Question about Connex 3300 240-Channels Base CB Radio
No power i drive a dump truck, the new connex i own will cut off every so often, i will wiggle the power cord it will come back on.. now it wont even come on at all. is it something i can fix or should find someone to fix it, thanks richard
  • wkcrowson Feb 22, 2009
    I have the same problem. The radio power will go out so i hit the radio and it will come back on. I took the radio to a repair place and he found 2 cold solders. He fixed them and I put the radio back in. Approximateley 3 days later the same problem was happening again. Mine is on a CX3300HP.
This is called a cold solder....try the cord first but its probly the solder. have a tech look at it.
Posted on Jan 05, 2009
  • 90 Answers
Either the power cord is bad or the connections to the power jack inside the radio are disconnected or broken. Easiest thing is to try a new power cord, if it doesn't help have a radio tech check out the unit. This should be a very inexpensive repair, usually under $20.
Posted on Sep 29, 2008
My Connex 3300 hp blow`s up my amp fuse`s and the power cord`s get hot.
don't use the amp you are drawing to much power for it and thats why the cord is getting hot.
Apr 04, 2013 | Connex Radio Communications
Power supply cuts out on Gateway zx6000 all in one computer touch screen
If the cable is a "Kettle" type, you can get one in any electrical goods store.
Feb 11, 2013 | Computers & Internet
How to fix my connex 3300 it has no power
If it is new take it back and have it checked
Dec 25, 2011 | Connex 3300 240-Channels Base CB Radio
Got a connex 3300HP has a ranger board and chipset won't modulate recieves fine keys up relay clicks needle doesn't move no voice either cant find schematics
You may have a dead meter.
Modulation is audio's affect on swing wattage or pep. Notice that needle moving more with your voice.
Dead key or carrier wattage is without your voice enhancing the power only with mic keyed.
I can only assume that the chipset you are referring to is an ic chip audio or pll which must be working if you are receiving audio.
Check your mic cord................ transmit and modulation and even your receive volume can be affected by the cord/mic plug solder joints or broken wires here.
http://www.cbtricks.com/radios/galaxy/dx33hp2/graphics/dx_33hp2_sch.pdf this is a similar radio the General Lee, Connex 3300hp and Galaxy hp2 share boards i believe dont hold me to that thou.
Aug 20, 2011 | Connex 3300 240-Channels Base CB Radio
I have to turn the volume wide open on my connex 3300 hpzx to be able to hear it . It recieves great but the volume is not load and i even tryed an extenal speaker on it
The RX wire could be broke in the mic cord. You will still get receive when you have the talk back is on, but it will be low. Try another mic.
Dec 21, 2010 | Connex 3300 240-Channels Base CB Radio
MP3 Wont charge or upload
u need a new cord for charging.u lost ur receipt so no problem u can buy it any electronic or computer market i hope.
Aug 03, 2009 | SanDisk Sansa Clip MP3 Player
Power to Screen but does not come on. Wiggling
It sounds like there is a cold socket on the internal power input of your monitor. Have a repair technician take a look at it. It should be relativley cheap fix if that is the case.
Jun 15, 2009 | ViewSonic OptiQuest Monitor
Power cord cuts in and out
There are two places the trouble can be happening, at the adapter plug or at the power jack in the laptop. To determine which one is causing the power loss, hold the plug in the computer steady with your fingers while you wiggle the adapter cable. (If you have access to a voltmeter you can measure the voltage at the plug while you wiggle the cable to see if remains steady.)
If the charge light flickers it's the adapter cord that's bad. Because the wire flexes so much at the plug, it can break inside the insulation and cause the power loss. You either need to replace the adapter or repair it by cutting off the bad end and installing a new plug.
If the charge light remains on with the plug held steady but flickers when you wiggle the plug itself, the trouble is on the main board in the computer. The solder connections at the power jack have broken from the plug flexing and need to be repaired. This involves opening up the computer and getting at the solder side of the main board. It's tedious but relatively simple. If you are not experienced with soldering on small electronics, leave this to a professional shop.
Apr 23, 2009 | Acer (56.04145.901) (5604145901) Power...
Owners manual for connex 4600 turbo
to cut down on noise i would hook it directly to the battery. make sure there is a fuse in the power cord first.
Robert
Please rate this solution thanks
Feb 23, 2009 | Connex 4600 Base CB Radio
Acer aspire 3500 wont hold charge or turn on
remove the battery and see it the power comes on, if so bad battery, check the connector where the power plugs into the laptop, sometime this breaks or has a cold solder joint, you can test this by wiggling and looking to see if the power lights up. last and worst case is a bad main board.
Jan 07, 2008 | Acer Aspire 3100-1405 Notebook
Connex 3300 240-Channels Base CB Radio Logo
79 people viewed this question
Top Connex Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Steve
Steve
Are you a Connex Radio Communication Expert? Answer questions, earn points and help others
