Question about HP PSC 1350 All-In-One Thermal Printer
Installing printer cartridges
I have an all-in-one printer; haven't used it in several months. Took the cartridges out today to take to the store with me to buy new cartridges. I got home and, ridiculously, I can't figure out how to put the new cartridges in. It seems like before, when I was using my printer regularly, that they just popped in. Now, I feel like I'm forcing them and am afraid I'll break the printer. Please help me with this insane problem.
  • lori jay Sep 29, 2008
    worse yet! I managed to get the #58 into the slot for the 57 and it won't print and it won't come out. I am encouraged that you only posted yesterday... maybe someone can help me... or maybe like you I will fix it myself (I hope)
It was the stupidest mistake in the world. I was trying to install the color cartridge into the black slot. Whew!
NOW, however, I can't get the printer to print. The printer keeps telling me "error/offline" ~ I've tried changing the setting but to no avail. I'd appreciate it if you could give me some advice. If it helps, this is a 3 in one and it won't even copy a page NOT coming sraight from the computer. Thanks. bd
Posted on Sep 28, 2008
Haven't used printer for several weeks, although ink in cartridges print barely visible, tried new cartridges with same result
Dear plloyd, You had left the printer many times, which indicates that the printer heads are jammed due to non use. So go to the printer property in control panel - printer and faxes - your printer. In printer property go to maintenance. There is the option of head cleaning. Run the head cleaning programme twice or thrice. You will see, your old cartridges also can work. Thanks.
Sep 05, 2011 | Kodak ESP 5 Printer
What does 'Print Cartridge in right stall not supported' mean?
It means you have a faulty or incorrect cartridge installed on the right side position. It could also mean the contacts are dirty or misaligned. Remove the cartridge, clean with rubbing alcohol and reinstall.
This is not a unknown error particularly if you are using cartridges other than the HP brand. Other people will tell you it is fine to use off brand cartridges or refilled cartridges. For myself, I have never had luck doing that - on the other hand, I have never been disappointed using the more expensive cartridges recommended by the manufacturer across several brands including Epson, Canon, Compaq and HP.
Try cleaning the contacts and ink jets. You may have to replace the cartridge. If that is the case, I would return the faulty cartridge and get a store credit.
Just a few thoughts for you to consider. Thank you for using FixYa.com today.
Mar 03, 2011 | HP PSC 2355 All-In-One InkJet Printer
Hp 5510 printer/copier/fax/scanner will not print docs. The paper goes through but nothing is on the paper. Tried to print test page, same result. I've checked the cartridge - not empty. Haven't used the...
It sounds like the jets on your cartridge is plugged. I have unplugged some cartridges by soaking the jets in alcohol. I pour some alcohol in a shallow dish and set the cartridge in it with printing jets down. Leave it for 5-10 minutes. If the jets start to unclog you will see the ink discolor the alcohol.
Be careful when wiping off the ink jets so you don't damage them. Use a soft cloth. Try the cartridge and see if it prints. If you need to soak it longer.
Jul 13, 2010 | HP Officejet 5510 All-In-One Thermal...
My 750 is telling me "incorre3ct blaxck cartridge installed. Have been using HP15 for several months and it accepted thgem ?????
This happends when the print head dies it is not detecting the cartridge.
Things to try is call the manufacture for any firmware changes (they may have changed the cartridge a tad this happend with my lexmark i know theren ot the same manufacture but still try that.
if that does not work then the print head needs to be changed out I mean you got no other choice if the first solution does not work.
Thanks for allowing me the time please do leave psotive feedback and ratings for your free answer today.
Apr 28, 2010 | HP PSC 750 All-In-One InkJet Printer
Incompatible print cartridge - tri color
Here's two possible solutions...you can replace the cartridge as some times they can be prone to electric/electronic problem which renders them useless. You may be able to return the defect cartridge.
Option two is to reset the printer by following these steps:
1)Make sure your cartridges are installed.
2)Unplug the power to the printer and wait about 20 seconds
3)Press and hold the # and 3 keys (while unplugged)
4)Plug the power back in (you should see a reset message on the machine)
5)Release the # and 3 keys and follow the prompts
Mar 02, 2010 | HP OfficeJet J4580 All-In-One Laser...
Printing problem
You will need to clean cartridges and printer head with cotton swab and rubbing alcohol. Some printers have a self-cleaning diagnostic setting on them.
After thourough cleaning, print test page and use alignment if necessary.
May 15, 2009 | HP LaserJet III Printer
Printer will not work after installing a new ink cartridge?
did you see a piece of plastic stuck on the back of your cartridge?
Mar 21, 2009 | Lexmark C533DN InkJet Printer
All Cartridges show as empty though I know they are full.
You had it for 7, they have a 12month warranty, take it in for free repair.
Dec 17, 2007 | Epson Stylus Photo R260 InkJet Printer
Lexmark x6150 won't print after being stored
If you havent tried this already......try to reprint several times......this has worked for me in similar situations......you may just need to give the ink a chance to do its thing
Dec 12, 2007 | Lexmark X6150 All-In-One InkJet Printer
HP PSC 1350 All-In-One Thermal Printer Logo
37 people viewed this question
Seeker5211
Seeker5211
