My verizon Starzplay essentials and extas broadband will not connect. The starzplay will download up to 53% then an error message will appear that saiz offline, and reconnect but every time i try to reconnect the same thing happens again.i woul appreciate if you could helpme get to the bottom of this problem so that i can start to enjoy The Starzplay package Respectfully Submitted Ms. Linda Archibald starsandmoon1@verizon.net
    Problem Solver:
  • 20 Answers
Make sure the ip adress is good or right to match
Posted on Sep 28, 2008
Cannot connect through verizon dsl westell 6100g modem
Call verizon dsl and make sure you have your account username and password (given to you by verizon when the connection was put in your home) when you get them on the phone. also make sure you have the username and password for your Linksys device.
Aug 14, 2012 | Linksys Wireless-G Broadband Router
Tip
How to resolve "Limited Or No Connectivity Errors" in Windows
When attempting to set up or make network connections on a Windows computer, you may encounter a Limited Or No Connectivity error message similar to the following:
Limited or no connectivity: The connection has limited or no connectivity. You might be unable to access the Internet or some network resources.
This message can result from any of several different technical glitches or configuration problems. Follow these steps to resolve Limited Or No Connectivity errors in Windows.
1. Determine whether your network access is functioning properly (that you can reach local network resources and the Internet). If you are using a broadband Internet and Windows XP Service Pack 2, this message is often a false error report. See Microsoft Knowledge Base article 892896 for details on how to work around this error appropriately.
2. If your network access is non-functional. continue to the following steps.
3. If your computer connects to the network through a broadband router , resetting (powering off and on) the router may resolve the issue. If not using a broadband router, or if resetting your router only temporarily resolves the issue and the error message re-appears later, continue to the following steps.
If connecting to your network using Wi-Fi and using wireless security, your WEP or other security key may not be set properly. Check the wireless security configuration on your computer's network adapter and update if it necessary.
4. If connecting to your network using an Ethernet cable, your cable may have failed. Temporarily replace your network cable with a new one to determine whether this resolves the issue.
5. If using a broadband router and DHCP on your network, check your computer's IP address to verify it is valid and not a private address that starts with 169.254. An invalid address of the form 169.254.x.x signifies your computer's inability to obtain a usable IP address from your router.
To resolve DHCP configuration problems, proceed to the following steps.
6. Reboot your computer, router (if present) and broadband modem together, then re-test your connection.
7. If your connection remains non-functional, run the Windows Network Repair utility on your computer.
8. If your connection remains non-functional, update your router settings to change from dynamic to static IP address configuration, and set an IP address on the computer appropriately.
9. If your connection remains non-functional, unplug your router and connect the computer directly to your broadband modem. If this configuration is functional, contact the manufacturer of your router for additional support.
10. If your computer is connecting to your network directly through a broadband modem, or if your Internet access remains non-functional after following the instructions above, contact your Internet provider for support.
on Jul 20, 2010 | Computers & Internet
Tip
Solved Problem on Limited Or No Connectivity error message
Solving Limited Or No Connectivity error message
On setting up or make network connections on a Windows computer, you may encounter a Limited Or No Connectivity error message similar to the following:
Here's How:
Determine whether your network access is functioning properly (that you can reach local network resources and the Internet). If you are using a broadband Internet and Windows XP Service Pack 2, this message is often a false error report. If your network access is non-functional. continue to the following steps.
www.temabcomputerssolution.blogspot.com
on May 20, 2010 | Computers & Internet
Blue Screen hardware error on new HP g series notebook pc
It appears you have a faulty notebook. This can happen if the notebook come from the same batch of units that could be faulty.
I suggest you return the notebook to the store and get it fixed under warranty.
Mar 08, 2012 | HP Pavilion G60-120US NoteBook
I just bought this router and am trying to get it connect with a Verison wirelss USB mobile broadband. How can I connect it to my computer and an Xbox 360?
For Verizon i found that Currently, the DIR-412 Mobile Broadband Wireless Router is the only D-Link router that is 3G compatible. The DIR-412 supports 3G USB adapters complying with HSUPA/HSDPA/EV-DO/TD-SCDMA networks and works with most major cellular carriers (AT&T, Sprint, Verizon, Rogers, Telus, Bell, etc).
D-Link routers empower gamers to easily connect their Microsoft Xbox to network and experience lag-free online gaming. All you need is a D-Link router to go along with your broadband connection and Xbox Live subscription and you can go head to head with friends and adversaries from around the world.
The D-Link DI-624 Wireless Broadband Router, DI-614+ Wireless Broadband Router, and the D-Link DI-604 Broadband Router have all passed the tests for compatibility with Microsoft Xbox Live with specific firmware. Just download the specific compatible firmware listed below to your D-Link router before connecting to Xbox Live.
  • Click here to upgrade your firmware.
  • Click here for Xbox Live setup instructions with a router.
  • For Xbox Live support, please visit www.xbox.com.
  • If you need more help come back.
    Post / thumbs / testimonial are welcome!
    Dec 22, 2010 | D-Link DIR-628 Wireless Router
    My router is on, and is hooked up to my verizon modem. My xbox 360 and my computer are both hooked up to the router and all the lights are on but only my computer is working for the internet where my 360...
    with verizon, you need to set the modem to full bridged mode so that the connection from your modem will be opened. This certain firewall is called NAT. Your modem and your router has this feature. To disable NAT on your modem, you need to set it to full bridged mode. To disable the NAT on your router, you need to open ports on your router.
    You need to open this port on the router for Xbox live to work
    TCP: 80, 3074, 53
    UDP: 88, 3074
    forward it to the ip of your Xbox.
    this should set the NAT on your xbox to open, not moderate.
    Sep 18, 2010 | Dell TrueMobile 2300 Wireless Broadband...
    Ive got verizon wireless broadband for my lap top and cant seem to be able to get online with ps3
    Can you provide more information?  The Verizon Wireless broadband access is for your laptop only.  In order for the PS3 to take advantage of it, you'll have to setup Internet Connection Sharing on your laptop. That way your PS3 can connect to your laptop via your laptop's wireless connection (in Ad Hoc mode since you don't have a wifi network) and access the internet via the VzW Broadband Access.
    Dec 25, 2008 | Sony Playstation 3 (PS3) Console
    ISP blocking my internet connection.
    hello!
    -- do you know your verizon username and password?
    -- what is the operating system of your computer?
    -- have you tried connecting your computer directly to the modem to check if you can get online?
    you may try this and see if this help solve your problem. make sure your computer is directly connected to the router
    Step 1: Shutdown the computer.
    Step 2: reset the router while power on then Unplug the router’s power cable.
    Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
    Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
    Step 5: Plug in the router's power cable once the modem’s lights appear stable.
    Step 6: Power on the computer on and configure the router settings, you need to input your verizon username and password on the router setup page then save the settings.
    Step 7: test the Internet connection.
    if this still didnot work, upgrade the firmware of your router
    May 26, 2008 | NetGear WGR614 Wireless Router
    Verizon broadband wont connetc though it finds the network on q1 with XP.
    If your bills are clear and the service from the ISP is ok then check the drivers for the usb modem , remove the drivers and the software running the modem , remove the modem too . first install the software and drivers then connect the usb when required . The com settings can be configured from the control panel
    Nov 18, 2007 | Samsung Q1 Tablet PC
    Computers & Internet Logo
    42 people viewed this question
    David Payne
    David Payne
