Question about Mitsubishi WD-52525 52" Rear Projection HDTV
How do I test the Lamp Thermal sensor?
Thanks for your help on my last problem. I had a 34 code and replaced the capacitors on the power board and I now have an image. Now I am getting the message "TV will shut down in a few seconds..." The lamp cooling fan is operable and there is no blockage to the aie flow. I have unplugged the lamp thermal sensor at the two pin plug and re-seated it and still get the same message.
  • ChuckLRHG Nov 22, 2008
    I've been told to order 299P85010 lamp sensor -- do you have a manufacturer phone number and/or web link?
    thanks,
  • 927 Answers
Good Day;
The indication that the sensor is bad is showing the "air flow message", not an item that can be tested with positive results. Replace, it's only a couple of dollars. Good Luck, big IRISH.
Posted on Oct 02, 2008
Mitusbishi WD73833 won't power on. Replaced the power board with one from Mitsubishi and it still won't power on. Help!!!
These tvs are known to have sensor issues. EX: door lamp sensor failure. Thermal fuse failure (above bulb)....Check all sensors on the tv and replace with new and you will be up and running again.
Lastly, always double check all connections and check the bulb ballast as well.
Thank you and best of luck!
Jul 11, 2011 | Mitsubishi WD-73833 73" HDTV
I just replaced the lamp on my Samsung HLS5087 and now the TV won't power up. The 3 LEDs are lighting which indicates that the lamp needs to be replaced. I put the old lamp back in to make sure there is...
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I hope this will help to solve the problem,,,,
Dec 06, 2010 | Televison & Video
I replace the bulb and I'm getting a blinking error code 3 4. How do I fix? Mitsubishi WD-52525
That code can often be caused by failed capacitors on the power board which will cause the 34 error for lamp abnormality. The V26 Power repair kit at www.tvrepairworld.com may fix that issue. The kit contains the replacement capacitors and has the CD with instructions.
Dec 14, 2009 | Mitsubishi WD-52525 52" Rear Projection...
SONY KDF70XBR950 DLP TV 6 Blinks. Is it on the G1 Board? and does anyone know the fix? Thank You.
First double-check all your connections and wiring. Make sure there is nothing looose or broken. The capacitors also could be swoolen and burned out. You can test with capacitor tester. Thermal fuse or flyback is also possible and common causes. Lamp burn out? Do you have power to the bulb socket? Power to ballast that bulb attaches to? Last solution wold be to replace the board
Oct 27, 2009 | Sony Televison & Video
No picture on my WD-52525 projection television.
Chances are youre getting a 34 errod which is cxaused by failed capacitors on the power board. You can get the V26 DLP Power board repair kit at the following link which contains the capacitors and the CD with detailed instructions.
http://www.tvrepairworld.com/
Jul 25, 2009 | Televison & Video
My Mitsubishi WD-52725 will turn off while watching and the lamp led will go red. It will sometimes come back on without unplugging and sometimes you must unplug wait 2 minutes and the plug back in. I...
Thats a common symptom of when the power board capacitors fail. It will make the lamp light turn red and a self diagnosis 34 for lamp abnormality. Usually install the power board repair kit will solve that issue. Heres a link to the power board repair kit for your model. The kit contains the capacitors and detailed instructions.
http://servicemanuals.vstore.ca/product_info.php/pName/mitsubishi-v26-dlp-power-pwb-repair-kit/cName/repair-kits
Jul 11, 2009 | Mitsubishi WD-52725 52". Rear Projection...
Replaced lamp ,have sound but no pic,shuts down
Thats the code for whats known as lamp abnormality which is actually caused by failed capacitors on the power board. Heres a link to the repair kit that will usually fix that issue. The kit contains the replacement capacitors and also has step by step detailed instructions with photos so you can easialy do the repair yourself.
Jun 13, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 error code 34
replaced 2 capacitors 3300u/35v. At the power board.
do not tuch the rest of the chassis...............
Nov 23, 2008 | Mitsubishi WD-52525 52" Rear Projection...
WD-52525 Red lamp Indicator
usually with that model when you get a 34 eror code for lamp abnormality, its directly related to the capacitors on the Power Pwb. You can get the V26 Power PWB repair kit at the following link which repairs that issue. It contains the replacement High temp capacitors with the board location numbers and PWB identification as well as the service manual on CD. Heres the link its under their repair kit ctegory.
Sep 04, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Bulb firing, won't stay on
Try to clean the air filter it soubds as if that is the problem. Then try it aain. If you need further assistance let me know.
Jan 22, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
292 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
