My HP printer is displaying the following message: Remove and check cartridge. I have removed and checked the cartridge, even replacing the black cartridge and still get the same message.
One of the printer cartridges had a expiration date of 2008/9/2. I replaced the cartridge with a new one and the printer now works. Thanks for asking.
Posted on Sep 28, 2008
My hp officejet is displaying a message "remove
Your printer is in Error mode.. Specially with black ink empty message. HP Printer is designed in such manner that it will not allow you do to anything if it gives cartridge error message on printer screen.
you will have to replace the cartridge and align the printer to get it working.
Regards,
Ron
Jun 12, 2011 | HP OfficeJet 6110 All-In-One InkJet...
HP printer all-in-one model2410xphotosnart keeps giving me the message to remove and check print cartridges which I have done and both are full. Will not stop blinking and when trying to print makes...
Welcome to Fixya
This means the the printer cannot determine which cartridge is causing the error. Make sure that you are using original HP cartridges.
Please see troubleshooting procedure below:
  1. Remove the color cartridge from the left stall (which has a blue latch) and refasten the latch. Leave the other cartridge in place.
  2. Close the printer, wait 10 to 15 seconds, then look at the LCD display.
    • If the LCD display reads Insert Color Cartridge in Left Stall , the color cartridge may be causing the problem. Follow the steps below:
      1. Clean the color cartridge contacts. Click here to see how.
      2. Reinsert the color cartridge into the carriage and close the blue latch.
      3. Close the printer and wait 10 to 15 seconds.
      4. If the LCD display reads Remove and Check Print Cartridges , replace the color cartridge.
    • If the LCD display reads Remove and Check Print Cartridges , follow the steps below:
      1. Reinsert the color cartridge.
      2. Remove the black or photo cartridge, depending on which one is installed in the right stall. The right stall has the gray latch. Be sure to refasten the latch on the empty stall.
      3. Clean the black or photo cartridge contacts.
      4. Reinsert the black or photo cartridge.
      5. Close the printer and wait 10 to 15 seconds.
      6. If the LCD display reads Remove and Check Print Cartridges , replace the black or photo cartridge.
  3. If replacing cartridges fails to correct the problem, click the link at the top of this page to contact HP.
Thank you for using Fixya!
Apr 03, 2011 | HP Office Equipment & Supplies
Cannot print, scan or copy. Continue to receive
Solution
  1. Remove and then reinsert the cartridge indicated in the error message.
  2. If the error is still displayed, clean the contacts. Click here to see how.
  3. If the error message is Error. Remove and Check Black or Photo Cartridge , the following steps may help:
    1. Remove both cartridges, lower the latches, and close the printer access door.
    2. Turn off the unit by pressing the On button on the front panel. Wait for the printer to completely shut down.
    3. Turn the printer back on by pressing the On button.
    4. When the message display reads Insert Print Cartridges , open the access door and replace the cartridges.
  4. If neither of the steps above fixed the problem, either the cartridge or the printer is faulty.5. Replace Cartridge.Please rate my response!!!Thanks,SF
Jan 28, 2010 | HP PSC 2410 All-In-One InkJet Printer
Keep getting Remove and Check Cartridge message even when I replace the black cartridge with a new HP one. How can this be fixed?
I believe you have to press the "select" button or the "options" button. Both are located right under the LCD display
Sep 07, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Hp officejet 5510 remove and check black cartridge message and i replaced the black to new one.
Hi Shaharz !
As per the information you have provided, I understand that you are receiving an error "Remove and check black ink cartridge" on the All-In-One display screen. If yes, perform the below steps.
Let me provide you the cause of the issue. The most cause of the issue is that if you are using refilled, re manufacture ink cartridges, cartridge is not fitting properly, wrong cartridge no. However, perform the below steps to resolve the issue.
1. Remove the print cartridges from the printer.
2. Clean the print cartridges using the lint free cloth both the cartridges heads as well as inside the printer.
3.Follow the steps below to power cycle your all-in-one:
a. Verify that the unit is switched on. Disconnect power cable from All-in-One and also from wall outlet.
b. Wait 30 seconds.
c. Plug in the power cable to All-in-One and also to wall outlet.
4. Insert only the black ink cartridge first and check the message on the printer.
If the issue is with the black ink cartridge then the same message will be appears on the printer. If not it will prompt you to insert the color ink cartridge.
Do the same procedure with the color ink cartridge.
If the issue persist, then it shows that the issue is with the black ink cartridge. check the expiry date of the print cartridges and try to replace it.
I believe the issue is with the printer itself. However, the printer using the HP 56 and 57 ink cartridges.
As you have mentioned that you have already replaced the black ink cartridge. Then it confirms that the issue is with the printer. However, you can try resetting of the printer to its default settings and check for the issue.
To reset the printer, perform the below steps.
A semi-full reset will do the following:
The user settings to the factory defaults, Language and country settings on some models, Fax logs, Fax headers, Fax speed dial information.
Reset the All-in-One to the factory default settings by using these instructions:
1. Unplug the power cable from printer when the printer is powered on and wait for 20 seconds.
2. Then, press and hold # and 6 while plugging in the power cord.
Continue holding until it displays Semi Full Reset message in the front panel of the All-in-One.
The printer might be turned off after performing the above steps, so no need to worry about that.
Then turn on the printer and check for the result.
Hope this will helps you a lot!!!
With Regards
Mike.
Jun 27, 2009 | HP Officejet 6310 All-In-One InkJet...
HP 7410 printer displays error ''remove and check colour cartridge
I think that spring must have gotten loose that holds the cartridge in place, right hand side, put it back where it belongs, might want to compare with the other, black cartridge side.  Good Luck!
May 13, 2009 | HP OfficeJet 7410 All-In-One InkJet...
I haven't the manual for this printer color laserJet 2600n series,
HP Color LaserJet 2600n Printer - Installing Print Cartridges When a print cartridge approaches the end of useful life, the control panel displays a message recommending that to order a replacement. The printer can continue to print using the current print cartridge until the control panel displays a message instructing to replace the cartridge. The printer uses four colors and has a different print cartridge for each color: black (K), cyan (C), magenta (M), and yellow (Y). Replace a print cartridge when the printer control panel displays one of the following messages: Replace yellow cartridge, Replace magenta cartridge, Replace cyan cartridge, Replace black cartridge. The control panel display also indicates the color that should be replaced (unless a genuine HP cartridge is not currently installed). Change the print cartridge
  1. Turn off the printer.
  2. Open the front door. c00315320.gif CAUTION: Do not place anything on the transfer belt (ETB), which is located on the inside of the front door.
  4. Remove the new print cartridge from the bag. Place the used print cartridge in the bag for recycling. c00315322.gif
  5. Grasp both sides of the print cartridge by the blue handles and distribute the toner by gently rocking the print cartridge from front to back. CAUTION: Do not touch the shutter or the surface of the roller. c00315323.gif
  6. Remove the orange shipping locks and the orange shipping tape from the new print cartridge. Discard the shipping tape and shipping locks according to local regulations. c00315324.gif
  7. Align the print cartridge with the tracks inside the printer, and using the handles, insert the print cartridge until it is firmly seated. c00315325.gif
  9. Turn on the printer. After a short time, the control panel should display Ready.
    NOTE: If a cartridge is in the wrong slot or is the wrong type for the printer, the control panel will display one of the following messages: Incorrect yellow, Incorrect magenta, Incorrect cyan, Incorrect black.
  10. Installation is complete. Place the used print cartridge in the box in which the new cartridge arrived. See the enclosed recycling guide for recycling instructions.
  11. If a non-HP print cartridge is in the printer, check the printer control panel for further instructions.
    NOTE: When replacing or changing a black print cartridge, a cleaning page will automatically print. This helps prevent speckles on the front or back of printed documents. A cleaning page can also be generated using the control panel or the HP Toolbox.
Nov 03, 2008 | HP Color LaserJet 2600n Printer
Hp psc2410xi
The following error message appears on the color graphics display after you insert a cartridge: Remove and Check Print Cartridges . The printer will not print. The message does not specify which cartridge has caused the error. Solution This error message indicates that the printer cannot determine which cartridge is causing the error. Follow the steps below to solve the problem.
    OR
    1. If the error message is Error. Remove and Check Black or Photo Cartridge , the following steps may help:
    1. If neither of the steps above fixed the problem, either the cartridge or the printer is faulty
    Aug 12, 2008 | HP LaserJet 5L Printer
    Remove and ck right cartridge
    Once remove both the cartridges from the all-in-one and then clean the copper contacts of the cartridges and then put only black cartridge and check for the message displayed on the all-in-one if it even reads check right cartridge then the issue is with the all-in-one hardware. If it reads insert right or color cartridge then the issue seems to be with the cartridge.
    Remove the cartridges from the all-in-one and power cycle the all-in-one and then reset.
    Now insert the cartridge and check for the result. If the issue still persists then check the expiry date on the cartridge and once replace the cartridge and check for the result.
    May 27, 2008 | HP Officejet 7210 All-In-One InkJet...
    Check black cartridge message
    This happens if you refilled the cartridges, and forgot to take out the air..
    Follow this steps..
    1. Switch on the printer, open cartridge bay, remove cartridge, dont close the cartridge holder flaps, directly unplug the power supply from the printer end.
    2. take a soft cotton, lint free cloth, slightly swab it with pure water, wring the cloth so any excess water is removed, and clean the contact pins inside the printer cartridge holder..
    3. clean the cartridge head by keeping it in hot water (about 50C) and then wiping it clean, keep it upright for a few min, and when both printer and cartridge is completly dry put it back in, voila it should not display the message now...
    Sep 25, 2007 | HP OfficeJet V40 All-In-One InkJet Printer
    64 people viewed this question
    jasbo
    jasbo
