Question about GE DBSR453EBWW Electric Dryer
Burning smell coming from the dryer!
When I dry my clothes, there seems to be a burning smell coming from the dryer...Also, a puddle of water forms underneath the dryer and the metal hose thing that connects the dryer to the wall is wet on the inside...It seems as though there is condensation on the inside of the dryer door when you open it and the clothes are still wet and hot.
  • 5,911 Answers
You have a serious clog somewhere in your dryer exhaust ventilation. I would recommend you STOP using the dryer immediately and clean both the interior and all the vent ducting from where it exits the dryer to where it exits the home. the burning is coming from lint build up in and around the heating element and its beginning to smolder. This is a potential fire hazard and may end up causing the heating circuits to fail. The condensation comes from the the inability of the hot air (which is mixed with humidity from your clothing) condensating inside the vent duct. The lint starts to collect and get wet to the point of saturation. Then it begins to cause water to form and leak out of the ducting and on to your floor. You do not want this condensation inside the dryer where the heating circuits are. The following link will provide with some guidance for future reference:
http://www.fixya.com/support/r385301-thorough_dryer_advice
Pay particular attention the paragraph where it discusses proper dryer ventilation. I hope this helps you. Let me know if I can be of further assistance.
Posted on Sep 28, 2008
Why is my hotpoint tcm570 tumble dryer leaving a puddle on the floor
Since no dryer I am aware of uses any liquid, I suggest you may be putting wet clothes into the dryer.
This can happen if the washer does not spin the clothes nearly dry. Many dryers have small holes in the dryer drum to let excess water flow out, I would guess that may be the case with yours.
Are your clothes nearly dry when they come out of the washer?
If not, perhaps the washer has a loose belt or has a problem with the "dry" cycle.
God bless your efforts.
Nov 02, 2015 | Hotpoint Dryers
My amana dryer smells like something's burning
You will need to open the dryer ans clean the internal duct work.
May 22, 2012 | Amana NED7200TW Electric Dryer
Puddles of water forming under the unit
clean out the dryer and the vent line,you need to clean out the duct that the lint filter slides into,vac out the inside where the motor is and if the vent line is long blow it out with a leaf blower,also check the outside vent to make sure nothing is blocking it.the hot moist air isn't blowing outside,it's stuck in the dryer and vent line,all a dryer does is remove the moisture out of the clothes by moving air,if the air can't move correctly themoisture has to go somewhere.let me know how you make out,also if it's gas do this once a year,electric once every two years so you don't have a fire
Jul 25, 2010 | Fisher and Paykel DE06 Electric Dryer
When the dryer is running it smells like charcol ligher fluid
Sometime recently there has been a petroleum product used in the house. Possibly an oil based paint, stain, varnish, adhesive or some form of cleaning product.
Anyone of these products or many others like them, contain a distillate of liquid. Check around the house.
Until that oil based product dries or cures, the odor and vapors will remain and so will the dryer smell.
At the end of the drying cycle, use the air fluff cycle to purge out the smell. Besure to return the selector on the dryer back to it's prior postition.
Jun 11, 2009 | Kenmore 62882 Electric Dryer
A STRANGE SMELL WHEN DRYING..
sounds like brushes they can cause a burning smell......as for clothes smell after drying the fan in the heater could be dirty but generally that would mean the heater will not work
Mar 18, 2009 | Hotpoint Aquarius WD63 Front Load...
GE Dryer smells like its burning
the burning smell may be caused by a belt some have a look at the belt
Mar 07, 2009 | GE Dryers
LG TROMM DRYER DLE5977 Burning Smell
It is a POS dryer, we have the same one. My suggestion get another dryer. We vacuumed it all out (don't you have a problem with the lint catcher?) Then it started loud pounding noise, which a lot of people seem to have the same problem, then our sensor went out and we had to dry the clothes 5-10 x's...now crack in stainless steel drum and is chewing up all our expensive clothes!
Feb 21, 2009 | LG DLE5977 Stainless Steel Electric Dryer
LG Gas dryer doesn't dry clothes in one cycle
Have you checked your outside vent while it was running to see if the dryer was venting 100%. If your clothes are hot and humid I would say clean your vent pipe has a blockage and needs to be cleaned out. Also as far as the burning smell you could take the front off (unplug first) the dryer of by removing 4 screws one above and one below the latch and two at the bottom and there are two clips one at the top left and right push in with a puddy knife and lift the top up a couple inches and lift the front up off the bottom holders. Then you will have access to vacuuming the lint that is floating around the burner.
Dec 01, 2008 | LG DLG5932W Gas Dryer
GE DBSR453EBWW Electric Dryer Logo
386 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
