Question about Refrigerators
I just replaced my fridge fan and now it created a lot of ice. The fan actually gets stuck in the ice. What is the problem?
  • 943 Answers
Hi. thanks for the question .the foam in the freezer, where the fan is. gets saturated with moisture. . thaw the fridge out completely . then use hair blower to dry the foam .dryit a lot then reassemble . it will happen again . but not for a while thanks tats a fix ya.
Posted on Sep 28, 2008
When we shut the fridge door a loud continuous humming noise comes from the fridge. This seems to be activated by the door light switch at the top. Thank you
There are 2 possibilities I can think of for the hum. When you activate that door switch it activates 2 fans and the compressor. There is one fan located on the compressor and one located in the vent system in the fridge. The second fan is used to circulate cool air evenly through the fridge. I would recommend holding your finger on the door switch and listen carefully whether the noise is coming from inside the back of the fridge or from the lower bottom. Lower bottom could indicate compressor cooling fan or compressor. They would need to be inspected. If it sounds more like the other fan mentioned above it would again need to be inspected. The compressor cooling fans can get stuck or become noisy due to bearing failure. The vent fan can get stuck or noisy but also in some cases if the defrost circuit is not working can chock up with ice and create a buzzing noise as the fan blades strike the ice.
Jan 13, 2017 | Refrigerators
The refrigerator side is cool, but not cold. The freezer side is frozen, but melting. The ice in the ice maker melted, but created one big ice cycle that has not melted. The fan underneath is running,...
I just ran into this problem this year. Is it very warm underneath your fridge? If you remove the cover in the back, you may find that you compressor is so hot you can't touch it. You can first try blowing out your cooling fins in the back of your fridge. A fan is connected to it and it should be next to the compressor. For my case that did not work. I then replaced the fan for the cooling fins and now my fridge works fine.
Nov 10, 2012 | KitchenAid KSRS25FG
Fan make noise
There are 2 things in that area that can make a noise, the ice maker,and an evaporator fan,depending on the model.The fan is an easy fix if the blade is just hitting something ,but you have to be abit mechanically inclined to get to it.The icemaker has a little motor that sometimes gets stuck in the ice harvest mode,then you just have to unstick it ,also depending on what kind of fridge you have..everything else is down at the bottom,compressor,condenser,ect. In any case you probably want to call a tech unless its old,because repairs would be more than it is worth.
1. Open the freezer to see if the noise gets louder. If the noise becomes louder with the freezer open, the noise is likely caused by the evaporator fan. If the evaporator fan is the culprit, replace it to get rid of the noise.
2. Take raer panel off inside freezer and check there is no ice build up which is hitting the fan
3. Pull the refrigerator away from the wall, and check the condenser fan at the back of the fridge. A metal panel may cover the fan, which can be unscrewed. Listen to see if the fan is the source of the noise. If it is, the fan may need to be cleaned or replaced.
4. Unplug the refrigerator, and listen to the back side of the fridge. The fans will immediately stop running. If the back of the fridge continues to make a noise after the fans have shut off, the sound is most likely coming from the compressor, which is located at the back of the fridge, near the bottom. If you have a compressor problem, you either have to replace the compressor or the entire refrigerator.
Oct 04, 2012 | Refrigerators
Freezer side is working fine. the fridge side appears not to be as cold as it use to be. a few days ago my kid left the door ajar all night. how ever it should be cold by now. there is power I can hearthe...
When a refrigerator door is left open the freezer will continue to run to keep it cold and since it can't cool an open area it will freeze up on the inside, to resolve this you will need to unplug the fridge and open the freezer door and allow the freezer to thaw completely, once it is thawed you can plug it back in and everything should go back to normal after a 24 hour period
Jun 28, 2011 | Kenmore Side by Side Refrigerator
The freezer works the frig doesnt get cold but its not warm just mild
open the freezer and at the back is a fan with a cover check the fan operation and housing if fan iced over or ice or debris blocking [food bag ]clear and check operation if fan doesnt work at all check power if power good replace fan if fan good check in fridge side for operation of flapper where air from freezer enters may be stuck or blocked air from freezer controls ur fridge side --if freezer side works than one of above problems which are the most common should get u back on line
Jan 19, 2011 | Admiral Refrigerators
LG french door fridge - makes hideous noise - loose bearings? - whenever fan is running, which is several times an hour. Any idea what is causing it? Husband tried to grease the fan. It's really...
A broken fan blade can cause a noisy motor. or a buildup of ice can cause some noise. If thes aren't the case you will need to have the fan motor replaced.
Jan 04, 2011 | LG LRFD25850 French Door Refrigerator
Samsung SRS583HDP fridge not cooling. Side by side
Most likely the thermostat in the fridge, especially if it read 5 degrees until you reset it. Possibly the compressor in the fridge side as this fridge has twin cooling, or the circulating fan in the back of the fridge is frozen, which is a common problem as well.
Easiest things to try is to see if the fan is frozen and check if the fridge cooling is actually working. Turn off the fridge, remove the shelves, remove the 4 screws that hold in the bottom cover and the 2 screws that hold the water tank in. Cover should then come out a few inches. Reach behind and unplug the 2 plugs and pull out the cover. If the cover doesnt come out easily it may be glued to the back of the fridge by ice. Leave for a couple of hours and gently prize it off. Check for ice around the fan and that the fan spins freely. You could try sitting the cover inside the fridge, plug it in turn it back on for a few minutes (be careful) and then open the door and quickly look / listen to see if the fan is still spinning (it stops when you open the door). Leave the fridge off for a while until the ice disappears off the coils. Turn back on for half an hour. The coils should be icy again. Anything else call Samsung. If the deal in your country is the same as mine the fridge has a 2 year warranty but in the fine print the sealed compressor unit has five years on parts only. You could get the unit replaced for labour costs only. Check your warranty card.
Jun 22, 2010 | Samsung Refrigerators
Refrigerator the freezer is cold but other side is not, when I have the freezer door open cold air blows through the vent to the other side through the vent
First thing to try is Powering off the FF at the mains supply and leaving it standing for 30 minutes. Make sure that you do not open any of the doors or touch any of the controls during this time. Then reconnect the power and wait for 30 to 60 minutes to see if the fault remains or is cured.
In side by sides if the freezer side is working OK and the fridge side is not working correctly it means that the air vent from the freezing unit to the fridge compartment has stuck in the closed or partially closed position which causes the fridge to not be any where near as cool as it should be. If it is too cold then the vent is stuck in the open position and the fridge temperature will continue to fall and become the same as the freezer, thereby freezing the contents of the fridge compartment. It can also get stuck in another position so that if the temperature is adjusted on the front panel then nothing happens to the temperature in the fridge compartment. The vent, which is usually at the tope of the fridge compartment on the side where it joins the freezer compartment, is controlled by a small sync motor and either the motor has become faulty, the control module is faulty or the vent is iced up. It can be come iced up by putting too many hot items in the fridge so the steam condenses and freezes the vent in position and then the motor cannot open or close it causing it and / or the control module to become faulty. Other times it is just old age that causes the motor and / or the control module to fail. If the sync motor and vent are working Ok then there may be a fault with the fridge temperature sensor or main on board controller that will mean that the sensor or the controller will need replacing.
Also worth checking the return air path from the fridge and making sure it is not blocked or frozen up. Also check the freezer compartment and cooling panel at the rear (behind the cover plates) and the fan for icing / blockage up as it sounds like there is a mini vacuum being created when the freezer door is closed or you have too much in the frezer so it presses on the back plate and stops the mini fan circulating air to the fridge.
Oct 30, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Too warm both freezer and fridge recently ice cubes melted when opened a lot.
5 reasons for fridge and/or freezer getting warm: 1- the evaporator coils are icing up and won?t let air circulate. 2- the evaporator fan is not working to circulate air. 3- there is no refrigerant in the system. 4- no power to fridge or compressor. 5- the condenser coils have no air circulation check under the fridge behind the vent. if it is too dusty or the fan isn?t working, it is not getting enough airflow to cool down. replace fan and/or vacuum out the dust. if there is no power to the fridge, the light will be off. if the compressor is not running, there is a defrost timer that cuts the power temporarily to the compressor to melt ice on the coils. it?s located under the fridge behind the bottom vent. If the timer is off and the compressor is not going, the compressor or the main board is bad and needs replacing. there is also a temperature sensor on the evaporator coils that tells the defrost coil to turn on and when to turn off. if the defrost timer is on but the coil is not heating up, replace the sensor. if it still won?t heat up, it?s the timer or the coil. the easiest way to tell if there is no refrigerant- the freezer wall is warm and the compressor is loud. if there is no refrigerant, it may be more cost effective to replace the fridge. if you feel no air coming from the freezer vent, the fan needs replacing. If you feel air moving in the freezer but not the fridge, the channel from freezer to fridge is blocked. if the freezer has air and the rear freezer wall has frost on it, the evaporator coils are iced up and need defrosting. causes: 1. low refrigerant 2. no fan 3. too much humid air in fridge/freezer due to door open or bad door seals 4. the condensate drain tube is clogged if the seal around the door is ripped or not completely sealing, or there is condensation at the bottom or the walls of the fridge, replace the seal(s). no air, no fan. Replace if the refrigerant is low, it just needs a top off. but you need to be certified by the epa to move refrigerant, so get a professional. defrost solutions: unplug the fridge. remove the wall of the freezer that is frosted/icing up. use a hair dryer to melt the ice. do not get too close. you will see a drain under the evaporator coil. make sure it is not blocked. the water should run freely to a condensate pan under the fridge that evaporates the condensation with the hot line from the compressor. once the coil is free of ice, frost, and water, replace the panel and repair any of the problems that caused the icing up. plug the fridge in and turn it on. If it frosts up within a week, there is still an issue that not been taken care of.
Aug 28, 2009 | Admiral Refrigerators
Ice maker feeding too much water and overflows
I have the GE Profile TFX24PR that exhibited the same symptoms. I had water leaking, making ice in the bottom of the ice bin, as well as under the ice bin. I also discovered ice down the back wall of the freezer.
A technician replaced the ice maker, which did not solve the problem. He put the original back and replaced the valve on the back. That too did not solve the problem. I took matters into my own hands.
I discovered that the ice maker water fill tube that comes in through the back of the freezer wall was leaking. Water would run down the outside of the tube. Some of the water would go into the ice maker, some would go into the ice bin and some of the water would also run down the wall of the fan housing where it passes through a hole in the fan housing. The big problem was the water running down the wall of the fan housing. From there it ran onto the cooling coils, where it would freeze, causing the freezer to go into extended defrost. My freezer and fridge would warm up and I had some food spoil.
If this looks like it may be your problem, you may want to enlist some help for this; it is tedious, time consuming and requires working in the confined spaces of the freezer.
After disassembling the fan housing I was able to access the fill tube. It just pushes in and is prone to wear, especially after fourteen years. I just reversed the ends of the tube and pushed it back in for a snug fit. You may want to consider using a sealer. Everything is working fine now; lots of ice in the bin, and no stray ice or water.
Nov 21, 2008 | GE Profile PSW26P Stainless Steel Side by...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
