Question about Casio Exilim EX-S880 Digital Camera
Battery won't charge - red flashing light!!
I put my camera in the charge cradle but the red light just flashes and the camera does not charge. i can view the pictures on my card and i can access all the menus on my camera but the shutter or anything to do with taking a picture will not work...
what do i do?!
thanks!
  • Anonymous Sep 28, 2008
    I put the battery in the charger and the red light just keeps flashing but will not charge the battery. Is it the battery or the charger that is the problem?
  • 477 Answers
You have a bad battery this happens to the NP20 battery all the time get a new batter off ebay for like 5 bucks
Posted on Oct 02, 2008
Battery doesn't charge
Try other lithium ion batteries and charge .. if everything goes fine the old battery is dead or else problem lies in the cradle
Dec 26, 2007 | Casio Exilim EXZ75 Digital Camera
My Casio Exilim EX-S880 wont turn on. Battery is dead but the camera wont charge on the charger. The red charger light is flashing when then camera is placed on it. This red light used to stay on...
I found this while trying to solve my exact same problem.. It worked for me after about 7 times. Some other people on the site said it worked for them after 20 times. Good luck!
My NP 20 gave me the flashing red light of death and I got Casio to replace it. Then I had the same problem with my second NP 20 so I dug around for a way to fix it and I found the following advice on a site called FixYa. It worked instantly and I didn't risk ruining my battery.
ylu1 writes:
I had the same problem as this.
what i did was...
i kept putting the battery on the charger then took it off as soon as the red light came on.
i did this about 6 times.
doing this puts a bit of charge in the battery each time before the charger starts to flash.
after the battery as got enough charge in it it can start to charge.
hope this helps.
Aug 05, 2009 | Casio Exilim EX-S880 Digital Camera
My casio ex s880 won't turn on. when i put it on the charger cradle the red light flashes (it normally doesn't flash). Also when its on the charger it'll let me view my pictures on my memory card it just...
It happened to me. I fixed it by luck . Here is my way . fully charge the camera till the led turns green. "IMPORTANT" unplug the power of the charger first, then remove the camera from the cradle . Then I pressed power button, it worked.
Wish good luck to you too
cz
Jul 18, 2009 | Casio Exilim EX-S880 Digital Camera
EX S880 not charging
you have a bad battery common when the battery sits to long with out being charged they are like 5 bucks on ebay.
Aug 05, 2008 | Casio Exilim EX-S880 Digital Camera
Battery will not charge
Here is how you fix the problem (without using a 9V battery method...).
The battery doesn't charge because it's been fully discharged.
What you do is you put the camera into the cradle. Now you see that the Red LED comes on solid for a while. It's charging for a few seconds. Then it starts blinking. When it does that - TAKE THE CAMERA OUT of the cradle.
Now put the camera back and repeat. Do this six or eight times. Each time what's happening is that the battery is getting a tiny bit of charge. After 8 times the LED will come on red and stay solid red.
Bingo, no problem!
Jul 10, 2008 | Casio Exilim EX-Z57 Digital Camera
Digimax i5 problem charging battery
■ Charging LED
Charging LED
Red LED is on = Being charged
Red LED is blinking = Charging error
 Green LED is on = Charging is complete
● If the charge indicator blinks as red, it indicates a battery charging error.
- The battery is not properly inserted
- The terminals of battery are dirty or damaged
If the battery is inserted properly and the charge indicator continues to blink, contact the
nearest Samsung Camera Service Center.
If the charging LED doesn't turn to green could mean a signal that the battery is bad or can't charge 100% anymore = too old, needs a new battery. Hope this helps.
Jul 06, 2008 | Samsung Digimax i5 Digital Camera
Battery charging
i have not used my camera since June, when i went to charge the battery the other night the Red light just kept flashing even after leaving it for 8 hours, i can get pictures from it which are stored in it but the shutter will not open whilist in and out of the cradle.
May 28, 2008 | Casio Exilim EX-S880 Digital Camera
WON"T WORK
sounds like a dead battery. Plug the origional charger into it and the front led (below the flash) should flash red. If the red led in the back of the camera flashes or stays lit, then you have the wrong charger plugged in. (the camera won't power up if the back red/green led is on when plugged in)
May 08, 2008 | Jazz DV-179 Digital Camera
Casio Exilim EX-S880 Digital Camera Logo
127 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
Are you a Casio Camera Expert? Answer questions, earn points and help others
