Question about APC Back-UPS ES 350 - UPS ( external ) - 350 VA - UPS battery lead acid - 6 output connector(s) (NEWITEM13161548) UPS System
APC ES350 strange noise
My apc es 350 is making a loud squeeling noise. What is wrong with this backup device?
  • 3 more comments
  • Anonymous Nov 11, 2008
    it is making a loud squeeling noise
  • Anonymous Jan 12, 2009
    I have to push the reset button to get it to to go away, basically have to turn the whole unit off...
  • Anonymous Mar 02, 2009
    it is also flashing red and green light
  • nevadarich Mar 26, 2009
    Unit making squealing noise. Had this one time before and was able to cure with reset but not working this time. Any help appreciated.
  • myapcalarm Apr 05, 2009
    alarm sounds and cant get it to turn off. Have to shut down the unit and all devices :(
My solution was to unplug everything, hit the reset button, and then power the unit back up. The problem I found to be that I had my laser printer connected to the "surge + battery" side, and for some reason no laser printer can be connected to it.
Posted on May 28, 2009
  • 560 Answers
I was able to fix mine by replacing the battery with a new one. charge the new battery for 12hours before turning it back on.
Posted on Apr 27, 2009
Can i use a surge suppression stripe on my UPS
Not recommended. I asked APC technical support before.
Apr 20, 2014 | APC Back-UPS ES 350 - UPS ( external ) -...
Apc beeping twice every 2 seconds
The battery inside the APC is "weak", and the "beep" is telling you to replace the battery inside the APC, or, maybe cheaper, to buy a new APC.
Feb 03, 2014 | APC BACKUPS ES BE550G 8Outlet 550VA 330W...
APC 500 ES when i turn it on it creates a constant noise with green light flashing. sometimes it stops in 10sec. but most of the time it wont.
the apc ups performs a self test when ever it is powered on.... it should complete the process in 10 to 20 second but if it does not, then there is something wrong with ups.. try to get it checked...
Feb 24, 2011 | APC Computers & Internet
How to upgrade the ups software from
i wana increase the charginr of apc su 620 it is 900mah i wana it 4 amp
Oct 12, 2010 | APC BackUPS ES 350 Battery Backup System ...
Found an APC UPS 350 in the garbage, seems to work, but I don't understand the difference between having the power button engaged or not because both ways it seems to power my devices.
you may have a defective switch that is on/off button and is not serviceable.
I suggest you purchase a new APC model and by pass the headache here unless this is a project. You will need to take this unit apart and then call the manufacturer for a new part that may or may not be available or the unit is discontinued.
Jul 03, 2010 | APC Back-UPS ES 350 - UPS ( external ) -...
APC Back-UPS ES 350 - when powered on has a blinking green light Is this normal
A blinking green light is likely an indication that the internal battery is nearing the end of its usable life cycle. If it's over 3 years old this is likely the case. To test, plug something in to the battery outlets and pull the plug of the UPS from the wall. If you get a short runtime (or none at all) it's the battery. Batteries are under $20 and can be found here:
Oct 06, 2009 | APC Back-UPS ES 350 - UPS ( external ) -...
Need charging instructions for apc back-ups es 350
Take off the bottom cover and make sure the battery is connected (both terminals).
Plug the unit into a wall outlet.
Press the power button to turn it on. Leave it plugged in for 8 hours to charge the battery. Do this with nothing plugged into the unit.
Aug 08, 2009 | APC Back-UPS ES 350 UPS System
APC UPS issues
If its really a noise? neutral and ground of your utility power (building transformer) should be bonded
Apr 14, 2009 | APC Back-UPS ES 350 - UPS ( external ) -...
APC Back-UPS ES 350 - UPS ( external ) - 350 VA - UPS battery lead acid - 6 output connector(s) (NEWITEM13161548) UPS System Logo
3,981 people viewed this question
Top APC Computers & Internet Experts
Jax Planet
Jax Planet
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
