Question about Toshiba TZ43V61 43" Rear Projection Television
Toshiba TZ43V61 43 in. Rear Projection... Problem
The power light is blinking, sound but no image. I tried to reset by ON and OFF, same problem
  • robert_lenor May 04, 2009
    My picture will come on for a few seconds, then go off. The red power light begins blinking and the only way to turn it off is by unplugging it. After doing so, the same problem occurs.
  • 63 Answers
Try unplugging unit for 5 minutes, then plug in and turn on. If this works, your power supply may be going. However it is more likely that the bulb is gone, you can replace it yourself, but make sure you get the right bulb for that unit and take care in the installation of it.Go to the manufacturers website and look up your model and find out how to inspect and remove the bulb.
Bulbs can run for 140 to $300 and can be found on EBAY
Posted on Dec 24, 2008
My Toshiba 50H81 screen black, no sound & power light blinking
sounds as if your power supply needs to be repaired. the capacitors over heat and crown or leak.
Jan 01, 2010 | Toshiba 50H81 50" Rear Projection...
No picture and the power light blinks
A red blinking light could mean that the lamp timer is at it's limit and it is time to change the lamp. You will also have to reset the lamp timer by pushing and holding down 2-3 buttons on the tv or remote. Refer to your user guide for the proper way to reset and or change your lamp.
Oct 04, 2009 | Toshiba 50H81 50" Rear Projection...
Red power light continuously blinking. no picture no sound.
It could be the lamp went out and needs replacement. The Toshiba website states when this happens to unplug the televison for 10 minutes then plug back in. If that does not work then try another power outlet. If that does not work then call for service
Sep 12, 2009 | Toshiba 57H81 57" Rear Projection...
Toshiba tz43v61 TV just died. No red light.
does it have a power strip on the tv stand? if so plug the tv into a wall socket.my power strip went bad and the reset button did not work
Jul 17, 2009 | Toshiba TZ43V61 43" Rear Projection...
Click when plugged in and steady blinking red light.
hello it sounds like it could be just a dry joint on the video section of the tv good luck
shaun
May 27, 2009 | Toshiba 43HX71 43" Rear Projection...
Toshiba Rear Projection TV Problem
common problems on toshiba are the stk ic and it is not ease to replace them you will need a technician
Sep 15, 2008 | Toshiba TZ50V51 50" Rear Projection...
Toshiba blinking power light...nothing on screen
HELLO.!!! IT SOUND LIKE YOU HAVE A BAD HORIZANTAL OUTPUT TRANSISTER & FLY BAD FLY BACK TRANFORMER. TRY CHANGING THEY'S .!!! THEN YOU SHOULD HAVE A WORKING SET"GOOD LUCK"
Sep 01, 2008 | Toshiba 43HX70 43" Rear Projection...
Toshiba problem
did you try power reset leaving unpluged for 5 minutes
it might be the power house component went out
do u get sound at all
this might be indicator of bulb replacement if no picture but sound
May 09, 2008 | Toshiba 57H81 57" Rear Projection...
Toshiba TZ43V61 43" Rear Projection Television Logo
487 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
