Back to:
Tags:
Compaq iPAQ H3760 Pocket PC
Ipaq 3760 new ROM and battery?
By Brad - usenet poster
I came accross old Ipaq 3760 and I would like to use it. But firstly I would like to upgrade ROM to bewer version than original and if possible one with windows version higher than 3.0. Do you know if it is possible and where from could I download this kind of ROM and where can I find information (tutorial) of upgrade procedure. Also is it possible to change battery as this one last for a few hours, and if it is, where can I buy one.
Thanks
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on May 30, 2006
Not Rated (0)
Perkins
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
The newest ROM version is 2.2 which was released in 2002 so you might already have this version on your iPAQ. Check first!
Instructions are provided also, using the link above.
As far as the battery goes, they can be ordered from many places...ebay, PocketPC Techs and many others.
If the battery lasts for several hours, then the battery is probably just fine. My 3765 only lasts about 3-5 hours with a new battery installed, and can be as low as 1 hour, depending what you're doing on your iPAQ. These numbers are for continual usage BTW.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Ipaq 3760 new ROM and battery?:
I don't want to Accept this solution
Can you Help with these PDAs problems?
PDAs
i have an insinia bluetooth headset that will not...
PDAs
my sat nav screen froze
PDAs
need directions on how to use my mp3 video player
I have an ipaq h3760 and it keeps locking up on me. I...
I don't have any discs for my iPAQ H3760. I've downloaded...
Loading problems.
Repair Service
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
