I have a RCA 52" Big screen TV D52W17. When i try to turn on the set the power light comes on fro about 2 seconds then off again. This happens 3 times then nothing. If I hold the power button a code flashes out 1 9. Any ideas would be greatly appriciated.
    President:
  • 2,712 Answers
1. Try this - hold the menu button down for 10 seconds. TV should power up; youwill have to turn off front panelbuttons on menu.
2. You can also try a hard reset: Unplug TV from AC mains and remove all cablesfrom TV. Wait about 30 minutes and re-plug to AC power and redo the cabling.Switch on the TV and see if it works..
3. Powering down the set or putting it in standby may haveallowed the power supply to cool. Weak capacitors often go out of spec whenthey cool, thus preventing a section of the power supply from firing upproperly again. There is a simple trick...just warm the back of the TV with ahair dryer for 5-7 mins after you have unplugged the TV. Look for the littleareas of holes in the back panel of TV. Use these as your guide at where to usethe hairdryer, but don't hold the dryer too close (say 5-6inches away). (Makesure the dryer is on High heat). If the TV doesn't turn on after you haveheated it up (like it tries to come on but then turns off) you need to unplugthe TV again, this resets it. And repeat those steps till it works. Resettingthe TV after it fails to turn on is the key. Also, just leave the TV on. Don'tturn in off. Since it is LCD, it doesn't take much power...only a few bucksextra a month for your utility bill.
4. A circuit board may crack about some of the largercomponents mounted on it. You can inspect the PCB's for fractures, and thenrepair them. It may also be poor soldering that has failed. I would be checkingfor these things first.
5. If you want to go in for a long term solution, you can easily replace thewhole power board or just change the faulty capacitors. You will have to openthe back panel and take a look. You can make out which are faulty, becausetheir caps will be swollen on top. Here's a sample pic of a bust capacitor (notsame model):
Check the specifications of the faulty capacitors, and get the replacementsfrom your local electronics shop. If you are comfortable with this, you can usea pair of needle nose pliers to G-E-N-T-L-Y pull out the defunct capacitors.Once that is done, solder in the new capacitors carefully. If are unsure how todo this, try to get a friend who knows how to do this kinda stuff do it foryou, or get a qualified technician. Warning: If you do nothave a background in electronics repair, or are inexperienced, get a qualifiedtechnician to do it for you.
REMEMBER there are very dangerous voltages inside a TVthat can KILL. Be sure to work SAFE when dealing with electricity. DISCONNECTTHE POWER BEFORE YOU DO ANYTHING.
Hope that helps!
If your issue isnot resolved, please do not assign a rating just yet. Please post back asto what steps you took, results, etc, and I will try to assist you further asbest I can. I am here at your service.
P.S. - You can rate a solution with one of fourratings as explained under (remember that at times a bit of to and fro dialoguemay be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
Posted on Sep 28, 2008
52 Inch RCA D52W17 BYX1 projection screen tv cuts off when i TURN ON
The set literally has a 3 strikes and you are out where it will try three times and go to shutdown.
The common issues this set has are bad solder connections under and around the high voltage transformer and also in some cases the High voltage splitter block (located way up front behind lower grill below screen unit and behind a removable inspection plate).
The transformer rarely fails but can--photo of what is general appearance of this type of part is attached.
Oct 26, 2012 | Televison & Video
I have a RCA D52W17 rear projection T.V. When I turned the power on the green light flashed 3 times then shut off and now it won't go on at all.
Hi
Thanks for using FixYa. 3 blinks in your RCA D52W17 rear projection are caused due to 3 capacitors (CP114, 120 and 150) which are located on the deflection board. If any of these capacitors goes bad you’ll have to replace them with the exact same ones. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 21, 2010 | RCA D52W19 52" Rear Projection Television
52" RCA big screen tv turns on and few seconds turns off by itsel
if you heard a hissing or like static sound your board probably has a hole in it now. the board on the left side with the flyback fransformer. the hole is from where a prong has come loose an is arking over an it burns the board the ark is the sound you heard.
Apr 23, 2009 | RCA R52WM24 52" HDTV Projection Television
52 inch rca big screen tv will not come on
ck capacitor cp150 if it is bad replace 2 other caps in same circuit 2200uf 16v -220uf35v cp111 cp114?
Dec 09, 2008 | RCA D52W19 52" Rear Projection Television
Power on/off
that is a common problem with this rca's check the convergence board for a short circuit
more likely is a transistor or an convergence ic
caypianan@yahoo.com
Jul 18, 2008 | RCA HD52W58 52" TV
RCA MODEK D52W17 Cant Get Any Remotes To Work This TV
The remote receiver in the TV is failed. It is possible that a TV repair shop might be able to fix the problem for you
Jun 18, 2008 | RCA HD52W58 52" TV
RCA 52-inch (rear projection) big screen television
tv worked great, turned it off one day and back on the next and the on light would not come on nor would the tv work, rear projection 52 inch rca
Jun 18, 2008 | RCA P52926 52" Rear Projection Television
RCA D52W17 won't stay on.
Possiblility include bad convergence cuircit. A component that is overheating and bad solder connections.. Technicians can use special equipment to read error codes... this will tell them the error that is shutting it down
Mar 13, 2008 | RCA D52W19 52" Rear Projection Television
52" RCA HD capable projection tv won't stay on!
This set has a processor that is telling the set there is a safety problem and shut the set down. this could be one of about 35 different cuiricts. Are there any sounds clicking chirping? An rca technician have special computer interfaces that can read errors generated by the processor that can help in determining what is wrong with your set.
Jan 15, 2008 | RCA HD52W56 52" Rear Projection HDTV
Rca d52w17 hdvt rear projection Problem
If the light cycles on three time the micro is working but there is something shuting it down.a This is not clear cut it would need to be troubleshot. You need to call a tech.
                                   Packman
Oct 29, 2007 | RCA D52W19 52" Rear Projection Television
Televison & Video Logo
179 people viewed this question
Top Televison & Video Experts
Electro Med Services...
