How do you get to diffrent tv station to show at the same time (pip)
  • 10,594 Answers
If your TV has built-in Duel Tuner then you can see 2nd picture in pip. In remote you have channel up-down button for main picture and another set of channel up-down for pip function to change channels in pip.
Posted on Sep 28, 2008
Just today a black box has appeared on my screen. It appears in the top right hand corner of the Tv and is approximately 6 inches by 6 inches. I can see that it actually works as when there is movement on...
It sounds like you accidentally activated picture in picture with a dead station tuned in or a different input selected for the P.I.P.
Start around page 52 of the user manual for instructions on this.
Your manual is here:
http://www.fixya.com/support/p232474-panasonic_th_42xvs30u_42_in_hdtv_plasma/manual-8012#
If you turn off the PIP, everything should go back to normal.
Feb 27, 2011 | Panasonic TH-42XVS30U 42 in. Plasma HDTV
Have a black box in the top left corner of tv how can I get
check and see if your tv has PIP (picture in Picture) which you turn on and off with the remote. If you do you have PIP turned on, but not set to any station.
Nov 30, 2009 | Panasonic Viera TH-42PZ80U Plasma TV
Vizio remote
The remotes for the TV and Direct TV box are universal remotes that can operate very basic functions for whatever else they are programmed to control. If you can program the TVs remote to operate the Direct TV box it will basically only control power and channel. Maybe something else, but not much. The same goes for the Direct TV remote. It will control basic functions on the TV; power, channel & volume. Best bet would be to purchase a universal remote that can learn functions from the original or just keep both remotes available by the TV.
PIP (Picture In Picture) - Your television should have the capability because it has two built in tuners. It can show two channels at the same time or show one channel and one video source (whatever is connected to the audio/video inputs). However, because you are using DTV (Direct TV) you are very limited because you are not using the built in tuners on your television. You should be able to see one picture from the DTV channel and one from lets say your DVD player. If your DTV box has two tuners built in then you should have the PIP capabilities from your DTV and not your television. I'm guessing your DTV is a single tuner (one satellite cable to your box). If you want to watch two different channels you'll need to either upgrade your box or attach another box to your television.
Option: you could also connect an antenna to your television this way you can use the PIP function. Obviously you'll only be able to view whatever local stations you can get with the antenna. Depending on where you live you might or might not have a lot of channels to choose from.
Apr 19, 2009 | Vizio L32 32 in. LCD HDTV
PIP on old panasonic tv only shows the channel you are watching
Determine your exact model - there should be a sticker on the back.
Similar to: CT32HX40B, CT32HC43G, CT32S20U, etc, etc.
Go to below link and download the appropriate PDF for your model.
(Tip: Set page to " Show All Rows" for ease of use.
http://service.us.panasonic.com/operman/findmanual.aspx?cat=DTV
Depending on your source input (Cable, Antenna, both) - the PIP instructions will vary.
Note: The PIP is not all it is cracked up to be anyway, so you may be wasting your time, also if you get the PIP in a stuck mode... See the link to fix it: http://www.fixya.com/support/t664989-turn_off_panasonic_pip
Jan 03, 2009 | Panasonic CT-36HL43 36" TV
Windows madeia center
This is all I found. If this tuner isn't digital ready chances are there isn't going to be much support for this and you will have to get a new one by next February.
Here is the current software link:
http://www.nxp.com/#/homepage/cb=[t=p,p=/50804/50823/55463,f=SAA7130HL_4]|pp=[t=pip,i=SAA7130HL_4]
Jul 05, 2008 | Philips SAA7130 TV Tuner/FM Radio/Video...
WD-52628 Mitsubishi - change inputs
We had the same problem. Luckily, we had a service contract, so it was serviced yesterday. The fix involved the service guy going through a "service menu" and resetting the TV that way. He was not "allowed" to tell me how I can access the service menu, however. I do plan to research this on the internet in case it happens in the future. It is basically a software/computer problem, and unplugging the TV isn't enough to clear it unless the TV is unplugged for "a long time." The technician said the length of time depends on the condition of your capacitors. Anyway, as a temporary fix, he showed me that you can go into the PIP mode. The device toggle for PIP apparently did still work with mine, so I was able to switch the device on the secondary picture and then switch it to primary, then toggle the PIP off. Good luck!
Jan 05, 2008 | Mitsubishi WD-52628 52" Projection HDTV
PROSCAN PICTURE IN PICTURE DOES NOT WORK
You can't receive two pictures at the same time on your Satellite Receiver. I have the same tv with Dish.
Dec 13, 2007 | Proscan PS61670 61" Rear Projection...
Pip
On the front of the TV while it is on, press on the ACTION and POWER buttons at the same time and hold them for about 5 seconds until the screen goes blank and comes up with a diagnostic screen. Once that happens release them and press action again to clear the diagnostic information. Now your TV is se back the way it was brand new so you will have to proram the channels back into memory and apply your color,brightness,hue etc..settungs as those have all gone back to factory as well.
Mar 22, 2007 | Panasonic PT-53WX53 53" Rear Projection...
No pic/sound on main screen
I will recommend replacement of the main tuner
Dec 10, 2006 | Toshiba CN35F95 35" TV
Televison & Video Logo
Top Televison & Video Experts
