Question about Sony Cyber-Shot DSC-F707 Digital Camera
Sony digital dsc-f707 startup goes to "no memory stick"
I have a Sony DSC-F707 digital camera. When I start it I get a message saying "no memory stick" or "memory stick access". I have replaced the memory stick with no change. Sony wants $375 to look at it. Any suggestions?
Thanks, Dave
  • daash Sep 28, 2008
    I have tried changing memory sticks with no success.
    Thanks for your help.
    daash
  • Anonymous Dec 07, 2008
    I have the same problem too, just to let you know.
The "no memory stick" error is likely caused by the ribbon cable connecting the memory stick bay. Instructions for how to fix this problem can be found on this web page. Following these instructrions, I had the problem on my F707 solved in less than 20 minutes.
Posted on Oct 16, 2008
I had the same problem. This is dumb but it worked on mine. Put memory stick in a card reader then put a picture on it and install it back in the camera and turn it on. worked on mine for some reason.
Posted on Oct 06, 2008
    President:
  • 2,712 Answers
Could be that the contacts on the camera are oxidised. Try cleaning the contacts with isopropyl alcohol and see if this helps. If not, it could indicate a circuitry problem. In this case, you'd probably be better off buying a new cam altogether!
Posted on Sep 28, 2008
  • Swilin Sampson
    Swilin Sampson Sep 28, 2008
    Try using a different memory stick if you have one, and see. Sometimes the memory stick itself may be faulty..
    Hope that helps!
    If your issue is
    not resolved, please do not assign a rating just yet. Please post back as
    to what steps you took, results, etc, and I will try to assist you further as
    best I can.
    P.S. - You can rate a
    solution with one of four ratings as explained under (remember that at times a
    bit of to and fro dialogue may be necessary to resolve an issue).
    • "FixYa!"
      - The solution provides great advice on how to solve the problem.
      (Positive Rating)
    • "Helpful"
      - The solution provides useful leads that helps solve the problem.
      (Positive Rating)
    • "Thanks
      for Trying
      " - The solution does not solve the problem but the
      effort is appreciated. (Negative Rating)
    • "Inappropriate"
      - The solution has absolutely nothing to do with the problem.
      (Negative
      Rating)
    Thank you for using FIXYA!
    IrishDruid
Can i use sony memory stick duo for sony cyber shoot DSC-F707
The answer is yes as long as they are the same type memorystick.
Feb 10, 2010 | Sony Cyber-Shot DSC-F707 Digital Camera
Have Sony CyberShot DSC-F707 Sony Memory Stick Duo Adaptor and Sony Memory Stick Pro Duo 4gb When installed get C:1301 error
In DSCT1 Camera, the C:13:01 error message indicates a Self diagnostic message. Each of these codes indicates the symptoms and resolutions of the Camera. In C:13:01, the issue is with the Memory Stick being used in the Camera.
The Symptoms are:
Memory Stick Pro Duo 4GB is not compatible with the DSCF707 Camera. Maximum capacity supported by the Camera is up to 128MB. Please try using a MS with 128 MB and check if it works. A dedicated adapter (MSAC-M2) must be attached to use Memory Stick Duo or MagicGate Memory Stick Duo media.
Thanks.
KenSolutions
FixYa
Dec 24, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
I have a dsc-f707 and the camera claims no memory stick is in it. I replaced it with two memory sticks and still the same message. Plus, can Memory stick duo work in camera?
I only got one reply and it was a "spam ad" selling offers from different camera repair companies. I ended up calling a local camera repair place and basically was told that the camera is nonfixable. The cost to repair is most likely going to cost the same as buying a new 12M pixal camera. So, why fix it?
Sep 30, 2009 | Sony Cyber-Shot DSC-F707 Digital Camera
I insert a memory stick and it says "No memory Stick" although it will take and record pictures . Does anyone know where i can purchase a 128 Memory stick for the DSC -F707?
You should purchase online from some secure seller.
Like here, its Sandisk Homepage.
search for the compatible Card from the bottom right tab.
Also Note that DSC -F707 doesn't support more than 128-Mb cards.
If helpful, Kindly DO RATE!
Best Regards.
Jul 17, 2009 | Sony Cyber-Shot DSC-F707 Digital Camera
Sony cibershot dsc-f707 manual
http://esupport.sony.com/US/perl/model-documents.pl?mdl=DSC-F707&region_id=1
Apr 09, 2009 | Sony Cyber-shot DSC-S700 Digital Camera
DSC-F707 camera cuts off after 10 second , just bought a new battery.
I also bought an aftermarket battery for my F707 on Ebay and got the same "for info...." message.
I contacted the seller and they sent me a new one and it worked, don't see a way around it.
Oct 26, 2008 | Sony Cyber-Shot DSC-F707 Digital Camera
DSC F707 Error C:13:01
Can't use Memory Stick PRO's on the DSC 707, they won't format. The technology of the PRO's postdates the 707's.
Aug 10, 2008 | Sony Cyber-Shot DSC-F707 Digital Camera
Memory Stick Error
Have you tried re-formatting the cards? If you can't with the camera you should be able to with a card reader. It's probably the camera, unfortunately, but this is worth a shot...
Sep 13, 2005 | Sony Cyber-Shot DSC-F707 Digital Camera
F707 type of memory stick?
I bought a Lexar 256MB, since the F707 can't use PRO or anything about 128mb, it has two 128mb on one stick. There's a switch on the stick to change it when the first 128mb is full.
Sep 12, 2005 | Sony Cyber-Shot DSC-F707 Digital Camera
Memory stick problem
I had this same problem and the procedure it the following : IF YOU WANT TO SEE YOUR PICTURES, DOWNLOAD "PhotoRescue" INSERT YOUR MEMORY STICK CARD IN YOUR CAMERA, RUN THE SETUP1 AND FORMAT IT. Good luck
Sony Cyber-Shot DSC-F707 Digital Camera Logo
315 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
