Question about Gateway 400SD4 Notebook
Mini PCI 802 card in a Gateway 400sd4
Installed a Mini PCI 802 card. drivers are installed and device manager says it is working but is not aquiring a net work. Card is enabled. Is there any other way to turn it on?
Need to install wifi driver on gateway 400sd4, win vista,
Go to Gateways web site and download all of the drivers for your Gateway machine and install them.
Mar 22, 2014 | Gateway 400SD4 Notebook
My gateway laptop cant connect to the internet. _When I plug a cable, the red light in the port does not respond _ The WIFI does not respond
Hello John,
It seems that: 1. Your LAN controller and the WiFi controller could be disabled in your BIOS setup.To re-enable them, if applicable,
  • Press the F1(or F2 ) key repeatedly after restarting the computer to enter the BIOS setup.
  • Navigate through your BIOS and locate the settings for LAN conroller and wireless, and select Enabled to enable them.
2. You may not have the appropriate drivers installed on your laptop for your network controllers. Upon further investigation, your laptop runs on the following network hardware:
  • ActionTec IEEE 802.11b network card installed in Mini PCI expansion slot
  • Broadcom BCM94306 IEEE802.11g network card installed in Mini PCI expansion slot
  • Broadcom BCM94300 IEEE802.11a/g network card installed in Mini PCI expansion slot
Download and install your drivers for the hardware above from: Wireless Drivers(Broadcom BCM94306) from Broadcom BCM94306 10/100Mbps LAN drivers from
Hope this solution helps.Good day.
Jan 14, 2011 | Gateway M305CRV Notebook
Need drivers for wireless mini lan card for Toshiba Satellite 1900-704,toshiba-satellite-m35x-s3491-intel-802-11b-g-mini-pci-wifi-driver-8-0-12-9000w2.html
copy this url and paste it in your browser and lunch.the download button for your driver will appear for your download.install/run setup.exe after ward and your problem would be fixed.
rate this solution please
Nov 24, 2010 | Intel Toshiba Satellite Mini-PCI Laptop...
How do you enable the pci express slot on gateway gt5674
OK, for this issue, we will start with a basic fix for this issue regarding a Windows XP Machine.
1.Navigate to and click the Start menu.
2.Find "My Computer" and right click on it. If this is not in your start menu, check the desktop, the icon should be there.
3.Select "Manage" and the Computer Management pane will open
4.Click on "Device Manager" to expand the installed devices on your machine.
5.Locate the PCI Express Slot in the list and right click on it. (You may need to expand "PCI Express Adapters" or similar to view the card.
6.Select "Enable" and the card should be good to go.
If you see a Red X through the listed controller, it needs to be installed with the proper drivers. This model Gateway drivers can be found at the following link.
Feb 25, 2010 | Gateway GT5674 Desktop PC
My gateway profile 5 will not install the network driver. 1394 net adapter is installed but doesn't connect me to the internet.
1394 is NOT your Network adapter... you need to go to device manager and look there for any "Network Adapter" then right click and "Update Drivers". Your network card will have a "Name" or say PCI network device or the like. Thats the driver you need to find and install. Hopefully it is on your drive somewhere.
Jan 31, 2010 | Gateway Profile 5 PC Desktop
Dell Inspiron B130--I have an internal Broadcom 1370 Wireless mini pci card installed. When installed the card everything worked. I had to reformat and reinstal WinXP from the hidden partition using...
Check Device manager to see if the wireless card is Enabled and working. If it has a yellow ? against it then reinstall the wireless PCI LAN driver.
Jul 08, 2009 | Dell Inspiron B130 Notebook
I have a Gateway DX4710-05 with Windows Vista 64-bit and I'm trying to install a PCI HDTV TV Tuner. Everything seems to install ok, but I can't get it to scan for channels. The pci card is from Sabrent. I...
First you need to find out exact model of your TV Tuner. If it is installed it should be in
Start\Control Panel\System\Device Manager\Sound, video and game controllers.
To check installation you can double click it and in tab "General" you will see "This device is working properly" or not.
Knowing the board part number you can check out Sabrent web site for drivers: and see if they have a newer one - if yes, then give it a try.
Mar 12, 2009 | Gateway Computers & Internet
Ethenet port
Go into device manager and make sure the drivers for the ethernet controller are there. If they are, uninstall them, then do a hardware search. It will find the port and install the drivers automatically. If the drivers are installed and everything shows correctly, then it may be the port itself.
Jun 12, 2008 | Gateway 400SD4 Notebook
Sound problem
try disabling the sound and rebooting, so that vista thinks its a new device and reinstalls
May 26, 2008 | Gateway 400SD4 Notebook
Gateway 400SD4 Notebook Logo
135 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
