Question about Miele Vacuums
Meile S548. It work turn on expect when I fiddle with retractable cord. Even then, it's prone to stop again. The machine is relatively new and shows no cord wear.
  • ikcycles Sep 30, 2008
    same problem. I need to know how to get access to the conntacts to be able to repair.
  • 37 Answers
You have a bad cord reel. the cord may look fine but its the contacts inside that have gone bad. i have had some luck with simply adjusting the contacts but probably need to replace the cord reel.
Posted on Sep 28, 2008
VC248. Why won't the cord retract?
Vacuums today are most all plastic parts, and you have likely accidentally broken the retractor. Very highly likely you will be wrapping the cord around the machine from now on, as the repair parts are probably not available.
God bless your efforts.
Sep 07, 2015 | Cirrus Vacuums
Bounced down a step while on, blew house circuit breaker, now s548 only powers on when on its side
Rickhan,
I would recommend taking it to a Miele dealer and let them repair it. It can get rather tricky trying to put those back together. I speak from experience and I work at a Miele dealer and I leave them for the other repair tech.
Jul 04, 2015 | Miele S548 Bagged Canister Vacuum
How do I repair my Electrolux Lux 9000 cannister electrical cord retraction? It was pulled out as far as it would go and now it doesn't retract.
First, try standing vacuum on it's back end. Gently pull on cord and release. Try this a few times.
If this doesn't work, you'll need to take it to an authorized Aerus Electrolux store and let the service tech repair it. Although it's relatively easy to disassemble, reassembling correctly is trickier. I've had several machines come into the shop disassembled because the owner couldn't figure out how to put it together again.
Also, when taking the cord rewinder apart, there's a risk of breaking tabs that hold it together.
http://www.aerushome.com/storelocator/
Dec 19, 2010 | Electrolux Lux 5500 Canister Vacuum
Have a miele S546 vac. and it won't turn on. Is there a fuse? Can the on/off switch burn out? Thanks.
If you vacuum wont turn on it is most likely the cord winder. This is a pretty big repair, you wouldn't want to attempt it yourself. Most shops should be able to repair the cord winder for about $50-75. If you need a new cord winder expect to pay about $150.
Oct 13, 2009 | Miele S548 Bagged Canister Vacuum
Electric cord won't retract
Depends on the machine. If its a Sebo K model then usually pulling on the cord will re-automatically retract the cord anyway. Any other brand and it will need to be replaced by a qualified repair.
May 06, 2009 | Vacuums
Power cord will not retract on my Electrolux UltraLux 2000
You will need to take the machine apart to correct this. Open the front of the canister and remove the bag. As you are looking at the front of the unit, there are two vinyl covered strips that run the length of the unit. Pull forward on these strips and then pull out so that the vinyl separates from the plastic underneath. Now grab the plastic strip with a pair of needle nose pliers and pull towards the front of the canister. These can be tough if the machine has never been opened up before, but pull as hard as you need to, to slide the strip out. Once both strips are out, turn the machine over, pull out on the sides of the bottom of the unit, and lift up. The bottom should come off relatively easily, and everything will be exposed. Now, assuming that the cordwinder isn't damaged, you should be able to wind the cord in by hand. Once it gets started it may start to retract automatically. Usually the spring just gets in a bind against the housing when it's over extended, and rolling it in by hand a little will free it up. Good Luck!!
Dec 18, 2008 | Electrolux UltraLux 2000 Bagged Canister...
Sebo K 3 Vacuum
I had a problem with my K1 Komfort model which sounds similar to this. I initially thought the cord was too short but the machine wouldn't give out anymore and retracting was difficult. A Sebo engineer/helpline told me to pull roughly on the cord, of which I did and was rewarded with 2 metres more than what I thought I didnt have! So, perhaps if your machine isn't retracting properly, give the cord a rough pull with gloves on, or a strong grip - the cables on the K series are notorious for stopping up. Afterwards wipe the entire cord down with furniture polish; it will retract much more quickly.
Feb 21, 2007 | Sebo Air Belt C3.1 Bagged Canister Vacuum
Vacuums Logo
176 people viewed this question
Top Miele Vacuums Experts
Mack Baxter
Colin Stickland
Colin Stickland
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
