Question about Kenmore 3.8 cu. ft. HE3t Front Load Washer
I have blew threw the clear tube and it still over flows?
When the machine is overflowing we just pull out the control knob and it quits, I was able to get at the tube that runs from the level switch to the bottom of the tank and blew in it and it appears to be clear, did not make any difference. I ran several test runs outside holding the drain up higher and this did not make any difference. There appears to be no pattern when its going to overflow?
Pat
    Genius:
  • 1,028 Answers
I assume it's a top load and not a front load ..could be bad pressure switch,small hole somewhere in clear pressure switch hose or least likely a hole on inside within air dome area but not through tub to cause leak
Posted on Sep 28, 2008
Pilot light blew out by a fan..I turned the control off..How do I Ignite Please
First locate where to light pilot. You can do this by following thin aluminum colored tubing from control valve to inside heater.In general on top of your gas control valve is a knob. Turn indicator of this knob to pilot and depress knob. This will start gas flow to pilot at end of thin tube. Hold this knob in the depressed position and light pilot. DO NOT release knob for 30 -45 seconds. Then release knob and pilot will remain lit. Then turn knob to on position. If pilot will not stay lit you may need a new thermo coupler, which senses heat from flame to keep pilot gas flow open.
Good luck
Mar 10, 2015 | Heating & Cooling
Maytag Performa washer overflows when filling on any size load. Will stop when I push in the timer knob.
Overflow is usually caused by a "stuck-open" fill valve, with the cold water half of the valve 'sticking' open from sediment buildup inside the valve.
This can also be caused by the fill system control components: pressure switch, pressure tube, or pressure tube dome/port. So let's take a look at these.
First of all, determine whether your overflow condition is mechanical or electrical. Start the washer filling, then turn the timer off by pushing the knob in. If the fill continues, pull the washer plug. If filling continues with the washer unplugged, you have a mechanical problem - nearly always a stuck valve ***'y. Replace the fill valve.
If however, the fill stops when you unplug the machine, you are looking at an electrical fill control problem, and it gets a little more complicated.
Here a small piece of rubber or plastic tubing is handy. Unplug the washer and open the console where you'll see the pressure switch. This is the switch with a small rubber tube, usually clear, sometimes black, attached. Pull this tube off and replace it with your short tubing. Blow a bit of pressure into the switch using your mouth, and listen for a click, then another when you release the pressure. Hear two clicks? Good! The switch is probably OK
Plug the washer back in (being aware that components in the console are now 'hot' - live electric, use extreme caution , u can be SHOCKED), and start the washer filling again. With it filling, again blow a bit of pressure into the switch. If the switch is good, the fill should stop and the machine should start to agitate.
This verifies that the pressure switch is working, and causes us to suspect the pressure tubing or a clogged port/dome to which it connects. Wipe off the end of the original tube you removed from the switch, and blow into it. You're blowing air down into the tank now, and you should feel very little restriction. If it is very hard or impossible to blow through this tube, the tank dome or port is clogged.
Really old Maytags were known for this, and if you have one, spin out all water, remove the 'Corbin' clamp from the pressure tube outside of the tank and pull the tube off. (Pull washer front off - 2 Phillips screws at bottom, then two 3/8 in. hex screws release top, which swings upward) You will probably see 'gunk' clogging both the rubber tubing and the 'spud' that is a part of the tank. The hose ***'y can be taken to a sink and flushed clean with hot water, and an old toothbrush used to clear the tank spud, which, in the Maytags, is about 3/4 in. ID.
Very important: WHENEVER THE PRESSURE TUBE IS REMOVED, BEFORE REINSTALLING IT, BE SURE ALL WATER HAS BEEN SPUN OUT OF THE WASHER! Otherwise, the water fill level will be incorrect and you'll be back in trouble.
May 25, 2011 | Maytag PAV2300 Top Load Washer
Cannot get pump to turn on to fill circut. I can see water without air from water tank inlet through valve mounted on bottom of machine up towards pump .Pump wont turn on with steam valve rotated to pump...
I think you have something in the flow meter. When the flow meter is restricted on the intake it doesn't turn the flow meter. The spinning turbine is what clears the lights. You will have to take the top off. Pull the plug on the machine from the outlet.
  1. There are 2 screws #1 in the back top of the machine.
  2. Lift the top up a little.
  3. Push the back of the machine at the top away from the main body about 1". This disengages the grinder mount pins. These will need to be engaged when you reassemble.
  4. The tube on the back goes to the flow meter, located under the main boiler and behind the blue steam boiler.
  5. Pry up on the bottom of the flow meter ( white piece with the 2 tubes entering)
  6. Pull out when it is disengaged.
  7. Hold the flow meter in one hand and with the other hand twist the top of the flow meter counter clockwise about 30 degrees.
  8. There will be 4 pieces. 1. The top. 2. The bottom. 3. The O-ring. 4. The turbine with the black dot pointing up.
  9. The plug will be in the top piece on the intake tube. Pull the tube off by pulling the end of the hose on the top piece. Do not just pull the tube.
  10. Look inside the top piece and see if there is an obstruction. Clear the obstruction and the tube of all particles, then reassemble.
  11. The O-ring goes on the bottom piece, then the turbine with the dot up, then the top and push down and twist the top clockwise so the outlet tubes are opposite the 2 legs in the back.
  12. Slip the flow meter back into the machine under the main boiler.
  13. Set the back (black back) up against the back of the body.
  14. Lift the grinder mount (black mount) up a little and pull out on the back until the pins pop into the grinder mount.
  15. Replace the top back onto the machine. Sometimes you have to wiggle the knobs a little to get it to fall into place.
  16. The back part of the top should be flush with the back. To replace the screws you need to push in on the sides to align the holes. I turn the screws backwards first to align the screw holes. Then tighten.
  17. Now plug in your machine. Replace the water tank. Turn machine on. Open knob for water.
  18. Light should clear and machine should heat up.
What causes this problem is removing the water tank and then working with the beans. To prevent this from happening is when working on the water system, keep the lid on the beans, and when working on the beans, keep the water tank on the machine and covered.bansheracer_19.jpgbansheracer_20.jpg
Feb 17, 2011 | Starbucks Saeco Italia Digital Barista...
Water won't stop coming in
There is a small clear hose that connects to the side of the tub near the bottom, the other end of the hose connects to a switch in the console behind the knob for the load size, this tube either came off while you were working on it or it got full of water. If it came off simply put back on but do so with the tub empty of water, this is very important!!
If the tube was filled with water, drain the tub and blow through the tube and reconnect.
May 01, 2010 | Washing Machines
Starting a wash, tub overflows and keeps filling...
Sounds like there's a water level sensor problem. The water level sensor works by reacting to the air pressure in a tube connected to the tank. You need to open up the control panel. You may need to remove some screws, but on some machines you can "pop it" by prying it up with a putty knife. You'll find that the water sensor is the back of the knob that controls the water level. If it's a digital machine the sensor will be somewhere else but connected to a clear plastic tube. The first thing you should check is to unplug the tube from the sensor, and blow in it to make it's not just clogged with lint. If the tube flows freely, you'll need to replace to the water level sensor. This is pretty easy to do.
Dec 07, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Our washer overflowed last night. no warranty on
Overflow is usually caused by a “stuck-open” fill valve, and the cold water half of the valve is usually the culprit. This can also be caused by the fill system control components: pressure switch, pressure tube, or pressure tube dome/port.First of all, determine whether your overflow condition is mechanical or electrical. Start the washer filling, then turn the timer off by pushing the knob in. If the fill continues, pull the washer plug. If filling continues with the washer unplugged, you have a mechanical problem - nearly always a stuck valve ***’y. Replace the fill valve.i f however, the fill stops when you unplug the machine, you are looking at an electrical fill control problem, Here a small piece of rubber or plastic tubing is handy. Unplug the washer and open the console where you’ll see the pressure switch. This is the switch with a small rubber tube, usually clear, sometimes black, attached. Pull this tube off and replace it with your short tubing. Blow a bit of pressure into the switch using your mouth, and listen for a click, then another when you release the pressure. Hear two clicks? Good! The switch is probably OK, Plug the washer back in (being aware that components in the console are now ‘hot’ and start the washer filling again. With it filling, again blow a bit of pressure into the switch. If the switch is good, the fill should stop and the machine should start to agitate.
This verifies that the pressure switch is working, and causes us to suspect the pressure tubing or a clogged port/dome to which it connects. Wipe off the end of the original tube you removed from the switch, and blow into it. You’re blowing air down into the tank now, and you should feel very little restriction. If it is very hard or impossible to blow through this tube, the tank dome or port is clogged..
Whatever your brand, if air can’t be blown back through this tube, the port or dome will need cleaning.
If you have no trouble blowing pressure through it remove the tube completely and inspect it carefully. This tube must not have the smallest hole in it, and we sometimes see them worn through or, more often, chewed through by mice. while it is the least common cause of overflow, it does happen and is easily overlooked. sometimes this tube will swell and loosen a bit, leaking air where it attaches to the tank fitting. If you suspect this, or the tube fits very loosely, simply cut 3/4” or so off the end and push it back on.
Sep 30, 2009 | Kenmore Washing Machines
Air blown threw overflow tube, well it hurt anything
If your car is overheating and you are getting alot of air in the overflow tank. The air is caused by a blown head gasket the air is compression from the motor. Remove the spark plugs the one that is real clean is the one that the head gasket is leaking into. You should also be seeing white smoke out the tailpipe that is the antifreeze burning in the cylinder. When it burns it will clean the cylinder and the spark plug.Good luck I just had the same problem with a 3.1 in a Cutlass
Apr 07, 2009 | 2003 Chevrolet Malibu
Maytag Washing Machine - water will not shut off and overflows tub
this could be either a bad pressure switch, located behind the control panel. it has a small usually black hose running down to the tub. more than likely since this is an older machine the hose has become worn in one spot and is leaking air. replace the hose and that shold do it. if not its the presasure switch.
Nov 28, 2007 | Washing Machines
Washing machine overflows
sorry in advance for the lack of appropriate terminology. my "solution" comes from a mother with no mechanical experience point of view.
i had the same problem with my washing machine overflowing. I opened up my machine, found the clear hose that went from this little square box on the side of the tub up to the switch for the "load size" knob. i pulled the hose off the square box and saw that there was a piece of paper in it. i pulled it out, scraped the scum out and reconnected it. started the machine. - that didn't work.
so, I got the thinnest pipe cleaner i could find pulled the tube from the little box, and stuck the pipe clearner down the pipe of the little square box. pulled out a bit of scummy lint, then I blew in the tubing. I heard a "click", I thought.. okay maybe that's it. reconnected everything, started my machine.. and now it works :)
This probably wasn't the proper thing to do, but it worked and saved me from the cut throat washing machine mechanics in this area.
Nov 10, 2007 | GE WBSR3140DW Top Load Washer
Washing machine
Almost, I hope you put the tube back on. This goes on the pressure switch and the pressure switch determines when the tub is full according to the load size. I don't know what post you read, there's been so many. You have a couple of things to check here. First, make sure the hose going from the pressure switch to the tub is clear. Blow through it. If it's clear it's possible you have a faulty pressure switch. If that tube is not secure on the switch and the tub you will overflow. If the pressure switch is faulty, you can overflow too. Catriver.
Aug 24, 2007 | Kenmore 45081 Front Load Washer / Dryer
Washing Machines Logo
43 people viewed this question
Sal De GO PATS
fordexpert
Ed Mac
