Question about Milwaukee 5321-21 Rotary Hammer
When drilling the clutch starts to slip
Hammer drill 5321-21
  • David Ford
    David Ford May 11, 2010
    When you say starting to slip are you jamming the bit? This tool has an internal clutch that is preset to slip when the bit binds up to protect the user. If it does it all the time you would need to send it in for service. This is not a repair that can be done at home.
  • 2,176 Answers
If it slips to easily that is a problem, but it is designed to slip some when the bit binds up in the concrete. If you feel it is too easy, I would not recommend trying to service at home. I used to work on them and they are a pain, the clutch is an assembly and I would recommend taking to an authorized service station so they can check the static slip on the clutch mechanism and then advise whether needs serviced or acceptable.
Posted on Nov 05, 2009
Drill bit rotation stops
www.powertools-aftersalesservice.com this site allows you to input the model number in the trade name box or if you look on your tool you will see a 10 character code quite often starting with a '0' enter this number in the part number box. This will then display your exact model variation, voltage etc. (the former search will bring up a list of possible models, voltages and countries). From the parts break down you will see there is a clutch fitted. Testing of clutches is not easy and many makes can not be adjusted. I have seen on SDS drills the guide lugs in the tool holder have sheared/Worn away and the drill bit can be turned freely if the steel balls are removed from the chuck. On a max there are more lugs but I don't suppose it is unheard of these al wearing away. If it is a clutch problem you will hear the drive slipping. If it is the latter the drill will sound normal. All that said It could even be gear teeth that have broken and so not meshing in the rotation mode. Only stripping the tool will identify the fault.
Mar 01, 2014 | Bosch 11264EVS 158 SDSMax Combination...
My drill slips under high torque
check clutch adjust,put it in drilling mode
check if speed selector is in right position
after that if it slip aggain,you need a gearbox
Nov 04, 2012 | Milwaukee Tool Milwaukee 18V 1/2 In Hammer...
On my BOSCH CSB 470-RLE 470w electric drill the chuck is slipping i can hold it in my hand and it wont move
It is a spring loaded hammer drill. You need to push the chuck down just a bit for it to engage the clutch. If it is still slipping then either the clutch pieces (items 23 and 32) are worn or item 32 is spinning freely on the spindle shaft. Here is a parts diagram.
Bosch CSB470-RLE diagram
Aug 16, 2012 | Bosch Drills
Clutch slips reguardless of setting, in both drill and hammer mode. won't drill. is this a transmittion problem?
You can get the part replaced with metal gearing and clutch and that shouldn't happen again, but the cost may not be worth it
Mar 08, 2011 | Dewalt 18v Battery Hammer Drill Dcd950...
SDS drill bits slips frequently
Take a look down the nose and see if the tabs 180 degrees from each other that accept the bit are in good condition. If they are it is possible that the clutch is slipping (321/22 and 321/37 fit together to create the clutch along with the ring that 321/37 fit into). Please let me know what you find.
Nov 20, 2010 | Bosch 1" Sds+ Bulldog Rotary Hammer Drill...
Bosch rotary hammer (model # 11230EVS) drill will not rotate
There is a clutch in the main spur wheel of the unit. These sometime begin to slip, on rare occasions they will slip to the point where the drill will not rotate. If you are interested the part number for this clutch is 1617000817.
Jun 16, 2009 | Bosch 11247 Factory Reconditioned 1 -...
Bosch VSR 1199 hammer drill keeps slipping in hammer mode
Inside there is a little plastic shaft, where the selector hooks to. They have had problems over the years stripping. Replacement part is still plastic. Yay! You may need a bearing puller or find some way to get the clutch off the shaft. Lemme know. Please rate me
Jan 26, 2009 | Bosch 1199VSR 8.5 Amp 1/2 Inch Hammer...
HAMMER MODE SLIPS OUT
i am guessing the transmission problem not enough tension to the clutch
Aug 11, 2008 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Makita 8444d mxt drill
what is the setting in your clutch. if you set the clutch to the highest setting and it`s still slipping then you need transmission assy.
May 28, 2008 | Makita 18V LXT Lithium - Ion Cordless...
Dewalt 18V XRP Clutch Slipping
it very economical to repair the drill. replace the transmission.
Apr 27, 2008 | Dewalt 18 Volt Compact Drill Kit
Milwaukee 5321-21 Rotary Hammer Logo
530 people viewed this question
Top Milwaukee Drills Experts
Jim Thurston
Mike
Are you a Milwaukee Drill Expert? Answer questions, earn points and help others
