Question about Garden
Garden tractors and riding mowers
The engine will run for approx 15 minutes then shuts down. no spark. after a cooldown period spark returns and engine will run. coil or ignition module?
  • 3 Answers
If this is an older model engine , it may have points & condenser . You can change them or get an electronic ignition module to update your engine. On the points & condenser , the condenser gets very hot ! Thats why it will restart after a cooldown period ! Get the new parts , it comes with instructions . Good Luck !
Posted on Dec 06, 2008
Partial loss of power
It could be a short in the magnito a dirty carb prob. Or foul plug also use fresh gas to narrow the broblem. I almost forgot check the compression.
Jun 21, 2013 | Craftsman Kohler Courage 26 hp 54" Garden...
Motor shuts down sudden after 15 to 20 minutes run
it could be 2 things the soilonod is bad or the jets are pluged up in the carb
May 06, 2013 | Mtd Garden
Tractor runs for five minutes and then shuts down
I suggest if you change the spark plug on it, also check the oil level and temperature of the engine. If it is overheating it will shut down.
Thanks
Jun 03, 2011 | John Deere Garden
Governor hunts
Pour vinigar and hot pepper sparkles into the gas tank and mix it with the gas. Then start it- the differance in the way it runs will be very noticable!
May 22, 2010 | Craftsman 20 hp 42 in. Deck Yard Tractor
Shuts off after running a while
Given the fact that you offer absolutely NO information about what "IT" is, I am going to guess at a solution for you.
I am assuming that you have a one cylinder Briggs and Stratton engine mounted in a riding lawn mower that sounds like you are dealing with a defective ignition armature, commonly know as the coil.
You can verify this by obtaining an in-line spark tester, the kind with a neon bulb that will show a visible spark while the engine is running,
Insert your tester in the spark plug wire and connect it to the spark plug, start the engine and run it until it "shuts off". Immediately try to restart it while watching the spark tester for a visible sign of spark. If you see no light flash or a very weak looking light in the tester, replace the ignition armature/coil.
Oct 29, 2009 | Briggs & Stratton Garden
Crafstman riding mower cutting off now won't start at all
The two most likely suspects for the symptom you describe are:
a) Ignition coil failure under high heat.
OR
b) Decompression failure due to normal wear.
For a positive diagnosis try the following:
For scenario a)
Run the engine until it shuts itself down. As quickly as possible, check for spark using a spark tester (availabe at local auto parts store). If no spark when hot, allow to cool down and test again. If good spark when cold and no spark when hot, change the ignition coil.
Proper part number (assuming your machine is still all original) Briggs & Stratton part #492341.
For scenario b)
Run the engine until it shuts itself down. Try to restart but pay close attention to the speed of the spinning starter. Next, remove the spark plug and spin the engine over (WITH SPARK PLUG WIRE WELL OUT OF THE WAY!!) If the engine spins super fast and free you can discount the theory of a bad battery and you will need to adjust the valve lash.
Determine which is the case and reply to this post. I will gladly give a detailed explanation of the valve lash adjustment procedure in another post.
Hope this helps!
Oct 01, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
1976 JD 214 lawn mower Kohler engine K321AQS Model. Runs rough after 30 - 40 minutes use and starts to shake and over heats. rebuilt engine, honed cyclinder second time. New coil. New spark plug wire....
When it shuts down crack the fuel cap and listen for the woosh of a vacuum on the fuel tank. If you hear this, clean the pinhole vent in the fuel cap, or replace it. Being partially plugged would cause you to be starved for fuel and could explain your issue, and why it goes away after a period of time.
Regards, --W/D--
Jul 19, 2009 | John Deere &Reg Branded 27" Tractor Metal...
Mtd riding lawnmower won't run
my mtd lawn mower wont start . when I turn the key there is a buzzing soung where the battery conectors are near the shifter but the starter is hot and getting juice
Sep 28, 2008 | Garden
15 HP Kohler Engine RIding mower wont stay on
What's the gap setting between the coil and flywheel 15 hp kohler motor?
Apr 20, 2008 | Black & Decker 19" Electric Lawnhog...
Garden Logo
245 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
