Question about Refrigerators
I HAVE A 03 25CU SIDE BY SIDE REFRIDE JUST PURACHED TWO DAYS AGO WORKS FINE BUT GET VERY WARM BETWEEN BOTH FRT DOORS
  • 943 Answers
Hi. thanks for the question. the heat that you feel by the door is normal. if that heat was not there moisture would build up & run down the space between the doors and cause rust so the heat is normal thanks the appliance is that a fix ya
Posted on Sep 28, 2008
Freezer too warm, and i feel heat on the door seals
The door seals warm is from the mullion heater that minimizes moisture from forming in that area, under working conditions. You need to provide more information.... What did you see that made you defrost it 3 weeks ago..
Nov 27, 2013 | Kenmore 53542 / 53544 Side by Side...
Freezer ices up and fridge part warm, timer changed worked well for 2 weeks model frt 163ag no frost fridge
Hello Claire Trancoso - If the refrigeration side is the one with the issue, you need to check the damper door/switch that is between both doors. In side by side units this damper controls the cool air from the freezer to come over to the refrigeration side to cool it. Contact a professional technician to diagnose if the unit has a floating restriction, an issue with the evaporator fan or a possible air leak.
Dec 17, 2012 | Frigidaire Gallery Series GLHS269ZDB 36"...
Refrigerator light and temperature display not working
Check that the wires going to the temp. display has power on them, if "yes" change temp. display......
Lights the powre goes to a switch on the door frame that sends power to the light in refrid.
Dec 14, 2012 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Two days ago refrig worked fine. Yesterday it got warm. Light still go on
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 16, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Blows cold frt pass vents /warm air drivers side
see if freon is low ,if not ,u have a vent door actuator motor bad
Jul 07, 2009 | 2003 Toyota 4Runner
1997 Toyota Rav4 doors are locked
over time the grease in the locks etc can become frozen and stop movement when its warmed up a bit it will move better, using the key on the doors every now and then helps move this greas about as the central locking wont move these parts only the switches, replacing the grease after a degreasing locking mechanisms inside the door on the rear of the lock should help choose a grease that can handle low temperatures.
Jun 07, 2017 | 1997 Toyota RAV4
Side by sise refrid freezer top is not cooloing on freezer side warm on refergerator side
suspect fan is not working - can you hear fan?
if not, chances are fan is jammed with ice build up. take back panel off inside freezer and if there is ice build up, melt off with a hairdryer. also check for continuity thro fan and make sure it rotates freely
Oct 09, 2008 | Whirlpool Refrigerators
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
