Question about MSI Computers & Internet
Using a 1point 5G CPU.
Can I use a 1 point 5 G CPU in my MSI 6378 version 1 motherboard when
MSI state 1 point 3 G MAX. is recommended on data sheets.
From Spikeg
Went to a swap meet & obtained a 1.3 G CPU as the 1.5 G cpu I had was A INTEL
Unit with my motherboard a Socket A for Athlon {AMD} type units.
This solved my problem.
Thanks for all the help.
Posted on Sep 28, 2008
Msi 6378 turns on but I don't see anything on the monitor
Not trying to be trite sir, but I think that is a broad unsupported statement........
If we look at the known universe...........
!O_O! What a minute?...........What?............Oh........
...fans, video card, cpu, ram, cd drive, hard drive, and power supply work; (Semi-Colon), as well as the motherboard itself...........
With all due respect what do you base all that diatribe on?
Fans spin, and LED's light up; and you're going to assume the other hardware components, must be working as well?
THAT, is your basis for your hypothesis?
A) You can see the fans spin......
B) You might hear the harddrive spinning it's platters, while it is in an endless loop............
C) You can press the optical drive's (CD/DVD drive) tray release button, and open the tray.......(To assume it's getting power)
But tell me how you assume the cpu, motherboard, ram memory, graphics (video) card, and Power Supply; to be good?
What do you base this assumption on?
With all due respect..............nothing.
Your observations are baseless.
Seem like I'm trying to be rude?
No sir. Trying to get you to think outside the box
What is the common 'denominator' here?
What hardware component is common to all the others?
That........if not working at full capacity, would not allow the others to work?
The motherboard is the 'Building Block' of a computer.
The CPU is the 'Brain'
The Power Supply is the 'Heart'.
No 'heart' you have nothing.
When diagnosing desktop computer failure, the first hardware component to diagnose; is the Power Supply.
Without it operating at full capacity nothing else works.
Past this point the diagnosis can go on. (Power Supply deemed to be good)
If not you will be pulling your hair out searching for answers.
Primer:
1) If ALL of the LED's were on at once, they would use less than 1 Watt of power.
2) EACH fan uses 2 to 3 Watts of power.
3) A typical CPU (Processor) can use 51 to 130 Watts of power.
A Power Supply with a weak voltage power rail, will have power to light those simpy LED's, and maybe spin fans; but will not have enough power to turn the CPU -> ON.
Have an economical multimeter?
They range in cost from $5 to $12, usually.
I have seen them on checkout aisle racks, at major discount stores.
Auto parts stores have them, but usually more expensive.
With it you can test the 3 main DC Voltages, coming out of the Power Supply;
3.3 Volts
5 Volts
12 Volts
Again, all are DC Voltage.
In comparison two D cell flashlight batteries produce 3 Volts DC.
(The dangerous AC voltage is kept contained, in the metal case of the Power Supply)
OR,
Use a KNOWN to be good, Compatible power supply for a test unit.
("I need to borrow the Power Supply out of your computer honey.
No, no.......I'll put it back. This shouldn't take long.
What? Touch it, and I'll lose sum fingers?" )
Also, follow Anti-Static Procedures, and look at the Electrolytic Capacitors on the motherboard.
In fact, what the hey right? Might as well look at them first,
A) http://capacitorlab.com/visible-failures/index.htm
B) http://www.youtube.com/watch?v=Lut7MX5Dd_A
Capacitors on the motherboard are used as Filters, or Voltage Regulators.
The ones used as voltage regulators are in the
Motherboard Voltage Regulator Circuit.
Part of what the motherboard voltage regulator circuit does, is regulate voltage for the processor.
The processor MUST have a steady, 'clean', supply of voltage; and it MUST be kept within the tight voltage tolerance range, for the processor.
Too little, or too much, and it turns off. (BIOS turns it off)
http://www.hardwaresecrets.com/article/616
(For older motherboards, and to include older server computer motherboards; voltage regulation for the processor was accomplished with a VRM. Voltage Regulator Module.
A separate, replaceable 'card' )
http://www.msi.com/product/mb/MS-6378.html
http://computer.howstuffworks.com/hard-disk.htm
http://en.wikipedia.org/wiki/Computer_power_supply#Wiring_diagrams
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20
Post back in a Comment
Regards,
joecoolvette
(One last little item that seems to slip through the cracks, the Ram Memory. Clean the gold plated contact pins with a pencil eraser. Use air to remove the eraser dust )
Mar 29, 2013 | MSI MS-6378 Motherboard
Need wiring diagram as i had to recase
You can dload that manual in pdf format at the MSI website here:
http://global.msi.com.tw/index.php?func=downloadfile&dno=3536&type=manual
Pages1-4 and 1-5 are the pages you are looking for.
Hope this helps and thanks.
Please rate
Sean
Mar 30, 2009 | MSI MS-6378 Motherboard
MS 6378 bios Was crypted. Tell me about password reset! KYBRA
You can to reset password by jumper on motherboard his name CMOS CLEAR or CMOS RESET .
it plased near the 3 volt battery .
It look like 3 pins a 1 jumper on it.
reinstall for 2 second jumper to anover two pins from 2-3 to 1-2 or (from 1-2 to 2-3 ) and password will be cleared !!!
but the over settings will be cleared too.
P.S. if you can't find this jumper just to try remove the battery for 10 minutes and disconnect power cord from power supply unit, but it may be no useful.
Mar 23, 2009 | MSI MS-6378 Motherboard
Sorry for my bad english
Hi mastelmkd, click on this link;
http://global.msi.com.tw/index.php?func=prodcpusupport&prod_no=499&maincat_no=1#menu
This is MSI's link for supported CPU's for the 645E Max-U motherboard. Check you're bios version. You'll need ver 5.3 to run the Pentium 4 (Northwood, FSB533, L2 Cache 512KB), Pentium 4, 2.8GHz CPU. Or you can choose a lower CPU from the list. Suggest you add the link above to you're favorites.
Good luck mastelmkd!
Mike
Aug 29, 2008 | MSI 645E Max-U (MS-6547-050) Motherboard
Msi 654e max atx mother board
If your manual states a max of 2.2GHZ then, take it as that, when your board was made the bios and bus speeds would be set at the maximum to run a 2.2GHZ, not a 3GHZ, also the heat sink and fan may not be enough to cool the processor. The only way that a 3GHZ would run was if you updated the bios and personally i would not recommend it. You would be better advised updating the board and processor as a package ot fitting more memory if the pc is not used for gaming or high end video editing.
Apr 19, 2007 | MSI 645E Max Motherboard
Computers & Internet Logo
80 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
