Below is a standad mac fix-all and a quark fix-all but it could be something else that has happened, after looking on forums there appears to be a problem with this type of problem which quark never bothered fixing in 6.5. I would also instal the quark update from 6.5 to 6.52 from http://www.quark.com/support/downloads/Details.aspx?fid=122 before you do this it may correct it.
Mac Fix-All
Another thing I would do is go to the applications folder and then the utilities folder open up disk utility once opened click on your hard drive and then click on repair disk permissions and let it complete the verification and repair (it could take 20 minutes or more) depending upon the size of your hard drive. A lot of people do not this but to keep your machine running efficiently it should be done on a monthly basis.
Quark Fix-All
It could be that your quark preferences have corrupted, I would go to your users folder then go into the library folder, then the preferences folder and then the quark folder within the quark folder there should be a file called "XPress Preferences.prf" move this to the trash (But do not delete it yet). When you open quark next it will recreate the preference file and hopefully that will sort it out. If this has corrected the problem you can then delete the file in the trash. Please note that you will have to reset your preferences once you open Quark again.
Hope this helps in some way.
