Related Tags:
This problem should be removed because:
Problem with Kyocera Mita FS 1000+N Laser Printer
Huge Margin with Kyocera FS 1000+
I've many problem concerning Kyocera FS 1000+ (6 printer, same problem on all the six printers!!) . If I print any page, the top margin is too high. Even if I print the "print self test" pressing che green button on the printer, the page has the same the huge top margin. You told that there is a way to calibrate the margin...where can i find this way? I think is not a driver problem but a mechanical problem..but I don't know how to solve it :( Thanks for patience
Solutions (3)
Best Solution
If the FS-1000 prints too far down the page or leave too much top margin or leaves a gap at the top of the page etc (<- for google searches). This is a problem with the felt pads on the three solenoids/clutch electro magnets that are under the right panel (2 under the engine/button board, 1 under the inner plastic cover, sometimes 4 in total on other kyocera printers). They get compressed over time meaning the metal leavers come into contact with the solenoid meaning they are released too slowly. Simply replace the felt pads with .5mm cardboard or another non-sticky non-metallic material. Too thick and it prints too far up the page.
My printer had a similar problem - top margin unpredictable. The repair shop replaced a solenoid somewhere inside it to fix the problem. It is a mechanical problem.
laser printer has a margin sensor in the paper through way between paper input sensor and drum cartridge unit. too much top margin means this sensor lost it's sensitive paper edge function but works delay. you may try carefully take out paper tray and cartridge looking the paper through way the position of margin sensor, clean and adusting the sensor stander as well.
Kyocera FS1010 first page only half printed
I have a Kyocera FS1010 and every time I print the first page gets a huge top margin and the bottom of the page is missing. Subsequent pages...
Different label alignment on different printers
Where can the printer alignment/margins be set? IBM client access version 5.8 is being used to print labels on various Kyocera Mita FS 1010...
wierd margins from printer
the printer has decided to leave a large margin at the top and no margin at the bottom of the page.
kyocera fs-3830 cutting off print on top of page
why is this machine cutting off the top of the page
Add Your Solution
Kyocera FS1000+ that only prints
Kyocera FS1000+ that only prints pages of useless characters windows 7
i just did a refill
i just did a refill of the toner and when i print the paper becomes black
My printer is of Kyocera
My printer is of Kyocera FS-1700 my printer jam with one old document i delete old documents when i cannot solve my...
FS1000+ that only prints pages of useless...
I have a Kyocera FS1000+ that only prints pages of useless characters since reconnecting after have my PC rebuilt, I...
Fix-O-Meter
1,682
1,682 people viewed this problem
- 16 people found this problem to be helpful.
- 0 people are following this problem. Be the first!
Top Kyocera Mita Printer Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
You da man!
I fixed an FS-1000+ purchased on an auction site and now it works great :) 0.55mm cardboard did the trick beautifully :)
I can't find the three selenoids/cluth magnets but would really like to get it fixed. Anyone got some pictures or anything to help me find these? Printer in pieces on my desk now!
Thanks, Rick
I can't find the three selenoids/cluth magnets but would really like to get it fixed. Anyone got some pictures or anything to help me find these? Printer in pieces on my desk now! Thanks, Rick
View More Comments
