Can not get a full screen lack 1 quarter inch on both side of the screen
  • Alfonso Gonzalez Jr May 11, 2010
    Is your monitor a CRT or an LCD monitor? What brand is your monitor? And what resolution do you have the monitor in?
    Problem Solver:
  • 8 Answers
If you have an lcd monitor, depending on the model, there should be an auto adjust function which automatically fills up the screen. If it doesn't, follow the CRT instructions below.
If you have a CRT monitor however, if you want the monitor to fill up the screen, depending on your monitor, there should be a menu button on the monitor. Press it and a menu will pop up. Look for the function which stretches the monitor and all that stuff and adjust the size vertically and horizontally.
If for example: one side is full but the other isn't, change the position of the image until the image is centered for that function eg. vertical. Do the same for Horizontal. Then resize the screen once more and you should get it to full screen. Hopefully this helps you.
Alfonso Gonzalez Jr
Posted on Sep 28, 2008
    Problem Solver:
  • 20 Answers
Just right click right in desktop and choice properties then setting and adjust the screen resolustion
Shrunken picture
HI!
can you take a picture to your tv to see exactly what happen to your vertical problem!? then you can post here thanks!
Nov 02, 2007 | Proscan PS56670 56" Rear Projection...
Hood latch won't stay in locked position. Hood is 1 quarter inch high.
There should be rubber bumpers on the bottom of the hood where the latch is. They are located on either side (and ends). Screw them inward for lower closure.
Apr 29, 2012 | 1999 Oldsmobile 88
I run on Windows XP, pack3 and I use a CRT ViewSonic EF70 ... 17 inches The screen is not filled completely with the image from Microsoft Internet Explorer, nor with Outlook Express .... there is about 3...
two things you can do, first right click on your windows screen and look for "settings" this will open a dialog box where you can set the screen resolution. Set it lower and see if your screen is now filled. if that doesn't work go into the monitor setup (buttons on the bottom or side of the monitor) and try to set the verticle and horizontal size, since its only 3/4 of an inch you should be able to stretch the screen to fill up the space.
Mar 11, 2011 | ViewSonic E70f 17" CRT Monitor
Inspiron 1300 screen border 1 inch
Have you tried adjusting the screen resolution? If you are running windows, try right-clicking on the desktop, then going to properties>settings>screen resolution. Set it to maximum available (I think it's 1024x768 on your inspiron). This should sort it out.
Good luck,
Raf
Nov 09, 2009 | Dell Inspiron 1300 Notebook
How to remove rear seat back 1987 mustang convertable?
Tools Required:
  • 3/8 inch Drive Ratchet
  • 3/8 inch Drive 3” Extension
  • 3/8 inch Drive 10mm Socket
  • 3/8 inch Drive 13mm Socket
  • T-50 Torx Bit
  • 1/4 inch Allen Wrench
  • 3/16 inch Allen Wrench
  • 1/2 inch Wrench
  • Drill Motor
  • 1/8 inch Drill Bit
  • 5/16 inch Drill Bit
  • 2 inch Hole Saw
  • Trim Tool (Fork Tool)
  • Electrical Tape
  • Center Punch
  • Hammer
------------------- Installation:
Remove Back Seat:
  1. Locate the retainers securing the seat bottom into the vehicle, approximately 10 inches from the end of the cushion, either side. Use your thumb to push in retainer release tab. Lift the seat up to remove.
  2. Remove the two 13mm screws securing the seat back, located on each lower corner. Lift seat upward to release seat back from brackets at the top. You can carefully prop the seat back under the retracted top , use caution if choosing this method not to damage or scratch the vinyl of the seat. You can remove the seat from the vehicle completely by disengaging the flanges securing the top of the rear seat to the fabric of the convertible top well .
  3. Remove Quarter Trim Panels:
    1. Grip the Quarter Trim Panel Cap at the shoulder strap opening and lift up to dislodge the retaining clips.
    2. The inside Quarter Trim Panels are two-piece panels. Remove the upper portion of the Quarter Trim Panel from the vehicle; it is not necessary to remove the lower portion. Pull the forward edge of the trim Panel over the pinch weld in the doorjamb.
    3. Use a Door Trim Tool (Fork Tool) to dislodge the pushpin retainer at the rear edge of the Trim Panel approximately 4” down from the top, pry Trim Panel toward the outside of car to release retainer.
    for more help click this link directly
    1. http://www.americanmuscle.com/05-07-lightbar-install.html ---------
Oct 05, 2009 | 1987 Ford Mustang
Blackened pans, high flames in oven even at 200 degrees
You still have not answered the questions I asked you, and you have posted your question under an electric range model. I will just have to guess and give you general info due to the lack of information you have given.
I will guess that you are using your range on LP gas. You don't compain of top burner performance, so I will take that to signify that the regulator has been changed from natural to LP, and that the burner orifices have been changed as well. That leaves only the oven. You need to find the spot where the gas comes out of the safety valve and travels up the venturi tube to the oven burner. There will be a small (about 3/4 inch square) adjustable air flow hole there, and right there you will see a brass collar. Use a 1/2 inch wrench to turn that brass collar three full turns clockwise. (it is usually easier to count 12 one quarter turns) If someone has tried to do this step, it may be part way turned in already, so you may not need to, or be able to, turn it three full turns. You do not want to turn it too far, but it will take a little effort. If flames are still too high, turn it a little more. Usually, the square air hole should be left all the way open.
Jun 28, 2009 | Frigidaire FES367 Electric Kitchen Range
House of toilet noise
try bendind the brass rod down 1/4 inch in your stack
May 29, 2009 | Pegasus Technologies Two-Piece Round...
Line on screen
if you found out how to fix or what is wrong with tv please let me no shanequinn@tiscali.co.uk
Apr 07, 2008 | Fujitsu Plasmavision PDS-4233 42 in....
Mag monitor dx17t tint adjust
adjust color and tint by pressing buttons on your monitor
Feb 09, 2008 | Computers & Internet
Computers & Internet Logo
135 people viewed this question
David Payne
David Payne
