Question about Dishwashers
Old ge dishwasher
There isnt any water going to my dishwasher and its just making a humming noise when i turn it on
  • apowell8 May 15, 2009
    I have same problem but with zanussi zdf231s. Any suggestions?
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 171 Answers
Hi loda83,
I'm Harvey the Master Plumber.
Your problem is: there isnt any water going to your dishwasher and its just making a humming noise when you turn it on
The most likely culprit is the solenoid valve. It is a simple on/off valve under the d/w on the left. Depending on make and model I might remove the d/w from the cabinet to facilitate installation. Don't forget to turn off the water first.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 28, 2008
My GE Triton dishwasher won't drain. How do I de-clog it?
Remove the dishwasher drain line from the under sink connection. Direct that end to a bucket and run the drain option on the dishwasher.
1. Does water drains to the bucket. Then your under sink hook up to the dishwasher is clogged. Clean it with a screw driver.
2. No drain water comes to the bucket then
2.1 When on drain do you hear a humming noise. If yes then your drain motor working. That means mostly your dishwasher drain line clogged.
2.2 If humming noise is like a fan (impeller) running then drain line clogged.
2.3 If humming noise is like a small struggling to run. Then something stuck in the drain motor impeller.
Apr 24, 2015 | GE Tritonr XL GSD6260JCC Dishwasher
GE pdw9980lss dishwasher makes a horrible squealing noise when not in use.
The dishwasher control panel must be defective, nothing else would cause this.
Apr 04, 2017 | GE 24 in. PDW9980LSS Stainless Steel...
My old GE potscrubber 700 dishwasher stopped working
moter has probably locked up TAKE FRONT LOWER PANEL OFF AND YOU CAN ROTATE ROTOR/ if itis not free and rotates easly then the motor has failed / mm
Dec 07, 2009 | Dishwashers
No water getting into the dishwasher
At the bottom of the dishwasher remove the kick panel . Then turn on the dishwasher , and then locate the water inlet valve , it should be on the left hand side with hose going to it . the pipe might be copper or plastic or stainless steel . listen for a humming noise . If you hear a humming noise . there is no water getting to the unit . make sure the hose is not kinked and the water is turned on and clean the screen on the valve . if there is no humming it is bad water valve . ( cleaning the water valve ) remove the incoming water line and remove the screw that holds the valve in . Then remove the 90 degree fitting on the bottom . you will see the screen .
Oct 31, 2009 | Dishwashers
GE Profile dishwasher makes a humming noise
I had the same problem. The issue is due to the top rack water inlet not properly seating against the water line in the rear of the washer. I fixed it by placing heavier items (bowls, glass cups) on the rear of the rack and lighter items (plastic cups) near the front of the rack. As long as I arrange items on the top rack in this way the washer runs silently.
Oct 08, 2009 | GE GSD3800G - Multiple Color Built-in...
Dishwasher makes a humming/rumbling noise when washing but stops when the water drains.
As the machine gets older, it may start to make other noises due to wear on the various parts. If the machine is working well, leave well enough alone.
Oct 06, 2009 | GE 24 in. GSD6660GSS Built-in Dishwasher
Dishwasher wont go into cycle mode and hums
No model and brand name .
the way you mention look like the main motor jammed and making the humming noise click out on overload then the humming noise stop and after a while it will humming again and continue like that until you switch off the machine. If the dishwasher is old I would recommand you buy a new one instead of changing the motor.
God Bless have a nice day Dickson
Jun 30, 2009 | Dishwashers
Bosch dishwasher timer sticking
I have been told to replace the timer which I am looking to do the same to my machine!
Mar 24, 2009 | Bosch Dishwashers
Nautilius not running
drain motor doesn't work, yo cn hear a little noise but maybe to hot, th motor doesn't turn.
Jun 29, 2008 | GE Nautilus 24" Built-in Dishwasher
Dial not moving/not cycling through
If the dial won't rotate then you need to replace the timer.
Mar 30, 2008 | GE 24 in. GSD2000Z Built-in Dishwasher
Dishwashers Logo
128 people viewed this question
Top Dishwashers Experts
