NEC NW-491 washing machine. I keep getting the error message E9 on the display. the booklet does not describe this message what can I do to fix this problem?
  • tash002 Sep 28, 2008
    That did the trick! Thanks
  • Anonymous Mar 29, 2014
    I have a nec nw-452 washing machine showing a e9 error and won't start
  • 2,071 Answers
Just click below for code error;
NEC NW-491 washing machine. I - small_11_21.jpg For a detailed Washing Machine illustration, click below.
Top Load Maytag Style
TNEC NW-491 washing machine. I - redarrow.giflpool Style
redarrow.gif Top Load GE Style
redarrow.gif Front Load Maytag Style
redarrow.gif Front Load Frigidaire/GE/Kenmore Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Some problems that can occur with your top-loading washing machine are:
There's an error code on the digital display
It doesn't work at all
It won't drain
It doesn't spin
It doesn't agitate
It's noisy
It leaks
It's off balance
There's no hot water
There's no cold water
It's slow to fill
There's no water at all
The clothes are wet after spinning
The cycle doesn't advance
There's no delicate or regular spin or agitate
It's overfilling
It's underfilling
The water temperature is incorrect
Hope it may help you;
Posted on Sep 28, 2008
  • 2,712 Answers
This usually indicates a problem with the water pressure sensor or the water level switch. A defect--or an obstruction--in the water-level switch may cause this issue. Check the sensor by pulling the hose attached to the bottom part of the tub and blow on it and test the terminals of the sensor if it will close or open
  • Swilin Sampson
    Swilin Sampson Sep 28, 2008
    GREAT! Glad to have been of help. Cheers!
Daewoo Washing Machine Error Fault Code = E9
Fault Detected: Pressure Sensor Error
Washer Has Detected: Error with the pressure switch or level sensor
Check / Repair / Fix = Wiring to level sensor - Level sensor
Jun 01, 2017 | Washing Machines
Our AW-1170S Toshiba washing machine ia showing error code E9-5 error message . How can I fix it.
Pam: This code relates to WATER PRESSURE , could be a (1) Krink hose, (2) plugged strainer where water enters the machine ( doing it's job) or (3) a sensor that malfunctioning (thinking you have NO water pressure. These sensor prevent the machine from operating dry, flooded etc, some times they OVER protects. So check the first 3 items above. you may have IN HOME service on it.
Feb 09, 2015 | Washing Machines
My NEC NW 652 washing machine is showing an E9 fault. When I hit the power button the E9 message appears?
Sounds like the water level pressure sensor is not working. The code (E9) means the switch is open.
You'll need to replace the pressure switch. Check the manual for the repair procedures.
Apr 25, 2014 | Washing Machines
E9 message and machine stops
Jayshree, E9 error, pressure sensor error/water sensor error.
Replace water level sensor. The error display disappears if power button is turned off and on.This is what the service manual states.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Daewoo DWD M103 Service Manual Page 15 of 16
Daewoo CV701PC Service Manual Page 26 of 52
Daewoo Washing Machine Error Fault Codes
Washing Machine pressure switch
Apr 20, 2014 | Daewoo DWD M1031
Message = E2
Cause & Solution =
The water is supplied continuously due to an defective inlet valve. Change the valve inlet.
The valve inlet is normal, but the water level sensor Change the water level sensor
(sensor pressure) is low. (sensor pressure).
The drain motor does not work - Test and if faulty change the drain pump
Message = E9
Cause & Solution = The water level sensor is faulty. Change the water level sensor. (remove pressure tube and blow through it to make sure it is clear first)
Mar 10, 2012 | Daewoo Washing Machines
NEC NW 892 Errror E9
This error is related to the pressure sensor
check connections or replce pressure sensor
Check at the water source end of the hose and make sure the filter is not occluded. Both hot and cold. more likely the cold side as the hot water may disolve the particles more easily.
If all else seems good you will have to replace the sensor
Aug 01, 2009 | Washing Machines
My NEC NW 652 washing machine is showing an E9 fault. When i hit the power button the E9 message appears
E9 means the waterlevel sensor is defective or the pipe connected to it is faulty.
Jan 13, 2009 | Washing Machines
NEC washing machine displays E9
fault code e9 relates to pressure sensor.
Apr 29, 2008 | Washing Machines
Washing machine nec nw-652
i am having the almost the same problem with what i have, if it is turn, the water will just keeping on pouring in non stop, it does matter wether it is wash, rinse, dry or spin the water will just keep on pouring in at all time, it is not a good machine at all.
Sep 09, 2007 | Washing Machines
Washing Machines Logo
386 people viewed this question
Top Washing Machines Experts
