Question about Gateway HD2200 LCD Monitor
Gateway hd2200 monitor
Turns on for 2 seconds then is black no respond was fine last nite
was also flashing on off
  • 6 more comments
  • jjwong Sep 29, 2008
    Same problem, star for 2 seconds and then black. If you remove all connections and turn it on it suppose to say no signal, well I dont see any message even when there is no signal input.
  • boopat Sep 29, 2008
    thanks for the solution, its not the power source , because I have tried different power outlets, when the monitor is connected to the comupter it turns on flashes to the gateway logo then goes black,then sometimes flashes to my login page for two seconds, the monitor is only five months old,what could cause it to burn out ?
    in was pluged into a surge strip. putting in a box to back to gateway.
  • boopat Sep 30, 2008
    thank you very much.
    your'e right thats why the monitors are so cheap now ,they have comprised on quality parts, an they hardly give any warrentys ,they are becoming throw aways.
  • Anonymous Jan 24, 2009
    The monitor was fine last night when I went to bed. This morning when I turned it on, there was a quick flash and nothing. I've tried plugging into other outlets and it's not turning on at all. I've only had this monitor for seven months and I'm not happy. I'm using my old laptop which is useless as all the files I need are on my desktop which is inaccessible without a monitor. I guess I'll have to buy a new one. I don't think I'll go with Gateway again.
  • flashmarker Jan 24, 2009
    I have the same problem. Last night the monitor was working fine. When I got up this morning and turned it on, there was a quick flash then nothing else. I've tried plugging it into different outlets and it isn't turning on. I've only had this monitor since June and it's a shame that I'll have to go out and buy another one. I doubt I'll buy another Gateway.
  • johnzhu87 Mar 16, 2009
    same thing, woke up the next morning it blacks out...like i wait for my computer load compeletly then i switch it on...and it just turns on for 2 seconds and then it blacks out....-_-....i guess eh?...get a new one?
  • swimber May 09, 2009
    Monitor flashes the Gateway logo upon startup, then goes black. Occasionally, it will display the login screen for maybe 2 seconds and then go black again. It is less than a year old. It does NOT power off, the power remains on.
  • markd0618 May 17, 2009
    I have the same monitor (Gateway HD2200) with the same problem. I've disassembled it. The LCD panel is made by Samsung (model LTM220M1-L01). The LCD portion is working - I can see my computer's output when I use a different light source. The backlight flashes on momentarily then goes black. The data sheet indicates that the CCFLs are driven by 760Vrms. My meter won't go that high, so I can't check it. All DC voltages coming from the power supply are within spec (+5v and +10v). I don't see any burned or stressed components on the power supply/inverter board.
    Any ideas?
    Mark
  • 12 Answers
The problem with the monitor is the power inverter board. I took my monitor apart and tested all the power outputs. The ones going to the main board where ok but the ones going to the backlight where different. I changed the three capacitors on the power board that where located between the two heat sinks I think it was the 1000uf and the two 470uf. They looked ok but when i tested them they where off. Next on the opposite side of the board with all the little componites there are a few dry joins that you have to resolder. If you cant find then you can just resolder the whole back board it should only take 30min. If you have no idea what i am talking about i would not sugest taking the monitor apart.
Posted on Jul 28, 2009
I have the same monitor and have dealt with this for some time now. I think it may be a problem with the monitor not letting your tower know to look for the correct video source. The problem became much worse when I started using an HDMI cable. I think it may actually be my p.c., because when I shut down my tower and pull the power plug from the back of the p.c. for 10 seconds or so, it fixes it every time.
Posted on Jun 19, 2012
Timezone88, hope you get this since it is an old posting. I just replaced all the caps on my power inverter board. I have 10v comming off the board but do NOT have any 5v. Any idea what component creates the 5v? Do you have a schematic for this board? thanks
Posted on Feb 13, 2012
    Sergeant:
    Champion:
  • 223 Answers
When you say it was flashing on and off do you mean the power or the picture? If the picture it could be a fault with one or both of the rectifiers otherwise maybe something wrong on the power supply. Sorry my guess could not be a bit more accurate, if you can please write a little bit more information. Good luck.
Posted on Sep 28, 2008
  • Paul Sep 29, 2008
    I know I will sound like an old man saying this but the quality of components they use in equipment nowadays is not like it used to be. For example I know from experience that some of the surface mounted capacitors they use in this particular monitor there are better quality ones around, but then I guess the price of the monitor would go up and as always we end up footing the bill. Like I said before a lot of LCD monitors have high speed low loss rectifiers and its a mystery to me why a lot of them keep on failing. As soon as I find out more will be happy to share. Sorry I could not be more help.
  • Paul Sep 30, 2008
    Lol and thats exactly why that say "you gets what you pays for" is so rife nowadays. I wouldn't mind if the companies wanted to charge us the Earth for a reliable product but even that is no guarantee.
I figured out how to adjust the brightness on my Gateway hd2200 monitor but it won't brighten it flashes on bright for a second and then goes right back to dark is there anything I can do thank you
Jenny
In some monitors there is a HUD display, there you can reset the board, or program that control colors and other settings, also you can press if is available, a botton that automatic change colors, RGB, cinema, movies, games, etc.
Carl
Jul 17, 2016 | Gateway Computers & Internet
MONITOR HD2200. I TURN IT ON AND THE SCREEN GOES WHITE THEN A FEW VERTICAL COLOR LINES APPEARS AND AFTER A FEW SECONDS IT GOES BLACK.
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
Hope this will help out in solving the problem....
May 21, 2011 | Gateway HD2200 LCD Monitor
Installed wed cam and monitor shut down with a promt saying "frequency out of range". Changed resolution settings still have a problem with monitor and this promt. Changed to another monitor and everything...
Connect the monitor that works.
In the "Advanced" settings for the video-card,
set the "refresh-rate" to 60 Hertz.
Connect the other monitor -- it _very-likely_ will support a 60 Hertz refresh-rate.
Jan 24, 2010 | Gateway HD2200 LCD Monitor
Turns on for 2 seconds then just turns off
you check the power cable or the power unit may be the cable have been cut
Nov 02, 2009 | Gateway HD2200 LCD Monitor
Gateway FPD2185W
The next thing to try would be to resolder all of the connections on the transformers in your monitor. If you can take a few pictures of the board and email them to me I will mark the points to check and send it back to you.
Buddy
Corporate Computer
www.ccl-la.com
Aug 14, 2009 | Gateway HD2200 LCD Monitor
Same problem 2 seconds on, then turns black
Jul 03, 2009 | Gateway HD2200 LCD Monitor
Monitor doesnt work
You can check the fuse on the monitor and replace it. In case the fuse is OK check the cable connector, display card on the motherboard.
Thanks
Oct 17, 2008 | Gateway FPD1960 19" Flat Panel LCD Monitor
Gateway HD2200 LCD Monitor Logo
2,260 people viewed this question
Top Gateway Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Prashant M
Prashant M
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
