Question about Kenmore Elite 21086
Calypso I have a Calypso model: 11022064100. I've already replaced the pump and motor. I need to replace inner washplate and ujoint. I' ve removed the outer washplate. searspartsdirect calls this part the inner washplate; I've seen this also called the inner dome. How do I remove the inner washplate ( inner dome?). Any help would be awesome!
  • 1 more comment
  • fixiter Sep 28, 2008
    Thanks for the quick reply... I didn't know that the whole tub came out as well. Printed all diagrams and didn't even open the manual they sent as it looked generic and some of the posts said it wasn't helpful. Now it's on to the spanner wrench everyon'es been talking about. Sears does a great job on giving you as little help as possible when ordering the parts. Can this be purchased at a hardware store?
  • fixiter Oct 03, 2008
    Thanks for your help. It took alot of force and wd40. Got everything replaced and working except for the top. I can't get it back on at all. The clips on the side seem to be raised a good quarted of an inch. It's #2 on http://www.searspartsdirect.com/partsdir...
    Any tricks to getting the snaps on the side of the lid to snap back in place?
  • fixiter Oct 04, 2008
    Problem solved. The tub was not fitted all the way down on the spindle correctly. Thanks again for your help.
  • 5,911 Answers
If you have already removed the outer washplate, the inner wash plate should just lift off the leveler and u-joint. The washplate dome refers to the center cone that fits on top of the outer wash plate. This piece comes off by inserting a screwdriver in the slots along the sides and gently prying to release the locking tabs. The mounting bolts that secure the outer wash plate also secure the inner wash plate to the u-joint assembly. There is a seal under the inner wash plate that may be holding it on. I don't know of anything else that would be holding it in place. Searspartsdirect.com has an excellent exploded view diagram of the wash plate and components that you may refer to provide you with a perspective on how everything fits together. I hope you find some of this information helpful. Please post back and let me know if you are still having problems.
PS You may have to resort to using a rubber mallet to lightly tap on the inner wash plate to knock it free.
Posted on Sep 28, 2008
  • Jeff Rockwell
    Jeff Rockwell Sep 28, 2008
    I'm not sure about a hardware store. I know there are several good appliance repair websites that you can check for the availability of special tools required for repairs, though. I didn't know if you were willing to wait longer by having to order tools. You may also try any local appliance parts retailer to see if they carry anything in their inventory by way of special tools. Most do. If not, repairclinic.com and fixitnow.com come to mind as websites that have repair tool listings. I agree, that some manufacturers do not offer any advice or instructions on how to install parts.
  • Jeff Rockwell
    Jeff Rockwell Oct 04, 2008
    Sorry I didn't get back to you sooner. Glad you were able to resolve your washer problems.
I have a Whirlpool Calypso and I have removed the washplate, lock nut using spanner wrench and u joint assy. I want to remove the metal inner basket so I can clean all the scum inside the outer wash...
Once you remove the agitator, then the nut with the spanner wrench, the basket should lift right out. It may need a little encouragement but it will lift out. I clean the out side tub with a putty knife to get the bulk of the scum off then use some cleaner like 409, or purple power to get the rest off. BE careful around the tub seal around the shaft, you don't want to damage it and have to replace it.
Jan 22, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
Tip
Calypso Nunater Removal
The following advice gives the steps necessary to remove the wash plate (or nunater) in Calypso model washers. Common complaints of articles of clothing getting caught in the wash plate and/or lodged under it, may facilitate the need to do this:
1. UNPLUG THE WASHER.
2. Open the washer top. Look along the front seam of the washer where the top meets the front. There are a couple of retaining clips (about 2" in from each side) that you will need to push in on with a putty knife while gently lifting up on the top to get the top to release. Carefully open the top and lay it back in a resting position. Make sure you support the lid so it doesn't fall open when you tilt the top back. NOTE: I would recommend using duct tape to keep the lid closed and gently place the top against a wall for support. Use a towel between the cabinet and wall to prevent any damage to painted surfaces. This also reduces the strain on the top panel supports.
3. Remove the tub ring. This is the plastic donut shaped ring that sits on top of the wash tub. There will be a tab on either side of the outer tub near the back that you can use a screwdriver to release the tub ring. The ring is filled with fluid and is used to balance the tub. So, if you hear liquid sloshing around, this is normal.
4. Remove the wash plate center dome from the wash plate. This is the center cone on top of the wash plate. Use a flat blade screwdriver and insert it into any of the slots available along the sides. Gently pry until it pops off. I say "gently", but you may have to use a little muscle to get it to come off. Sometimes they stick. Once the center cone is removed there will be a series of nuts under it.
5. Remove the nuts and the main wash plate should lift out, exposing the inner wash plate. This is another cone shaped device located under the main wash plate. Remove the inner wash plate, using care not to damage the gasket under it. It is common for clothing to become tangled in the leveler or u-joint under this inner wash plate.
6. When all required maintenance is complete, reinstall the inner wash plate, ensuring the gasket is seated under it. The inner wash plate is keyed and should only install one way.
7. Insert the main wash plate and insert mounting bolts. Use a criss-cross pattern when tightening to ensure all bolts are tightened evenly and the gasket seats properly.
8. Reinstall the center dome on the wash plate by snapping it back in place.
9. Reinstall, the balance ring on the wash tub.
The following is a parts list of the most common items that may require replacement when you experience erratic motion of the wash plate, and/or clothing becoming damaged or entangled:
Wash Plate Dome
Main (Outer) Wash Plate
Inner Wash Plate
Leveler Assembly
Inner Wash Plate Seal
U-joint
Searspartsdirect.com has an excellent exploded view illustration of the wash plate assembly and components to illustrate everything I’ve discussed in the steps above. Just type in your model number and click on the “Washplate, Basket and Tub” heading. At a minimum you should replace the Inner Wash Plate Seal anytime you break the seal. This will minimize the possibility of leaks.
I hope this information is found to be helpful.
on Sep 21, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Calypso washer clothes get stuck under the washplate ..the gap looks too wide between tub and washplate...does the washplate need replaced,, or is the plastic seal around the washplate replaceable???
THE PLATE CAN BE REPLACED, GET ONE FROM YOUR LOCAL APPLIANCE PARTS STORE OR SEARCH ON LINE, SEARSPARTSDIRECT.COM, REPAIRCLINIC.COM, ETC. GET MESH BAGS FOR YOUR SMALL ITEMS. THAT WILL PREVENT FUTURE PROBLEMS, IE: PUMP GET STUCK AND BURN(COMMON PROBLEM)
TIMOTHY DO 714-334-1998
Aug 04, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
How do I remove a small part of ziper
You go buy a magnetic or three hook flexible retriever from your hardware store and go fishing down the side.
Or if the zipper is floating about loose you take the back off the machine after dumping the outlet hose into a bucket to drain off the water.
Tip the machine forward or backward so that the outlet hose from the drum to the pump is as near to the ground as possible then remove the clip retaining it to the outer drum and your zipper should be within grabbing distance.
Make sure you have an old towel underneath the hose before you crack the joint
Jul 24, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
How to remove outer washplate from. kenmore
Wash Plate Dome
Inner Wash Plate
Leveler Assembly
U-joint
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 24, 2009 | Kenmore Washing Machines
Kenmore calypso has clothing stuck
I believe the problem is the Outer Wash Plate. Replacing it may fix your problem. I am about to do that to mine, so I don't know yet. The outer plastic 'seal' or rim of the washplate should be touching the inner surface of the stainless steel wash basket. So it catches clothes. I just installed a u-joint kit today, so needless to say, I got out the washplate and retrieved my clothes on the way to replacing the u-joint. It involves leaning up the upper lid and cover, removing the tub ring and balance ring and the dome. Then there are 6 bolts to remove the outer wash plate to get to your clothes underneath. Might as well replace the washplate while you are at it. to download the manual, copy this https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2c1e295a88aaaae885256c5d004632a4/$FILE/8178010.pdf
into your internet explorer address line and save the manual. page 36 starts the instructions I used to remove the washplate and other items. I spent a LOT of time cleaning the gunk out.
May 23, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Water runs out of the bottom of the washer as rinse water runs in. Washer if top loading Whilrpool. Model #WTW5840SWO
Check the pump assembly ( this is a common pump ) first for a leaking problem, check fill valve, hoses, and center seal under the outer tank in the middle where the transmission goes inside the washer. The button catcher ( on older style washer ) on the side of the outer tank is also bad for leaking. See #'s 16, 17, 18 for the button catcher, grommet and clamp. Replace them all at the same time, the grommet is glued as well as clipped into the outer tank. With the use of plastic drain hoses on many machines today, this has become a common leak trouble maker. The drain hose can rub the wall or a pipe and this will rub a hole in the drain hose.
Changing a pump tips: This pump is pressed onto the motor shaft. The motor shaft often starts to rust and the shaft swells out and holds onto the pump...tightly!! Often need to...remove power, remove the pump clips, remove the hoses from the pump assy. if the pump assy will not lift off of the motor shaft, you may need to remove the motor & pump together and break off the pump assy. A hammer and flat screwdriver can usually crack the old pump so it can be replaced. Sand/clean the motor shaft before installing the new pump.
May 03, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso once wash cycle is selected. The machine will fill then stop and there will be a humming noise
does it wash or spin anywhere on the dial.  If not, the coupling that connects the motor to the transmission is defective and need replacing.  A $20 part
Mar 25, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Material getting caught
ARE YOU SELECTING THE RIGHT AMOUNT OF WATER.AND MAKE SURE THE HIGHT OF THE CLOTHING IS NOT TO HIGH.
Sep 12, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Clothes getting sucked under agitator
I was able to find information on another web site with a Whirlpool Calypso repair manual: https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2c1e295a88aaaae885256c5d004632a4/$FILE/8178010.pdf
Check out steps 5 and 6 on page 36:
6. Using two (2) flat bladed screwdrivers, 90°
apart, in the notches provided, separate the
dome from the outer wash plate. (Fig. 3-11)
7. Remove the six (6) 3/8” bolts securing the
outer wash plate to the universal joint.
(Fig. 3-12) Remove the outer wash plate
from the basket.
That gave me enough room to lift the outer wash plate and remove three napkins and a wash rag.
P.S. Take precautions to keep the bolts from dropping under the outer wash plate.
Dec 01, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Washing Machines Logo
329 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
