Question about D-Link DPR1260 Rangebooster G Multifunction Print Server (790069283475) Print Server
Problem with DPR-1260
I have a problem to use with my printer server DPR1260. I successfully connected DPR-1260 and printed documents under wireless environment. But, DPR-1260 suddenly disapears in "my network place" and I cannot connect it, after around 10 minute use. And the LED that displays the connected printer is off.
DPR-1260 works again when I unplug then plug the power connector. And it is gone after around 10 minute. (It looks like the DPR-1260 is not running correctly.) Is there any soultion for this problem?
  • leifmb Oct 20, 2008
    I have the same problem with my DPR-1260. Latest firmware installed. The unit works fine for a while using the wired cable and then the printer icons suddenly disappear and the unit stops functioning. To get it to work again I have to power cycle the unit.
  • richnuwa15 Feb 10, 2009
    this i have done over and over. resetting it and reconfiguring but the reason i have to do this all the time is every time there's a disconnection from the power source, the print server loses it's configurations. both th networkand wireless configurations are changed back to the default. what can i do about this situation? i have to reconfigure all the time and it's not always easy to access the upnp icons of the router in my network places. please help
    richard
  • 59 Answers
This kind of problem occurs in dlink router sometimes & after some time router stop responding after 10 -15 min & once u reboot the router it again start work for a while. the best solution to this problem is to reset the router back to its factory defualt settings u can do this by press the reset button on the back on the router ( it looks like a small hole u have to use a pin for press that button) once u have reset the router to factory default settings just reconfig the router & i am sure it will start working fine in case u still face the same problem just contact D-link or send me the details about the problem & the physical setup of ur router & printer etc
Posted on Oct 16, 2008
D-Link DPR-1260 print server setup problem
Try admin for logon & password.
Sometimes it is user ......
Feb 01, 2010 | D-Link RangeBooster G DPR-1260 (DPR1260)...
Windows 7 compatibility forthe DPR 1260
My DPR-1260 arrived yesterday and I set it up easily in minutes on both Windows 7 (32-bit Pro) and XP SP3 with 3 printers attached. So far I have only tried wired connection. Wi-fi may be more problematical.
Printers are Brother HL-2040, HL-2140 and Samsung CLP-300. Could not get it to recognize my Canon Lide 25 scanner
Oct 30, 2009 | D-Link RangeBooster G DPR-1260 (DPR1260)...
Dpr-1260 onkly works when connected by ethernet cable
dpr-1260 searching for ap and connected keeps changing back and forth when I refresh.On dpr-1260 if status of wireless keeps changing from searching and connected, change wireless to WPA, instead of WPA2. even if you have WPA2 setup (as I did), if you choose WPA it will stay connected.
Jan 23, 2009 | D-Link RangeBooster G DPR-1260 (DPR1260)...
Cannot access setup utilities in dpr-1260 print server.
Try to log in with "admin" as the P/W (without the quotes.
Jan 03, 2009 | D-Link DPR1260 Rangebooster G...
Printer eventually loses connection...
Try to upgrade the firmware revision to the last one (1.21).
I had similar problem with the dpr-1260 firmware rev 1.00.
Now after the firmware upgrade the problem seems solved
Nov 06, 2007 | D-Link RangeBooster G DPR-1260 (DPR1260)...
Connect d-link print server with linksys router
you might need to set the Gateway on the router to match your ip on the print server.
Oct 07, 2007 | D-Link RangeBooster G DPR-1260 (DPR1260)...
DPR-1260, HP All in one 2210, and IE7
Make sure your printer is on the compatibility list provided by D-Link. The list is in the following link: http://support.dlink.com/faq/view.asp?prod_id=2316&question=DPR-1260
Aug 20, 2007 | D-Link RangeBooster G DPR-1260 (DPR1260)...
D-Link DPR1260 Rangebooster G Multifunction Print Server (790069283475) Print Server Logo
1,113 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
