Question about NetGear WGT624 Wireless Router
Cabel to router
I cannot get internet to work with my router hoked up
  • NetGear Master
  • 787 Answers
More details would be helpful.
Is your internet cable, dsl (telephone) or something else?
What is the make and model of your router?
Are you trying to connect wired or wireless?
What operating system are you using.
Assuming that this is a wired router with DHCP turned on and your network adapter is configured to obtain IP and DNS addresses automatically. Turn off or unplug everything. Connect the cat5 cable from the cable or dsl modem to the WAN or INTERNET port on the router. Connect a cat5 cable from any of the other ports to you computer. Now turn the cable/dsl modem on and wait 60 secs, then turn the router on and wait 60 seconds, finally turn your computer on.
BASIC TROUBLESHOOTING (assumes XP with at least SP2)
Open a Command window - START - RUN and type in cmd, click OK
A Black windows with white text opens.
type "ipconfig /all" without the quotes and press enter
this should display your ip address, the default gateway and dns servers
type ping followed by your default gateway address example: ping 192.168.0.1
if you get a reply this means that he communication between your computer and the router is ok
next ping 74.125.19.147
This is the ip address for google, if you get a reply you do have access to the internet
try your browser, if it shows page cannot be displayed, enter this in the address bar -
http:\74.125.19.147
If you see a google page open up it means you have a dns problem, go back to the command window and type "ipconfig /flushdns"
If you cannot even ping your gateway,open the command windows and type "netsh winsock reset catalog" then reboot
More details in your questions means more specific answers :)
Posted on Sep 28, 2008
Lynnksys will not connect to internet
check if the type of protocol dhcp or ppoe
check that the ip not the same with cable modems
192.168.1.1 if same change it on lan settings on router
to 192.168.2.1
save settings and power cycle linksys router
please specifi protocol to folow up
Jan 29, 2010 | Linksys BEFW11S4 802.11b Wireless...
ZyXeL P320W Won't connect to internet
check weather urwireless zero configuration is disable go to the my computer right in that manage in the manage go to the services in that go to the services in that one service is there in down wireless zero configuration just start it if already start just go for the restart
Mar 28, 2009 | Zyxel Prestige 320W Wireless Firewall...
I have a cable modem. from the cable modem I go to a 5 port hub
That is because most cabel internet providers only gives you one public IP. Please go to a Best Buy, Office Depot, Staples, Walmart, or Targer, and ask for a LinkSys Router. The router will do NAT (Network Address Translation) that will allow more than one PC share the single public IP. This will solve your problem and will cost an estimated $30.00. The router is simple to hook up, just plug the cabel from your modem into the Internet/WAN port on the router. And the two computers into any of the other ports. Be sure to unplug both cable modem and router then plug up the cable modem first, once the ready light is on, plug up the router.
Adam
Nov 15, 2008 | Stratitec 5-Port 10BaseT Ethernet Hub...
Siemens speedstream 2624
you have to configer your router are you using dsl or cabel inter net
cabel you dont need to set in log on but dsl you do
secound configer your router wireless i think you are are useing dsl speed stream bell use
Aug 15, 2008 | Siemens SpeedStream 2624 Router...
Sharing internet with bt voyager 210 adsl router and linksys broad band router
hook you linksys uplink you cabel out from adsl router uplink other end goes to links wan
Aug 14, 2008 | Computers & Internet
Unplugged Power and Now Unable to get a connection with router
Make sure that the Ethernet Cabel is plugged into the computer and attached to the router. make sure another ethernet cabel is attached from port 1 of the router to the Modem. Hope this works.
Feb 19, 2008 | Dell Wireless 2350 Router
Trying to hook up the internet
Your internet connection should plug into your modem, and the modem should plug into your router. Plug any computers you use directly into the router. If it's a wireless router, it's just a matter of going into the Wii and entering the settings for your wireless router.
Does this help?
Jan 26, 2008 | Nintendo Wii Console
Can this be used with a MAC?
Any router will work, TCP/IP is a network standard, definately double check the cables. Your DSL modem is usually 192.168.254.254. and the router is usually 192.168.1.1. Check your documentation for the default IP. Once you know it type it in to the broswer in your Mac. Before doing so connect with an ethernet cable, purchase a new one if necessary. Connect from the <--> labeled port on the mac, or ethernet port. These wires are not like phone lines, they have 8 wires instead of 4/6. The router usually has ports on the back labeled 1, 2, 3, 4, and WAN. the 1-4 ports are LAN and that is also labeled on there. Plug the mac into port 1 and any other computers in after you get internet. once the physical connection is recognized. Go to your browser in the mac and proceed. if you get a web based router configuration page your router is working, then make the WAN connection to the ethernet port on the back of the dsl mode. Be sure your cables are good. Also go to your control panel and make sure your internet is enabled in your network section.
Jan 06, 2008 | Siemens SpeedStream 2624 Router...
How to work router
Router can't connect directly to internet by itself, you need to have a modem. Your router need to connect to your modem and the modem will connect to WAN.
Nov 16, 2007 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Open Questions:
See all NetGear WGT624 Wireless Router Questions
NetGear WGT624 Wireless Router Logo
59 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
