Question about Linksys (NH1005) 5x10/100 Mbps Networking Hub
NH1005 network hub
I hooked 2 PC to the hub and it will not allow us online. It says internet not connected
  • dont_spam_me Feb 12, 2009
    I kinda have the same problem, I currently have 2 computers connected to the internet through the Lynksys NH1005 hub but I can't seem to get the third one connected. I have had 3 computers connected to the internet before using this hub but can't remember how I did it. I know it has something to do with changing the last number of the internal IP address but can't find the setting that lets me change it. Does anyone know where I can find this setting?
  • 787 Answers
I assume that besides the 2 computers you also have a cable or dsl modem connected to the hub in order to provide the actual connection to the internet.
The problem may be the fact that this is a hub and not a router or gateway. The problem is that although it will allow you connect more than 1 computer to the internet, it does not do any good if you Internet Service Provider only supplies you with 1 IP address. You need something that handles Network Address Translation (NAT), like a router or gateway device.
Posted on Sep 28, 2008
I got 3 PCs in my room & I got an old NH1005 thinking that with it, I would be able to connect the 3 PCs to the internet at the same time. When I connect any of my PCs directly to de MODEM, I get...
It would seem that the modem has only one ip address to offer. The switch won't allocate ip addresses to everything, for that you will need a cheap router. Install, enable DHCP and Away you go!
Good luck. Hope this helped.
Mark Vincent
Jul 05, 2011 | Linksys (NH1005) 5x10/100 Mbps Networking...
I cant get my home computer and lap top to both go on line at the same time
A "hub" just "splits" the Internet connection.
Each computer connected to the hub gets an IP-address from your ISP (Internet Service Provider).
However, some ISPs only allow each customer to use _one_ IP-address.
Ask your ISP for the capability to obtain a second IP-address.
Mar 18, 2011 | Linksys (NH1005) 5x10/100 Mbps Networking...
Linksys NH1005 V2.2 Ethernet 10/100 5 Port Hub Router. I cant get the other computers connected to the hub to connect to the internet. I've tried everything.
Hello!
I will just illustrate on how to configure or to set the correct IP addressing;
Assuming that we will manually put IP address on each computer:
PC1:
IP Address: 192.168.1.13
Subnet mask: 255.255.255.0
Default gateway: 192.168.1.1
Preffered DNS server: 192.168.1.1
***note that 192.168.1.1 is the IP Address that your ISP gives to you, so on the other computer (see below)
PC2:
IP Address: 192.168.1.18
Hope I was able to help.
Oct 09, 2010 | Linksys (NH1005) 5x10/100 Mbps Networking...
How do you connect a Linksys NH1005 v2 hub and whats the difference between a hub and a router?
A router takes an Internet connection, routes it to several other computers and provides each of these computers with their own IP address.
A Hub, on the other hand, will split the Internet, but the various ports on the hub will all have a single IP address. Makes it hard to use a computer for much of anything, if it is the second computer, you'll have trouble getting access.
Nov 13, 2009 | Linksys (NH1005) 5x10/100 Mbps Networking...
Need help!!
Just enable the DHCP capability of your DSL router and then connect the Linksys hub to your DSL router then your PCs to the Linksys hub.
Jul 03, 2009 | Linksys (NH1005) 5x10/100 Mbps Networking...
Linksys 10/100 network hub model nh1005
I hub is just a network distribution device.
It doesn't control IP addressing, or aid in connecting to the internet., you need a router for that.
What is the problem you are having?
Jul 02, 2008 | Linksys (NH1005) 5x10/100 Mbps Networking...
Linksys nh1005 ver. 2.1
first make sure that you are getting lights on all of the devices at the hub, and also that all four are getting ip addresses. if the 4th device is not getting an ip address but does show connected to the hub, then the problem is more than likely your router is not serving enough ip's for all of your devices. also make sure that everyone of the devices are not assigning a static ip that could possibly knock out one of your devices, or if they are all static ips, that one of them is not set to the same ip as another.
Jun 21, 2008 | Linksys (NH1005) 5x10/100 Mbps Networking...
Network Hub or Router - World of Warcraft - NH1005 Linksys
I recommend purchasing a small switch because what it sounds like is that the traffic being generated from and to the two computers and then out to the Internet is killing your hub. A switch would help reduce some of the traffic.
Mar 23, 2008 | Linksys (NH1005) 5x10/100 Mbps Networking...
NH1005
connect your broadband modem into hub. configure your broadband modem to PPPOE. then u can access internet in both pcs.
Mar 10, 2008 | Linksys (NH1005) 5x10/100 Mbps Networking...
Wired Router problem
Are you working with a router or a hub...there's a big difference in how they work. The heading above your post says LinkSys NH1005 Networking hub, but your post refers to a Router.(?) Can you provide the exact brand and model number from the device?
A router can support several devices and allow them to share a single IP address on the Internet. Router setup is usually automatic, but there are several settings that can be adjusted manually if it doesn't work right. If this is a hub, the ability to assign addresses to more than one device at a time will have to be set up by your ISP on the cable modem.
Your description of the problem sounds like you may be working with a hub, and the cable modem isn't supporting connection of more than one device at a time to the Internet. If that is the case, you will need to contact your cable provider to see if they can support more than one network device using a hub. If not, you will need to upgrade to a router.
Jan 22, 2008 | Linksys (NH1005) 5x10/100 Mbps Networking...
Linksys (NH1005) 5x10/100 Mbps Networking Hub Logo
856 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
