Since I purchased a new laptop running Vista, I can no longer print PDF files. Everything else prints perfectly. I assume the problem lies with Vista, but with no response from Microsoft do you have any ideas please? Rosemary
  • 1 more comment
  • sokari52 Sep 28, 2008
    I am using Adobe Acrobat 8 to open pdf files. Nothing happens when I hit Print except for box that says no can do, printer inaccessable or words to that effect. I have tried all printer options available.
    Thanks Joed911, I will try your suggestion. I will post the results.
    Thanks heaps Joed911. Your suggestion fixed my problem. I downloaded Foxit and I was able to print my pdf file immediately. After weeks of frustration I can now get on with my work. Thanks again.
  • Computers & ... Master
  • 787 Answers
This sounds interesting.
Does nothing happen or does the print job sit there not being printed?
When you try to print the pdf have you checked to make sure it is going to the correct printer and not something like the Microsoft XPS Document Writer?
Can you open a pdf on this system to view it? If so, do you know what program you are using?
Posted on Sep 28, 2008
  • 4,338 Answers
Down load FoxIT reader, it is a better PDF reader.
  • JDTec
    JDTec Sep 28, 2008
    Yor are welcome :)
ES9410 - PDF jumbled printing
Assuming you are using MS Windows then install FoxIT pdf reader which allows command line printing on Windows. Go to http://www.foxitsoftware.com/ to get it. Make sure your OKI printer is the default.
Once installed you can print using the command, from my dusty memory -
Reader.exe /p MyFile.pdf
I don't use Windows any longer, now exclusively Linux, so I might be mistaken.
Cheers, Martin
Nov 07, 2013 | OKI Office Equipment & Supplies
Printer has stopped printing .pdf files
Check your list of printers and make sure the default printer is the correct one.
Mar 18, 2017 | HP OfficeJet 6210 All-In-One InkJet...
How do I scan multiple paged to one pdf and not have each page be its own pdf file
i thinks most scanners will let you press "Enter" for each page to scan multiple pages and then press "Finish" to actually start scanning.. this should print everything into one document
Feb 02, 2010 | HP Pavilion dv6000z Notebook
Hp photosmart c5580 all-in-one
This is not a printer problem, but a pdf problem. Re-install Acrobat Reader.
Aug 03, 2009 | HP Photosmart C5180 All-In-One InkJet...
My WGPS606 wont print on my Windows Vista laptop, its prints with all normall xp windows laptops and desktops, but I recently bought a new laptop and it does not print, the print says error, can somebody...
there is a proceedure for manually adding the printer ports instead of using the wizard on the software disk. Look on the disk and go to the guide .pdf file, the instrucitons are there. i tried it and it worked fine.
Apr 01, 2009 | NetGear WGPS606 (WGPS606NAR) Print Server
Canon bjc 50 printer
You are correct on your deduction.
It is the USB to Parrallel adpter. They are not reliable in the XP/Vista enviroment. I have run into this several times.
Oct 07, 2008 | Canon Office Equipment & Supplies
Printer will only print header
i have the same problem..if i highlight the document then it prints everything....helppppp
May 10, 2008 | Office Equipment & Supplies
Viewing scanned item
Go into HP Director and select save to file
send to email or save as pdf should be an option
It should rescan the file and save as pdf
which you can send as an attachment
you should be able to upload to
kodak imaging if it is available
on vista if exist click on file acquire image
I am assuming you had HP Director on
your software cd for the scanner
Nov 17, 2007 | HP Photosmart 2575 All-In-One InkJet...
Creating PDF files with Vista
Dear Andrea, its working for me. Simply Press Ctrl+P and page set up would appear, you can do it from there.
If that was helpful please press solved.
Nov 07, 2007 | Adobe Photoshop 7.0 for PC
Wireless printer
it sounds as if the printer may not be set as the default printer, so check in the installed printers and check and also check that the printer you are sending the print to is the setup one and not a pdf or microsoft office document printer, this is found on the drop down box when the print option appears. i am also assuming that the printer has worked before from vista to an xp machine as sometimes xp needs a small update to be used with a vista pc on the network
Jun 12, 2007 | Linksys (WKPC54GCU) 802.11g/b Wireless...
Computers & Internet Logo
David Payne
David Payne
