Question about Cameras
Computer will not load pictures from my camera
I had this same problem because I didn't have drivers for the camera, so I put the memory card in an older camera to upload photos to the computer, and it worked perfect! Just connect camera (or SD card reader) to your USB, click on the My Computer icon and you should see an extra drive shows up, if not refresh the page and it should be there, click on it and select open or explore, move the folder to your desktop, if you want to save pics. To edit photos cut and paste or drag to whatever program you normally use. May seem tricky but really it's simple. Hope this helps! c-ya, Lisa
Posted on Sep 28, 2008
Fuji svp t718 camera will not download pictures to my computer. hooked up usb cable and it just says on camera screen usb connecting. nothing else happens. what can I do?
In order to down load pictures from a digital camera to the computer, you must first load software that allows the computer to recognize your camera. There should be software that came with the camera, and how to load it is in your manual. If you choose not to do this, then you can take the memory card out of the camera and insert it into a card reader attached to your computer and see the pictures on the card.
Feb 14, 2011 | Cameras
I took 10 pictures without the memory card so the pictures are on the cameras memory i suppose. I'm now wanting to load them onto my computer but my picture program as well as computer can't see the...
Took a bit to find this this bad news in the manual but what happens now is to get the pictures from the internal memory to the computer as a down load you need to first insert a memory card format the memory card and load each picture from the internal memory onto the memory card one at a time once that is down then you can download the memory card to the computer then you will need to reformat the memory card and then go back into the internal memory erase each one of those images and format the internal memory. Now the GOOD news, you only have 10 pictures. Don't forget to do the formatting.
Jan 04, 2011 | Olympus Stylus 790SW Digital Camera
How to load pictures from camera to computer
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program, such as might have come with your camera.
Jul 28, 2010 | Pentax Optio 33LF Digital Camera
I am trying to download photos to my pc. All plugged in the the Device Connected box ins blank. Any ideas - its driving me nuts!
OK, when I use my Kodak Easy share cameras on a fresh computer that hasn't downloaded Kodak pictures before I do the following:
Load Easyshare software onto the machine, and install it.
Then, I connect the camera to the computer.
Then, I open the Easyshare software and it may ask a few questions.
Next, I watch the computer (Windows 7) as it loads the proper driver for my camera.
Finally, I click on transfer pictures and I am set with my pictures.
The pictures should show up in the Start Menu's picture under Kodak Pictures.
You should be done.
Let me know how it works out with the Easyshare software downloaded to the computer before trying to load pictures on to the computer.
Jul 10, 2010 | Kodak EasyShare C633 Digital Camera
Camera will not down load to the computer
Try NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Feb 03, 2010 | Kodak EasyShare M1033 Digital Camera
Not loading to my computer
Try using a separate card reader to download your pictures to a folder you create on your desktop.
Sep 21, 2009 | Casio QV-R40 Digital Camera
I loaded my computer using Manager instructions
Does this camera use a memory card? If so, try using a separate card reader to download your pictures.
Sep 06, 2009 | Cameras
Pictures wont down load
If the camera software is loaded and you are connecting the camera to computer.
Remove the softwaree and.
Windows will see the camers as a removable memory device in my computer an put up the scanner camera wizard.
This may reveal more.
You may also have inadvertantly deleted stuff
download www.pcinspector.com
install it to recover any deleted images.
Also try the camera and card in another computer.
Aug 12, 2008 | Cameras
Pictures not loading to computer
Create a new picture folder in the computer
then do the following
1. Format the card in the Camera
if no go
2.purchase another card
if that is no go
3 Replace the camera
If you have access to another card[ A friend or a shop] try it in the camera to establish card fault or camera fault.
At 2 years old a repair would be a viable proposition
Nov 15, 2007 | Canon PowerShot A75 Digital Camera
Cameras Logo
187 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
