Question about Microsoft Windows XP Home Edition
Internet explore When I go to use internet explore it opens than closes right way. I also got an error-IEXPLORE.EXE-Application error 0x040elfff referenced memory at 0x040e2000. The memory could not be "read"
    President:
  • 1,263 Answers
The error is in regards to the install application for the search engine. what i wan't you you to do forst is click on your start tab. then right click the browser tab. then click the properties tab. click the delete tab on your browsing history. click the delete all tab.it will pop a small window click the box that says delete add ons and click the yes tab. a window will pop up showing the deletions when that is done close the window.click your start tab and click on control panel options. click the network connection tab then right click on the network you use. then click on the repair tab. when that's done restart the computer.once it is rebooted click start and the browser tab and you should be allright. I believe that the virtual memory of your temporary files is full. please rate this solution thanks
Posted on Sep 28, 2008
Internet explorer is not visible on desktop
Find a Missing Internet Explorer Icon in Windows XP
  • Step 1 Click the "Start" button. Click on "All Programs." Look for an icon called "Internet Explorer." Right-click the icon. Select "Copy" from the menu.
  • Step 2 Find a blank space on your Desktop and right-click on it. Select "Paste" from the menu. You should see a new icon called "Internet Explorer." Double-click it to make sure that it works.
  • Step 3 Open "My Computer" on your Desktop if you were unable to find the Internet Explorer icon in "All Programs." Double-click the "C:" drive. Double-click "Program Files." Open the folder named "Internet Explorer."
  • Step 4 Select the "iexplore.exe" icon and right-click on it. Choose "Create Shortcut" from the menu. Scroll down to the bottom of the window. Right-click the "Shortcut to iexplore.exe" icon. Click "Copy."
  • Step 5 Paste the icon to your Desktop. Open it to make sure it works.
  • Step 6 Click the "Start" button and select "Search" from the menu if you are unable to find the "iexplore.exe" icon in your Program Files folder. Search for "iexplore.exe." Locate the file. Right-click it to create a shortcut. Paste the shortcut to your Desktop.
  • Find a Missing Internet Explorer Icon in Windows Vista
  • Step 1 Click the "Start" button. Select "Run." In the "Run command" box, type "regedit.exe."
  • Step 2 Look for the key ""HKEY_CURRENT_USER." Click twice to open it.
  • Step 3 Navigate to "Software" and open it. Open "Microsoft," "Windows," "CurrentVersion," "Explorer," "HideDesktopIcons" and "NewStartPanel."
  • Step 4 Open the "{871C5380-42A0-1069-A2EA-08002B30309D}" key on the right side of the screen. Change the value to "0" to show the icon on your Desktop.
  • Jul 14, 2010 | Microsoft Internet Explorer 8
    Application error message
    This msg caused by the Memory problem. Sometimes System can't Accesed the your computer RAM properly or may be your RAM is not giving good performance. pls replace your RAM accordigly..
    Dec 26, 2008 | Microsoft Windows XP Home Edition
    Iexplore.exe Application error win2000 professional
    You need to reset your Internet explorer Browser
    In Internet Explorer Menu bar
    Click on Tools >Internet Options>Advanced>Reset
    It should Work
    Dec 24, 2008 | Computers & Internet
    Explorer.exe - application error
    Try the following to gather additional information.
    Run a test on the hard drive(s) for any bad sectors via chkdsk
    Run a memtest to verify the integrity of the physical memory. I would suggest the memtest via the Knoppix CD.
    Look in the Windows Event Viewer, Application and System log for any possible resource contention issues or other system problems.
    Dec 13, 2008 | HP Compaq ProLiant ML530 Server
    Iexplorer.exe-application error
    I'm suspecting you have a bad stick of ram. If you have more then one stick, take each one out individually and see if the problem goes away. If it stops then you know which is the bad stick.
    Oct 21, 2008 | Microsoft Windows XP Professional
    Iexplore.exe
    its internet explorer thats shutting Down.
    you may need to look at your internet explorer settings, some applications require java scripting and active x to be enabled.
    Also ensure your computer has adequate RAM Memory installed.
    Finally check the version Of direct X installed on your system. And the Graphics card capabilities.
    Mike @ compurepair.
    Apr 18, 2008 | Microsoft Windows 2000 Professional for PC
    Window closing Problem
    I think you have a bad memory chip or bad motherboard RAM bank.
    You should do a RAM memory check. If you look in the EventViewer by going to Start | Run | and typing "eventvwr.msc". You may see events there that will indicate what and why.
    Or, you can search for a Memory checker on the internet and use it to reboot and test your memory on bootup.
    Nov 28, 2007 | IBM xSeries 346 Server
    Microsoft Windows XP Home Edition Logo
    82 people viewed this question
    Top Microsoft Computers & Internet Experts
    micky dee
    Alun Cox
    Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
