the ignition off, the light should start flashing again and the chirp for arm and disarm with work again, What you have going on is called Valet mode which is designed to put the alarm side of the system to sleep which can happen from accidentally bumping it.
Hope this was helpful.
That Crazy Install Guy.
Apr 05, 2009 | Vehicle Parts & Accessories
Programming the APS02BT2 remote
TO PROGRAM ADDITIONAL TRANSMITTERS:
1. Enter the vehicle, and turn the ignition key to the "on" position.
2. Press and release the valet push-button switch three times.
3. The dash LED will flash once, and the siren will "chirp" once, indicating the system is ready to accept programming for channel 1 or the arm/disarm and panic functions.
4. You can assign any of the three transmitter button functions listed below to channel 1.
a. Pressing button #1 on the keychain transmitter.
b. Pressing button #2 on the keychain transmitter.
c. Pressing both buttons simultaneously on the keychain transmitter.
5. Press and hold the selected choice a, b, or c above, until the siren emits a long "chirp" to confirm that programming of channel 1 was successful.
6. Press and release the valet push-button switch one time.
7. The dash mounted LED will flash 2 times, and the siren will "chirp" indicating that the system is ready to accept programming for the unlock/panic channel.(If you desire one button to control lock & unlock, move on to step 9)
8. Press and hold the selected remaining choice a, b, or c above, until the siren emits a long "chirp" to confirm that programming of unlock channel was successful.
9. Press and release the valet push-button switch one time.
10. The dash mounted LED will flash 3 times, and the siren will "chirp" indicating that the system is ready to accept programming for channel2, or the pulsed ground output for remote trunk release, remote car starter, etc.
11. Press and hold the selected remaining choice a, b, or c above, until the siren emits a long "chirp" to confirm that programming of channel 2 was successful.
12. Press and release the valet push-button switch one time.
13. The dash mounted LED will flash 4 times, and the siren will "chirp" indicating that the system is ready to accept programming for channel 3, or the additional pulsed ground output if available on your model. NOTE: If the program switch is operated again, the circuit will recycle through the program mode. In other words, press 1 time to access the lock function, 2 times to access the unlock function, 3 times to access the start function. When programming is complete, simply turn off the ignition switch to exit the program mode.
ERASING TRANSMITTERS IF THEY HAVE BEEN LOST OR STOLEN: NOTE: Before you begin to erase the lost or stolen transmitter(s), have all transmitters available that you wish to remain programmed. These will be used during the program process to identify transmitters that will continue to be used.
Enter the transmitter program mode:
1. Turn the ignition switch to the “ON” position.
2. Within 10 seconds, press and release the valet/program switch three times. (Siren emits 1 short chirp indicating channel 1 has been entered)
3. Within 10 Seconds, press and hold the ARM or ARM/DISARM but-ton of the first transmitter you wish to remain stored into the control unit until a single chirp is heard from the siren.(Repeat this for each transmitter you wish to remain stored in the control unit).The receiver stores up to four transmitters. To be certain all transmitter slots in the receiver are occupied with transmitters you wish to continue to use, and all others are erased, you will have to fill all four receiver slots. If in step 3 you identified one transmitter, you will have to fill the additional 3 slots. If in step 3 you identified two transmitters, you will have to fill the additional two slots, etc...
4. Press and hold any unused button or combination of buttons until a long chirp is heard from the siren. Release and press the button or button combination again and again until all remaining slots are full. NOTE: The button or combination of buttons entered will also control the armor arm/disarm function until additional transmitters are added. All unwanted transmitters are now deleted.
Feb 28, 2009 | Car APS02BT2 Transmitter for...
I cant disarm my alarm
Get inside the car, turn the key to the on position, the alarm is going to sound so do not panic when the alarm sounds press the valet button one time and the alarm should stop. To place the alarm in valet mode cycle the key with the door open on then off then press the valet button one time and the alarm should go into valet mode meaning the alarm light will be on steady.
Feb 03, 2009 | Viper Security and Remote Start System...
Car Audio & Video Logo
1,702 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
