A Kenmore washer/dryer combo front loader. Trying to spin, shakes badly and makes a very loud banging noise.
    President:
  • 2,712 Answers
Check the bearings. I suspect they are faulty..
Posted on Sep 28, 2008
Loud noise during spin cycle now they are stacked
a loud noise comes when you forget to remove shipping bolts after installation or if the shocks are worn out it makes noise thirdly the bearings might be worn out if the washer is more than 6years old
Jan 21, 2013 | LG Cherry Red Steamwasher Wm2487h Front...
Frigidare front load washer has loud banging on spin cycle. After much work we reallized one shock was broken of which we repaced both now it still making the loud banging shaking motion. Also the washer...
Thanks for choosing FixYa and welcome. Since the suspension is ok and it is level, check your drive motor and spin bearing. Usually, these are the trouble parts when loud noises are associated with the spinning cycle. Your drive motor controls the spinning. Since the noise is during spinning, that is probably where your problem lies.
Apr 29, 2011 | Frigidaire GLTF1670A Front Load Washer
My front loader washing machine is make a banging sound during spin cycle
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Apr 16, 2011 | Kenmore Washing Machines
Loud shaking in the spin cycle
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems
heatman101
Jan 19, 2011 | Kenmore HE2 Plus Front Load Washer
Open the cabinet top and check along the sides for a broken or out-of-position damper. Shake the mechanism in several directions to help locate. Hope this helps!
Jun 12, 2010 | Kenmore HE2 Plus Front Load Washer
My kenmore elite top loader has a loud banging noise when spinning
Disconnect power to the washer then tape the lid closed. Lay the washer carefully on its front panel on a padded surface then check the four suspension spring/rod assembly. Make sure the suspension doors are properly attached to the outer tub to prevent an off balance situation that may lead to the banging of the basket to the outer tub during the spin cycle. Also ensure the machine is balanced and properly or evenly seated on the floor.
May 07, 2010 | Washing Machines
My MAH9700 Front Loader washer is shaking a lot and making a loud banging noise when spinning.
unscrew the 4 screws inside the detergent dispenser and lift the top and see if the counterweight on the tub is loose,otherwise it may be the drum bearings going bad on the inner drum
Apr 01, 2010 | Maytag Neptune MAH9700 Front Load Washer
Kenmore series 80 washer makes loud knocking noise during spin cy
Unless your front loader is set firmly on concrete and leveled to perfection, the force of a heavy wash load spinning in excess of 1000rpm will create a bit of vibration and noise.A firm footing is your best defense against to much movement.
Also due to the earlier movements during the spin cycle, the shocks that are used to dampen the spin cycle might have been broken or damaged.
If the problem persists inspite of proper levelling, please do check for the shocks or might have them replaced them for good.
Dec 14, 2008 | Kenmore 24032\24036 Top Load Washer
Three day old Indesit washing machine
Is it a maytag? My maytag front load washing machine had 2 long bolts with plastic braces on them, to keep the drum still during shipping. Mine would bang and shake all over. I got the book out before I finally figured it out. I had to take the back cover off and remove the bolts and plastic braces over them. They look like they' 8 inches long or so. It works great now.
Carolynn
Jul 15, 2008 | Indesit W 123 Front Load Washer
Washing Machines Logo
134 people viewed this question
Top Washing Machines Experts
