Question about Sony KP-53V90 53" Rear Projection Television
Remote control does not work.
Ordered new remote and still does not work. tried looking for the IR but do not see it anywhere. i suspect it might be the brand logo. need someones help to make this work.
thanks
randy
  • 10,594 Answers
In Sony KP-53V90 TV, Remote Sensor (IR) is located in HC board and an exploded view is pasted here for reference.
Posted on Sep 28, 2008
M420mv vizio led television ir infrared doesnt work
that can be caused by either the IR sensor board or the main board. The IR sensor board would be suspected first. You can get the IR board or the main board from www.tvrepairworld.com
Feb 09, 2013 | Vizio Televison & Video
Remote has stopped working, I would like to order a new one if possible! thank you
Try website like Remotes.com to buy the tv original remote or very closed compatible one.
Aug 23, 2011 | TruTech PLV1615T 15 in. LCD Television
Remote won't work. Tried new batteries, reprogramming, etc. Universal Remote doesn't work either. LG #42PC5DC
To confirmed if the remote control is working fine, aim the remote control sensor(IR emitter) directly to your cellphone camera. While pressing any button key on the remote control, you can see the flash of an infrared emitted by the remote control if it is working fine.
If you've confirmed that the remote control emitted an infrared but still the tv won't communicate with it, this is an indication of faulty IR sensor board of the TV. Check if there's an obstruction from the IR receiver in front. Keep away all of it, clean the plastic window of the IR receiver with soft clean cloth.
If the symptoms still persist, you have to replace the IR sensor board. Check the actual part no. of the board before ordering.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Aug 22, 2011 | LG Televison & Video
My remote stopped turning the TV off and on and adjusting the volume....what can I do?
It's rare to see an IR sensor go, it's most likely a defect with the remote itself. If you have a remote you can test with the tv, that's probably the idea solution. If you don't, you can possibly check out a site like http://www.remotecontrolhookup.com and order a new original remote and give that a try. If that doesn't work, you can always return that new remote and maybe look into buying a new TV, because repairing it may get expensive.
Jan 27, 2011 | RCA RCR350 Remote Control
One ir sensor must be covered up in order to control receiver
rogere214
There could be an IR interference from another source, perhaps florescent lights, DVD player, TV, etc. To locate the source, leave everything off except the receiver and TV. Turn one component on at a time and try the remote to see if the remote still works or not. If it still works, turn on next component. Try the remote until it stops working. Once you find the source,try moving it to a new location. If you don't find the source, then we may need to replace the receiver. I hope this helps.
Ray Calo
DISH Network
Aug 03, 2010 | DISH Network IR Remote Control
Out of nowhere my remote won't turn on my directv box when the front of my wall unit is on. It will work when the front of my unit is off. what can i do?
Ok well I am going to assume that by 'wall unit' you mean your wall-mounted TV. This issue is most likely caused by a combination of two things.
1. The Harmony remote's IR emitter is becoming weaker. This can happen as the remote gets older, the IR signal is not as strong as it was when the remote was new.
2. Your TV is very bright, causing a lot of IR interferance. I suspect that this is the main issue here, since you indicated that the remote works OK then the TV is off.
Try dimming the amount of light that is coming from the TV (if possible) and dimming the lights in the room. Remember, the more light in the room when you are using the remote, the less strong the remote's IR signals are going to be.
Mar 24, 2010 | Logitech Harmony 550 Remote Control
Kenwood VR-6070: Broken volume knob; will IR sensor still work?
Looks like you have several faults?
First try to fix the remote:
http://www.instructables.com/id/Repair-your-remote-controls/
May 28, 2009 | Kenwood VR-6070 Receiver
Magnavox Model #PR1910 C123
It is very very rare for this to happen. I would try other remote or you can google universal remote codes and look for other codes.
May 06, 2009 | Philips Televison & Video
My IR remote no longer works in another room
Dawn,
If you want a remote that works via IR to control the satellite receiver you will need a IR only. The IR/UHF type only transmits signals to the receiver by UHF and the IR portion only operates the peripherals in the room such as the TV and VCR. There are some remotes that come with a kit that can change the remote to work as an IR only. I believe you have a TV2 remote and want it to work further away from the receiver particularly the room the TV is in. If this is the case you may have have to change the remote address of the new remote to match that of the old. You can do this by taking the number one remote and pressing menu-menu. Now take the new remote and press and hold the SAT button in the upper left of the remote until all lights across the top light up. Now key in the two digit number on the tv screen at remote address for tv2. Then press the pound sign and the SAT button will flash three times then press the record button and the TV2 icon should flash. Now you can cancell out of the screen on tv one and try the remote at the TV2 location. I believe this will fix your issue if not let me know. Thanks for using Fix Ya.
Jan 14, 2009 | DISH Network IR Remote Control
Sony KP-53V90 53" Rear Projection Television Logo
153 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
