Question about Dell UltraSharp 1900FP 19" Flat Panel LCD Monitor
Dell 1900FP Do you know where you can find the lamps for the Dell 1900fp?
You can push every lamp from 19inch monitor who have same jack for conector{i work that, i have dell1900fp}!!!sorry for eng.good luck
Posted on Nov 12, 2008
Dell 1900FP flat panel color monitor the on screen display wont go off
try to remove power lead for a minute or two and put it back in. Should be better.
Apr 07, 2014 | Dell UltraSharp 1900FP 19" Flat Panel LCD...
Lock keeps flashing on monitior
To get the lock to go off the screen you can press and hold the monitor Menu button for about 10-15 seconds.
Thank You,
Dell-Jesse L
Dell Social Media and Communites
Apr 06, 2014 | Dell UltraSharp 1900FP 19" Flat Panel LCD...
Dell 1900 fp monitor driver
Go to GOOGLE and type DRIVERS for your exact product and model of monitor, which will hopefully give you the correct drivers to download. Softonic would be one place to look. CNET would be another.
Sep 19, 2012 | Dell UltraSharp 1900FP 19" Flat Panel LCD...
Open and look at the tops of the capacitors. I bet there are at least 2-3 "bulging" tops. Replace them and the problem WILL be solved;.
Apr 07, 2011 | Dell UltraSharp 1900FP 19" Flat Panel LCD...
Monitor not working after adding drivers
1. turn off your computer
2. turn off your monitor
3. Unhook the power and video cable from both
4. Reseat them both on both ends.
5. Turn on your monitor
6. Turn on your computer
If its still doesnt work after all 6 steps, your monitor is bad, sorry.
Apr 02, 2009 | Dell UltraSharp 1900FP 19" Flat Panel LCD...
Dell 1900 FP Monitor
Bad video card? Substitute another to see.
Dec 30, 2008 | Dell UltraSharp 1900FP 19" Flat Panel LCD...
Dell 1900FP LCD Monitor
First, I would use a multimeter to verify that the power adapter is good. It should have an output of 14VDC. If it is working, the next step in verifing that it is a backlight problem would be to connect the display as normal and, with it powered up, shine a bright light on the screen at an acute angle to see if the desktop image is being displayed. If you can see the image, then it is probably the lamps or the inverter.
To remove the cover, remove the four screws attaching the base and after the base is removed the 2 halves of the cover simply snap together. Using a jewelers screwdriver, start at one corner and gently pry the front bezel away from the back, working your way around it. There are 4 locking tabs on each side and 5 on the top and bottom.
This display has 4 lamps, 2 each at the top and bottom of the display. This is the easiest display I have seen as far lamp replacement goes. At this point, all you have to do is disconnect the lamps wire from the inverter, remove the tiny screw, right below the point where the wires connect to the lamps, and carefully slide out the lamp assembly. Be very careful not to flex them while removing.
Check the lamps for burnt spots at the ends or physical damage. If the lamps look good then I would not rule out the inverter as the problem. At this point, if you are not familiar with electronics, I would seek help from someone who is.
I hope this helps.
Jun 28, 2008 | Dell UltraSharp 1900FP 19" Flat Panel LCD...
No power dell 1900fp silver blank screen power ??? help!!
try swapping the computer power cable and don't connect the vga cable with the system. if you get a power on self test displayed it makes sure that the monitor is fine. if nothing is displayed you can take it for repairs or else call 1-800-624-9896 its Dell technical support number or log on to
Jun 03, 2008 | Dell UltraSharp 1900FP 19" Flat Panel LCD...
Dell 1900fp 19" moniter Ultrasharp
Button on the bottom back base raises and lowers, if not low enough then you can remove the base. removal button is back and center of monitor.
of course you will have to deal with a way to mount it then.
Dec 12, 2007 | Dell UltraSharp 1900FP 19" Flat Panel LCD...
Dell UltraSharp 1900FP 19" Flat Panel LCD Monitor Logo
177 people viewed this question
Alun Cox
