Question about Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television
Replace lamb can not fit lamp red wires in wrong place
    Novelist:
  • 135 Answers
Make sure you got the correct lamp for your model and serial numbered TV. Some models use two different part numbers for the lamp.
Posted on Nov 09, 2008
How do you change the lamp in a mod # 980Z keystone projector
There is a black and silver knob under the keystone label( right above the automatic label ) on the side of your projector. turn this knob counterclockwise to loosen the covering over the housing unit for the lamb. once the knob is loosened lift the housing unit off of the side of the projector. You wlll see the enclosure where the lamp fits into beneath it.
Make sure the power is off for your projector while doing so. Screw the lamb into the enclosure , then replace the covering and screw the black knob in clockwise until it tightens.
Sep 21, 2012 | Office Equipment & Supplies
We can not get the new lamp to fit in its place
you must have the wrong replacement lamp as the correct lamp will simply slide back in with out any problems what so ever. Double check the lamp part number.
Aug 04, 2011 | RCA HD52W56 52" Rear Projection HDTV
Could you please advise how to reset lamp timer on a fujitsu LPF 4800 when I turn it on the green light goes to red and the lamp light indicator goes to red too and blinks
hi
You can reset the lamb timer as follows.
While pressing the MODE button, press the POWER button three times.
all the monitors flashes for a few second , The lamp timer is initialized to[ 0 hours] .
ok
Dec 15, 2010 | Fujitsu LPF 4800 Multimedia Projector
Someone told me to check my filter before I change the lamb because I may not have to change the lamb.I turn on my projector but I get no picture.
there is no filter on this model. just open it up and blow the dust out of it. if the lamp still won't light, check to see if the colorwheel is spinning. if it doesn't spin, the lamp won't light. if the lamp side screen is clogged with dust, the lamp is shot.
Mar 16, 2010 | InFocus ScreenPlay 4805 Multimedia...
Lamb out Could I replace
Refer to your owners' manual. Lamp replacement is very easy.
May 14, 2009 | Hitachi 50VF820 Projection TV
Did you fix the lamb issue?
These ballast plugs are fairly fragile and bend out of the way all the time, remove the lamp and see if this has happened. Other problems that cause this is capacitors in the power supply for the five volt line but check the connector first
Mar 29, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Dv 10 Lamp trouble
examine the lamp
any fault should be visible on the tube.
i assume you mean the pj lamp glowing bright red
Feb 26, 2008 | Optoma MovieTime DV10 Multimedia Projector
Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
